My NX5510H
/ My NX5510H
I'll be running short distances (maybe 1/4 mile), all flat (though I'll be at a very slight decline where I'm going to be dumping). Eventually I'd like to replace the current hook-up on the trailer to a pintle.
This is interesting:
FARM SHOW - "Ball To Pintle" Hitch Adapter
Some of my problem is that I don't have any firsthand look at a fixed tractor drawbar: I can only imagine that it's a flat bar with holes?
What in all of this would work? (assuming that any of these are even correct)
Clevis Hitch | etrailer.com
/ My NX5510H #22
Not sure what the US models are shipped with but our EU versions have a standard drawbar/pin arrangement like this:
If there is plenty of nose weight on what you are towing - on level ground you can generally use one of these:
I've used one of these for years on my other tractor for a stock trailer (sheep) and had no issues, even over rough ground. You should use it sensibly.
The slightly more time consuming version for "lighter" nosed trailers is this:
Search Results
With this, you can tighten the locknuts and ensure a solid pull.. with no pin movement. If you really want to get rough, then this is probably your best bet.
If your bar is just a flat bar with holes, then a straightforward bolt on ball should work fine - like this:
/ My NX5510H
mudplugger, that helps me visualize.
I can't turn up anything like that clevis with the ball hitch here on this side of the pond!:(
/ My NX5510H #24
There's probably a reason for that - litigation :p
You might be able to get one shipped from here for little money if you are prepared to wait a week or two..
/ My NX5510H
OK, looks like it might not be all that difficult at all. The ball coupler on the trailer can be swapped out with a lunette ring:
Lunette ring:
Would then need to figure out something on the tractor drawbar. Seems that others have struggled with this. Best(?) solution (from http://www.tractorbynet.com/forums/attachments/233690-pintle-hitch-draw-bar-2.html):
Quote Originally Posted by Oldmopar View Post
you could weld up a sleave out of 3/8" metal that would slide over your drawbar and pin in place and bolt a hitch on like jpm1 pictured.
This is what we use at work. I don't have any pictures but will try to get some. simple to weld. just a full sleeve that has 2 holes in it that match up to the last 2 holes in the drawbar on one of our m125x tractors. attach a flat vertical plate to the sleeve with a couple of gussets and bold on the pintle hitch and your good to go. comes off easy as well with minimal work. we use one bolt and one pin to make removal faster. we use this hitch to tow our chipper on fence lines and also to pull a 20k lb trailer to haul our bobcat with brush cutter to remote areas where a truck cant go easily. works pretty slick.
edit: watch the tongue on the tires as your tractor can most certainly turn tighter than a truck towing the trailer. one of the fellas i work with found out the hard way when he took off part of some lugs.
/ My NX5510H #26
Lunette ring:
Hi, a lot depends on your drawbar configuration from Kioti US. Can you post a picture of what your Kioti NX drawbar will look like?
I can advise on our EU one - but that may not be correct..
Also, is that a picture of your current trailer drawbar?
If you can post what each look like now - then I can give the best advice.. :)
/ My NX5510H
This is turning out to be quite confusing! Here's a picture I found from the Internet (listing for an 2015 NX5510):
This looks like solid a solid square bar with holes.
Yes, the first picture of the ball hitch is of my trailer. Main point is that I can pretty much put any coupler on that that I'd need.
/ My NX5510H #28
Why not just buy a 2-5/16 the ball and bolt on your tractor's drawbar and use the coupler that's already on your trailer? Your new nx will have a solid drawbar that you can bolt a ball on. Here is what your drawbar will look like
/ My NX5510H #29
OK that looks easy to fix.
As you say, getting a towing ring fitted to your trailer is easy. All ours tend to be welded, but that two bolt mount looks pretty substantial too.
Use high grade bolts though!.
To hitch to a ring with a drawbar - it will need to gain what's known as a hammer strap on the top of the drawbar.
It needs to go in a sort of Y shape like the picture I showed before (red drawbar).
It doesn't matter if the bottom bar is straight and the hammer strap goes above it, as long as you have something to lock the pin in with - top AND bottom.
The pin has a collar at the top, and the clevis pin at the bottom.
Your options then:
1. Ignore this idea of using/changing to a pin and ring for your trailer, and just fit a standard towball to your drawbar. Cheap, not as effective or as tough - but will probably do you for a while.
2. If you have ordered the tractor from a dealer - see if they'll just swap out the drawbar supplied as standard for one with a hammer strap fitted.
3. Fit a hammer strap yourself - but you'll probably need a decent workshop to drill the drawbar (tungsten drill) if it's not already got the holes.
Hammer strap can be bought most places, but you may get a good price from the supplying dealer.
A quick search here found a US site selling them - though this does look expensive. We'd expect to pay maybe GBP20 or GBP30 for one (c.$50) e.g.: Order Hammerstrap, Drawbar A-3545-8913 for tractors for sale | Best price 95. | Hitch & Drawbars at TractorTool
I guess it's now only a choice you can make.
Over here, all our trailers for proper tractor towing are pin and ring.
I have gone a step further on my NX6010 for using the ring towed trailers with a "pick up hitch" as you can see in the photos of the back of my tractor...
Unless you haul a trailer a lot, or are constantly swapping them about (like we do) - it's not worth it...
A neat animation of how one just like it works is here: Dromone - Mechanical Pick up Hitch - YouTube
Advantage is that you can hitch up/unhitch safely whilst staying in the cab!
