Ethanol Free Fuel gets Reprieve
/ Ethanol Free Fuel gets Reprieve
Maybe 9 million... +/- 420,000 in my city of Oakland.
My closest TBN friend lives in the Santa Cruz Mountains...
Have several tractor friends not on TBN in the Santa Cruz Mountains... 7 miles on a gravel road subject to closure in wet weather... off grid living deep in the Redwoods.
/ Ethanol Free Fuel gets Reprieve #62
Gotcha. I guess everyone has thier own idea of isolated. I always think of the folks over in the Sandhills east of me who have to drive 2 hours to go to wal mart as isolated but I have less than 100k people within 2 hours of my place so I guess I am isolated to some degree as well compared to 9 million. Pretty cool that you found a place to feel that way with so many folks nearby.
/ Ethanol Free Fuel gets Reprieve #63
The key thing to the EPA raising the level of ethanol use in the country fails to get realized by many folks. While they did raise the level of ethanol, they are not mandating how it gets used. If folks that have flex fuel vehicles (and there a heck of a lot of them around) would use higher blends like E20, E30, E50, E60, E85, then that would take the pressure off for folks to get ethanol free fuel for specific needs or to calm their enlarged paranoia gland. Only a small fraction of folks who can use the higher blends actually do so. I am strictly a cost per mile person. I will use all the various blends depending on seasonal pricing and such as to which one gives me the best value. For quite a while, it has been E15 in my area. The price spread hasn't been good enough for a while to use E85. Several years ago, E85 was all I used in my flex fuel capable stuff. When regular gas was hitting that $4 mark around the country, E85 was well over $1 cheaper. I was tickled pink to have a flex fuel vehicle. Even with the lower fuel economy of E85, I still was keeping my cost per mile well below what it would have been on regular gas or E10. I have even run E20 in cars that called only for E10 and not had a problem, but that is vehicle specific I suppose.
/ Ethanol Free Fuel gets Reprieve #64
/ Ethanol Free Fuel gets Reprieve #65
what is it about flex fuel vehicles Copperhead that make them tolerant of/invulnerable to the higher concentrations? Is it just hoses and seals?
What about performance? I always wondered following a flex fuel vehicle whether they ran differently on regular unleaded.
You seem to be on top of this, good info.
cost per mile is the smart way as long as maintenance does not increase
If one travels a lot, might be ingesting different kinds of fuel due to availability;
then what? Are the emissions computers smart enough to really maximize efficiency
from each type of gasoline? Never used to be this complicated...remember when Sunoco was the big deal
when they had that dial and you could get six blends, not two or three.
Smart marketing for the time, and even now. Pumps are changing, was at a Shell station yesterday with a brand new pump
and off to one side was E-0. Sorry, didn't pay attention to octane.
/ Ethanol Free Fuel gets Reprieve #66
Once upon a time I owned a diesel car, a wonderfully fun to drive Golf TDI.
Thankfully sold a few years back.
I have also owned a 3500 Ram Cummins.
when you own a diesel I think your horizons expand somewhat because you realize what you are burning is just one of many fuels.
Many diesels can easily be converted to run on cooking oil or other oils that are not petroleum based, but perhaps plant based instead.
And some say they can smell popcorn behind these vehicles.
What if they formulated a diesel fuel made entirely of corn that ran great in your truck, and did not screw up the existing hardware or software?
I'd buy it. So I'm not against corn per se.
I believe the introduction of corn into our fuels was done with inadequate testing on long standing equipment, to better understand
potential side effects such as increased attraction to water and long term impact on maintenance. I think they just went gung ho with
the green banner, and political favors called in, to reduce the amount of petroleum we consumed one way or the other. Well I think we got some other
in the bargain. Others disagree and have had zero problems with ethanol based fuel.
I like the idea of a butane based fuel for power but as an old fireman, boy that could be dangerous in a bad accident. They would have to have
race car quality tanks for that.
well, one thing for sure, this challenge will go away with electric power. With all these charging stations being built, now through Europe too, and VW and BMW both
making huge investments in electric power, plus Tesla of course, wait until all those model 3's get on the road, we will then be making much more room in "gas" stations for the
plug ins. They will need overhead signs to direct us in to the right spot...
