Ugly beads, critics welcome...
/ Ugly beads, critics welcome... #181
Back when I was taking a class in high skool, we had a rig where we'd bend our welds. It was interesting because you'd have the perfect looking weld, but it would crack when bent. The test piece was two 1/4x2" bars with a butt weld. You'd put the weld, facing up over a bottle jack that had two rollers a couple of inches apart. You work the jack and it would bend the bar into a U between the rollers. I referred to it as the "torture rack".
/ Ugly beads, critics welcome... #182
We use to call them the heart break machine. :laughing:
I'm going to buy or build a shop press, and plan to do some torture testing of my own!
Polished those up nice
Thanks! That was with about 15 minutes more practice, but I was able to stop by the steel supply place and buy 65lbs of drops (only $10) yesterday, so I can get back to practicing soon!
/ Ugly beads, critics welcome... #186
If you want to build a coupon bender, here is a print.
So, I'm finally reasonably comfortable with vertical up, and decided it was time to work on overhead welding with 7018.
I read a short description by Jody at Welding Tips and Tricks and jumped right into it. I spent about half an hour and the pic below was my last, and best, bead. I played around with the heat a bit and felt okay with that, but really need practice getting into a comfortable, stable position. Lots of work needed, but I think this would stick together reasonably well.
/ Ugly beads, critics welcome... #188
Not bad at all!:thumbsup: What you need to work on with over head. Take a flat plate and pad weld it. Go left to right. Right to left. Weld towards you, And weld away from you.
Welding away from you is a little hard to do, because the puddle blocks your view. So you really have to pay attention to your travel speed.
/ Ugly beads, critics welcome... #189
I would be very proud of that.
/ Ugly beads, critics welcome... #190
That's overhead? I wouldn't be ashamed of that even if it was in ideal conditions.
Got it...thanks!
I know I need to learn how to be stable in odd positions, but I think I'm going to make an extension so I can stand upright while I practice overhead.
I've also started trying to change other variables like working with fairly thin metal (down to about 12ga so far) in the various positions, but I haven't done a good job of keeping up with this thread!
/ Ugly beads, critics welcome... #194
You've come a long way since you first started. I've been hobby welding over 40 years and built quite a few projects but have never done or had to do any overhead. Very nice looking welds.
Thanks George!
I had enough time today to tack up a plate on some square tubing so I can weld overhead while standing normally. I ran four beads to start a pad as SA suggested. As you look at this they were right to left, but we're actually done left to right. This will take some practice!
That looks very good! :thumbsup::thumbsup:
It is hard to make a weld look good on a flat plate! You are doing really well with your welding:cool:!
Thanks!
I ran a few more beads today, and was getting a pretty good curve in the line, so I stopped, drew a line with chalk, and ran another four beads just now. I also learned that if you don't keep a bit of rod angle at the end, the slag can fall on the rod and put out the arc....did that about three times before I got the message :) That's why you'll see the poor finish with undercut (left side of the picture). I was running these all left to right, so I think I'm going to try right to left next.
I haven't had much time to weld lately, but there is a new addition to the welder family in my shop. The Everlast PowerArc 200ST went back, and this came in:
2004 JCB 8017 EXCAVATOR (A62129)
2004 JCB 8017...
Wooden Bench (A61570)
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
2018 Freightliner M2 106 20ft Reefer Box Truck (A60352)
2018 Freightliner...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
