k0ua
Epic Contributor
I'm kind of partial to Rock River ars.
how do you feel about grapples?
I'll bite, no pun intended. What's the consensus of the best wicked grapple for a john Deere 3520 with 300cx loader? A page or two back shows a 3520 but unsure of the grapple size??? I'm thinking 60, but the wicked compact 50 looks nice since its soooo light. Are the base "L" tines the same length on the compact 50 and the wicked 60???
Also any chance of buying it in pieces and welding it together? I thought I read about that some time ago, but haven't heard back from EA about this. EA's is top notch, but it comes with a $price$. Kicking rolling the dice with Titan to simply save some coin... As I doubt I'd wear a grapple out--// although it would be nice to know its going to work and hook up out of the box. I know about their rep, but I am trying to stay on budget!!! Lol
Well that is pretty simple too. For low end AR15's I like DPMS. For high end I like Daniel Defense. Which ones do you like? Oh, and do you prefer direct impingement gas systems or operating rod?
That is my post a few back. I bought the 56" single lid. I know plenty of people say the 50" is strong enough and it probably is but the 56" is still super light at 350lbs. It is actually lighter than my pallet forks. I don't know what your application is so I won't comment on width. I will tell you that the grapple is light enough where I was able to fit as many oak logs in it as I could shut the jaw around and the loader didn't even care.
I agree that 350lbs is still a reasonable grapple weight so long as your loader can lift 1500lbs or more. Hate to see grapple weight cut net lift to less than a half ton because you can pretty easily get that much wood into a grapple. What is the opening width of the jaws? Is the 56" made with 5/16" high strength or 3/8" mild steel? How much more does it cost than the 50" compact?
I see a 54 inch single lid "wicked" with 3/8 A572 steel and the opening width is 7 inches wider than the compact 50 inch like I have. So 37 inches instead of 30. The weight is given at 349 lbs in their chart. Which is about 75 lbs more than mine. The single lid 54 inch is $1690 and the 50 inch compact is $1492.
Thanks for doing the legwork James. Looks like either the 54 or 50 inch would make sense for a Kioti CK. I'd probably go with the 54 on a DK or NX. Having a wider opening is useful.
I have a 60" single lid. Works great on the L4330. Think I'm going to paint the outside tines safety yellow. It will be easier to see, and keep track of when manuvering in tight areas.
Good idea.
Kubota Orange might be almost as visible as safety yellow but would complement your tractor. Either way, post some pics.