/ Ethanol Free Fuel gets Reprieve #67
Can't speak to every brand or engine, but look at several of the official GM HP/Torque charts on many of their flex fuel engines. E85 bumps up HP and Torque on many of them. They all have an ethanol sensor that determines ethanol content of the fuel and adjusts ECM parameters accordingly. After having hauled many production auto parts to the assembly plants for many years, I can attest that fuel systems are virtually identical between flex fuel and non flex fuel vehicles. Simplicity is cost saving to auto plants. Only difference is the ethanol sensor and ECM programming on a flex fuel rated engine, less than $100 cost. E85 has roughly a 100 octane level so timing and other factors can be adjusted by ECM to take advantage of that. The sensor reads and adjusts the ECM based on fuel blend in the tank. So one can get varying levels of ethanol and things adjust. Per the manual, when changing blends, drive for a minimum 7 miles to let the system adjust.
I monitor my oil sample testing. I have yet to see any appreciable difference in oil samples for wear or contamination even using the higher blends of ethanol. Fuel dilution and other factors just aren't there.
No doubt, ethanol blends will cause mpg to suffer. That is where looking at cost per mile really comes into play. If the blend is substantially cheaper, then even with the lower mpg, it still might be a lower cost per mile to use. Right now, E0 regular is going for about $2.35 in my area. E85 is going for about $1.39. If I get 11-12 mpg average for all miles (town, rural gravel roads, highway, hauling) in my 3/4 ton pickup with E85 (which I do), that comes out to about 12.5 cents a mile to use it. With E0 regular at $2.35, I would have to get 19 mpg all the time just to break even. Not going to happen with the 6.0L in my 2015 Silverado 2500 Z71. Maybe a good day, empty, with a strong tail wind, and slower highway driving only.
I have been using various blends since the late 70's, as have many of my neighbors. If there was going to be any appreciable problem in doing so, we would have come across it. My 1974 Pontiac did just fine on E10 for over 250,000 miles. My '79 Bronco (another carbureted vehicle) did just fine on it for most of it's life. And every vehicle I have had between then and now has gotten E10 all the time, with the flex fuel versions jumping around on various blends. Still waiting for the major pitfall in doing so. Sure, you will find some occasional anecdotal stories of ethanol causing a major problem, but usually, when all things are considered, it had more to do with the negative condition of the engine and fuel system already, or a serious goof in fuel management and storage. Leaving E10 in a vented container or vented fuel tank for quite a while in humid weather is pretty stupid. And a fuel system that has a lot of varnish and other buildup in it will get a major cleaning out with E10 and can have a detrimental effect on filters and carbs. But it wasn't the fuel's fault, it was other things.
But it all comes down to one's comfort level. If one just cannot stand the idea of ethanol in their fuel, then don't buy it. If your state doesn't allow E0, then either live with it or move. Better yet, put leverage on your hired help at the state capitol. There is no mandate by the Feds that all fuel must have ethanol, nor is there any ban on ethanol free. That is a state directed or city directed issue. I can get ethanol free regular and premium all around me in almost every town at the majority of filling stations. If there was a ban of E0 by the feds, I should be seeing it. But even with all the ethanol free around me, ethanol blends outsell it by several margins according to state data. We just don't suffer from enlarged paranoia glands.
/ Ethanol Free Fuel gets Reprieve #68
We use to dump some Wesson cooking oil in our kerosene gun heater when working at building houses in the winter months, made the house smell like a Theater instead of a Truck stop, made the bullet end get just a little bit redder also. The homeowners loved it on there walk through, and our clothes smelt better after work.
/ Ethanol Free Fuel gets Reprieve #69
Rocky, that's too funny. One of the options on the most expensive German sedans is an ability to add a variety of scents to the car flowing through the hvac I assume.
Like those home nightlight gizmos with the oil added. I made my late wife take every one of those things down, they had too many recalls for catching on fire. She was not pleased...liked the smell.
Wonder if you could dump a little violet extract in your heater...;)
I wonder, since I love marketing, if how a car smelled could be marketed for a particular brand of gasoline. We know about the popcorn smell, and everyone
seems to like it. Compared to the horrible rotten eggs smell one seems to get out of so many Japanese catalytic converters. Some cars smell so bad in front of you it comes through the vents,
charcoal filter and all. I'm sure the exhaust is clean but what a nasty chemically smell. How about one that smells like cheeseburgers? French fries?
Strawberry? Chocolate...
Why don't the refiners add something new...they sure have the delivery device. I bet some gals would like the violets...
Just like giving medicine to your child or dog, mask it in something else, like an E85 blend would smell like strawberries.
Biggest obstacle to that are guys in their jacked up 250's wanting to smell strawberries...:D
The few stations that offered E85 no longer do so... the "Pumps" are now Hydrogen for fuel cell vehicles.
I have no idea statewide... only in my trading area.
DEUTZ MARATHON...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
