HELP - BX steering wheel removal?
/ HELP - BX steering wheel removal? #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
Actually I am trying to replace the instrument cluster as my tach is dead and likely due to water damage as the sealed unit is condensing badly. Question at the moment is how does one remove the steering wheel? I have the nut off of the spindle and it appears it should just pull off. Persuasion is not working... is there a trick or special tool? I see three holes on the hub of the steering wheel. :confused3:
/ HELP - BX steering wheel removal? #2
Ummm, steering wheel puller, perhaps? Most auto parts stores have loaner tools for stuff like this nowadays, so check one out.
/ HELP - BX steering wheel removal? #4
Mark,
The WSM is vague on this subject. Per the Parts manual it is a serrated/tapered shaft end under the nut. I would use my slide hammer puller as a first idea w/o seeing what there is to grab onto with the fingers as there is no top view of the steering wheel. Some pictures would help.
Ron
/ HELP - BX steering wheel removal? #6
David,
Agree, always best to go easy. The shaft goes down into the steering controller, no clue on how rugged that item is. This is probably one of those things Kubota missing in assembly of putting a little anti-seize on that serrated shaft. Also I believe Mark parks his outside like I do, although he is closer to salt water. Dealer had mine off last year to replace the instrument panel under a KATAC casualty claim. Anew controller was not on the parts list so it must of come off easy. Usually a light bump will break such connections loose.
Ron
Yeah I have the WSM and no help there but I can see it looks to be a spline gear that should slip off. I did some tapping on spindle (or whatever you call it) while trying to pull the wheel off. Put a come along strap around the ROPS while tapping. No luck. Saw on Youtube a guy use a U bolt that snuggly fit around the wheel column base and then use a two jaw gear puller on what looked to be an older JD tractor wheel. Going to try this method this afternoon. Let it sit overnight with a couple doses of WD40.
Doubt the attached pics help other than maybe give you a laugh.
Good news! Got the steering wheel off. Used a three jaw gear puller with a 2-1/2in U bolt. The jaws would not engage the column without the U bolt around the hub. Duct taped the jaws to help keep them from slipping off. The spline gear was dry and seized so I lubed it with some Permatex anti-seize so hopefully I don't have this trouble again.
/ HELP - BX steering wheel removal? #9
I like your high-tech retaining tape!! :thumbsup:
/ HELP - BX steering wheel removal? #11
"The sign of quality workmanship is no wrinkles in you duct tape"
"You only need two tools .... penetrating oil and duct tape.
If it doesn't move and it should ... use the penetrating oil.
If it moves and it shouldn't ... use the duct tape."
/ HELP - BX steering wheel removal? #12
I need eight tools. Penetrating oil, duct tape, and a six pack!
Yep a mini fridge in the garage/shop was the latest tool box I added! :drink:
/ HELP - BX steering wheel removal? #14
Why did you need to remove steering wheel?? My cluster comes out without removing anything else??? But, I do have a BX24...
/ HELP - BX steering wheel removal? #16
draggoneggs,
My only question is why do you have to pull the steering wheel to remove the dash cluster? I replaced the dash cluster on my BX by reaching under it through the battery compartment. Only 2 tabs on the top and 2 tabs on the bottom held it in. hen I released the bottom tabs, it just popped out. The ne one just snapped into place.
Dave
/ HELP - BX steering wheel removal? #18
I broke the steering wheel on my BX23. I found a replacement at Messicks and ordered it. I really dreaded taking the old one off, figuring that it would probably have a hidden retaining ring or, at least, be stuck on there pretty good.
I removed the nut and, to my surprise, the wheel came right off with no issue whatsoever. The new one slipped right on. It was less than a 5 minute job.
It's one of the few maintenance / repair jobs I've done that was easier than expected.
draggoneggs,
Dave
I can't remember now if tried from the bottom but thought I did.
2005 FRAC TANK 500BBL WHEELED (A63569)
2005 FRAC TANK...
Wolverine Skid Steer Tree Digger (A64047)
Wolverine Skid...
Wolverine 48� Excavator Flail Mower (A64047)
Wolverine 48�...
BOBCAT 3650 UTV (A63569)
BOBCAT 3650 UTV...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
20ft. Tilt Trailer (A64047)
20ft. Tilt Trailer...
