PTO Generator outlet box problems. Help need pls
/ PTO Generator outlet box problems. Help need pls #1
gogojuice
Canada
Kubota
I have a bx2670 with a 15kw pto generator. (I know I can't max it out).
I am going with an interlock on my fuse panel.
Problem is finding a 60 amp outlet box for the outside of the house. I can find 30 and 50, but not 60.
The 60amp one they brought had the power cord go through the top and then travel down the outside wall.
I am looking for a 60amp that comes out the back of the box. I don't wish to see the power cord running down my wall.
I'm hoping that you can help me locate one.
Thanks
/ PTO Generator outlet box problems. Help need pls #2
Why not just punch or drill a knockout on the back and use the one you have?
Nothing magic......
/ PTO Generator outlet box problems. Help need pls #3
OR go to your local electrical supply house and ask them to show you an "LL" or "RR"
Come out of your existing knockout and enter the wall with one of those.
I'll call an electrical supply place tomorrow. Harry.. the current one has a large hole in the top. When the wires are mounted for the bottom.. it leaves the bare wire ope at the top. Probably not the best idea for a weather proof receptacle to have a hole in the top?
I suppose I could just duck tape it lol.
/ PTO Generator outlet box problems. Help need pls #5
You can get plugs for these knock out holes, In a pinch I've used a piece of sheet metal and glue it over the hole with silicone.
/ PTO Generator outlet box problems. Help need pls #6
The straight blade 60amp is a 15-60 and 15-60R. In twist lock L14-60 and L14-60R. Tractor could probably run 13KW of electrical load.
Ok.. So the contractor called back this am.
Seems there is confusion.
My PTO generator has a female plug in (I haven't seen a different kind), So we would need a male cable plug in from there.
When we get to the house....to plug in.... what should the end of the cord be, and what should the receptacle be on the house?
The contractors says there is a safety concern if both ends of the cable are male.
However.. I am unable to find a 60amp male connector for the receptacle for the house box.
Is this supposed to be so difficult?
/ PTO Generator outlet box problems. Help need pls #8
Not difficult , and don't let anybody tell you that a double ended male patch cord between the generator and what ever is legal.
Call in a pro, it is cheaper than making mistakes.
You said something about an interlock on a breaker or fuse panel? Using a Kirk key system?
How about installing a proper 200 amp transfer switch between the meter base and first fuse or breaker panel?
No they said it was illegal. So were not going that route.
I called in a master electrician. He's confident we can get it done. He just has to find the right stuff. I'm on the chat board with PLATT electrical. I'll give you an update asap. Yes using the interlock which will have a 200amp breaker of its own.
/ PTO Generator outlet box problems. Help need pls #11
That is a typical generator connector. I've installed hundreds of them for portable industrial generators.
It is not what you find on residential generators but your electrician can certainly make a cord to match.
So.. I called and all of a sudden it got complicated with the store.
How many volts, how many poles how many phazes...etc.. I'm LOST!!!
All I could say was a PTO Generator, 16KW (I can't make that much) going to a 200 amp interlock.
I guess its not going to be a simple twist lock form what I can gather.
Thanks for trying to help me through this.. Im frustrated..
/ PTO Generator outlet box problems. Help need pls #13
Howdy,
The connection you are talking about are called pin & sleeve connections. The important connection information is 460_12W, which means the plug is 125/250 volts, North American, orange colored. Each manufacturer puts there special naming in the front of the numbers.
__460P12W = plug
__460C12W = connector
__460R12W = receptacle
__460B12W = inlet
Mennekes
ME460B12W
Scame
SCM460B12W
Hubbell
HBL460B12W
and others....
Marine use, mining use, stage and theatre use, generator use. You would just need to find a compatible back box for mounting the inlet. There are others methods too. I make use of Anderson connectors. Specifically the Anderson SB350 plugs matted which are 350 amp plugs bolted together for the 4 wires. The thread is still relevant today with connecting a generator.
Generator Transfer switch connection choices
/ PTO Generator outlet box problems. Help need pls #14
/ PTO Generator outlet box problems. Help need pls #15
This is an example where there are some jobs that "do it your selfers" should not attempt. No time and no money has been saved plus there is extra frustration. Plus your electrician friend is tired of giving out free advice . Does a lawyer give free advice ?
/ PTO Generator outlet box problems. Help need pls #16
I'm confused. You mentioned a contractor in a previous post. If you have a contractor why not let him find the parts and do his job?
Yes. I have a contractor. I'm not doing this myself. However, he brought the wrong stuff last time, so the lost time and money and extra frustration I get.
I did ask on here because I have had great experiences with people helping out. I have even chatted with other electrical supply places who have different opinions.
As for your legal advice. Yes all the time :)
That's what makes it so great, to share our specialities with others who do not have the same level of understanding given a certain topic.
I can certainly say that I don't know it all and have no problem helping where I can.
I apologize for any inconvenience this may have cause you.
/ PTO Generator outlet box problems. Help need pls #18
Thank you for clarifying. If I can help let me know. Personally for over 50A I'd go the pin and sleeve route. I like heavy duty.
Thanks to all who have helped. I appreciate it.
For anyone who goes through the process.. you can see there are different ways, this is the solution which at this time fits my needs.
HBL9461C Plug from generator
SCM460R12W 60Amp Receptacle
SCM460P12W 60 Amp Plug
4C6SIW *wire*
View attachment Q_B0175586.pdf
2003 Sterling L7500 S/A Day Cab Truck Tractor (A64556)
2003 Sterling...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
2013 Nissan Versa Sedan (A64557)
2013 Nissan Versa...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
2010 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2010 Ford F-250...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
