Ugly beads, critics welcome...
/ Ugly beads, critics welcome... #181
Back when I was taking a class in high skool, we had a rig where we'd bend our welds. It was interesting because you'd have the perfect looking weld, but it would crack when bent. The test piece was two 1/4x2" bars with a butt weld. You'd put the weld, facing up over a bottle jack that had two rollers a couple of inches apart. You work the jack and it would bend the bar into a U between the rollers. I referred to it as the "torture rack".
/ Ugly beads, critics welcome... #182
We use to call them the heart break machine. :laughing:
I'm going to buy or build a shop press, and plan to do some torture testing of my own!
Polished those up nice
Thanks! That was with about 15 minutes more practice, but I was able to stop by the steel supply place and buy 65lbs of drops (only $10) yesterday, so I can get back to practicing soon!
/ Ugly beads, critics welcome... #186
If you want to build a coupon bender, here is a print.
So, I'm finally reasonably comfortable with vertical up, and decided it was time to work on overhead welding with 7018.
I read a short description by Jody at Welding Tips and Tricks and jumped right into it. I spent about half an hour and the pic below was my last, and best, bead. I played around with the heat a bit and felt okay with that, but really need practice getting into a comfortable, stable position. Lots of work needed, but I think this would stick together reasonably well.
/ Ugly beads, critics welcome... #188
Not bad at all!:thumbsup: What you need to work on with over head. Take a flat plate and pad weld it. Go left to right. Right to left. Weld towards you, And weld away from you.
Welding away from you is a little hard to do, because the puddle blocks your view. So you really have to pay attention to your travel speed.
/ Ugly beads, critics welcome... #189
I would be very proud of that.
/ Ugly beads, critics welcome... #190
That's overhead? I wouldn't be ashamed of that even if it was in ideal conditions.
Got it...thanks!
I know I need to learn how to be stable in odd positions, but I think I'm going to make an extension so I can stand upright while I practice overhead.
I've also started trying to change other variables like working with fairly thin metal (down to about 12ga so far) in the various positions, but I haven't done a good job of keeping up with this thread!
/ Ugly beads, critics welcome... #194
You've come a long way since you first started. I've been hobby welding over 40 years and built quite a few projects but have never done or had to do any overhead. Very nice looking welds.
Thanks George!
I had enough time today to tack up a plate on some square tubing so I can weld overhead while standing normally. I ran four beads to start a pad as SA suggested. As you look at this they were right to left, but we're actually done left to right. This will take some practice!
That looks very good! :thumbsup::thumbsup:
It is hard to make a weld look good on a flat plate! You are doing really well with your welding:cool:!
Thanks!
I ran a few more beads today, and was getting a pretty good curve in the line, so I stopped, drew a line with chalk, and ran another four beads just now. I also learned that if you don't keep a bit of rod angle at the end, the slag can fall on the rod and put out the arc....did that about three times before I got the message :) That's why you'll see the poor finish with undercut (left side of the picture). I was running these all left to right, so I think I'm going to try right to left next.
I haven't had much time to weld lately, but there is a new addition to the welder family in my shop. The Everlast PowerArc 200ST went back, and this came in:
2004 Subaru Impreza AWD Sedan. (A61569)
2004 Subaru...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2025 Pabreak Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak...
Location Info Please
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A61568)
2019 East...