Hope that helps,
/ My NX5510H #30
That's been an option all along - but DieselBound said right at the start "Eventually I'd like to replace the current hook-up on the trailer to a pintle."... ;)
I guess it depends what he wants to use it for, and just how much weight he's carrying - over what ground...
Personally I like the heavy duty 3 point tow/logging frames you guys can get - we only get the lightweight versions over here.
Yet, if we want pintle/ring fittings - they're everywhere...
/ My NX5510H
OK, I'm going to set this on the back burner until I actually get the tractor. Unfortunately that back burner time has now been increased as the factory failed to ship my tractor! Dealer called to tell me that it didn't come with their shipment. I'm puzzling on how this could happen; but it is, at this point, spilled milk. I'm disappointed. The dealer offered to loan me an NX4510 (he said cabbed 45 hp tractor, so maybe it's something else). That was a good gesture and I told him I'll be OK w/o it and that I'll call in the extra effort when it's really necessary: I have my B7800 and it's able to do what I need done at this time.
On the hitch issue, I was confused as to what the drawbar is on the NX. I was thinking it was clevis-like. It does look like I can put a ball on it (as countrybumpkin said); if I can't put on a pintle hitch then I'd like to go that route.
/ My NX5510H #32
For now that would be your quickest and easiest way to just use a ball. You might ask your dealer if he can find a part number and order a hammer strap, the drawbar is designed for one along with the drawbar pin that comes with the tractor.
/ My NX5510H
Update. Tractor delivery, take two.
Tractor is scheduled to arrive at the dealer's this Friday (10/7) and delivery will be some time next week.
/ My NX5510H
Rumor from my dealer is that they're assembling my tractor. Not sure when it came in. Also wasn't given a completion time. (got left voice mail)
/ My NX5510H
Getting closer...
Apparently they didn't mesh up the ordering and the third rear remove valve is about a week out. Weather is going to turn to absolute crap starting Thursday, so I told them that if they could have everything else ready to go and get this thing delivered to me on Wednesday (which is tomorrow) that I'd install the valve.
/ My NX5510H
Wanted to split posts up because I have a change of direction in topic now...
I've spent a fair amount of time researching rotary mowers: I've decided to go with a rotary now and hold off on a flail until a later date. I'm fairly certain that middle-of-the-road is the way to go for me- "medium duty" cutter ought to be sufficient. And when one talks about "medium duty" one has to look at the leading manufacturers to understand what constitutes "medium duty." Here is what I'm seeing as comparables:
1) Land Pride RCR2672
2) Woods BB720X
3) Bush Hog BH26
All have as standard (and these are what seem to classify them as "medium duty"):
- 10ga decks
- 1/2" x 4" blades (this may not necessarily be a requirement for "medium duty," it's just that they all have this size so I figure that's the standard)
- Cutting capacity of up to 3" dia
- Gearbox ratings of 120hp or more
- Clevis style hook-ups
- Cat 4 drive line w/slip clutch
I like the Brown 416 but they don't run full welds, so I ruled that one out: it's otherwise a nice cutter.
All of these brands have dealers near me.
The RCR2672 has chains standard. The BB720X does not.
The BB720X's blade change system/mechanism is really attractive, though I have never had to change a set of blades (just parted with my old Rankin 5' and after years the blades still had a lot of meat left on them- I didn't necessarily treat it gingerly either!), until NOW... I bought a Land Pride RCR1860 for my B7800 and it comes with well-eaten-up blades; I am unable to get the blade bolts loose (nuts won't budge- had to buy a 43mm socket) and will be resorting to dropping the entire pan off (waiting on yet another stupid socket -36mm). So, this blade thing is kind of really starting to seem more important to me now.
Bush Hog's BH26 doesn't seem to have anything that sets it apart from the others other than its name. The only thing I can see is their "Tough Tail Wheel Beam," and while it looks better than the LCR2672's tail wheel (I'd have to give LP a negative on theirs) it doesn't seem any better than on the BB720x (which I think might be better).
Time is on my side here as we push into Fall and then Winter. I suspect that better deals will be possible off-season. I'll see what dealers are asking now. From what I'm seeing the pricing is just about a tie between the BB720X and RCR2672: $3k-ish. Not sure on the BH26, but I'll find out.
Oh, I'd talked to my Kioti dealer, who also sells Mahindra, and the 7' Super Duty Mahindra (a rebranded Kodiak) would run around $4k. This is the commercial level series, cutting up to 4" stuff (7ga deck); it's nice-looking stuff (but so then too is the higher series for the other manufacturers, though I suspect they're more expensive). I wasn't really considering a 6' Super Duty until I realized this pricing, so I think I'll see what the 6' one is running. Their Medium Duty cutters don't have the clevis pin hook ups like their Super Duty does, otherwise it would be in the running. I got rid of my Rankin and picked up the RCR1860 (I'd been watching used stuff for a long time until this one popped up) because I was tired of the hassle connecting up to just pins: on the B7800 I've had a regular quick hitch and then Pat's quick hitch; the regular quick hitch didn't work for my box blade so that style of hitch got sold; Pat's quick hitch just kind of became a pain, nominal gains, so were taken off (and I'll look to sell them).
/ My NX5510H
Haven't mentioned (here) that the monitor I got was bad. White screen and nothing else: two different cameras and two different photo cameras and no images on the monitor. Sent it back for another one. Sad, in that the retailers have ZERO ability to provide "technical" assistance, couldn't tell me what the "Menu" button is supposed to do! No documentation. I'd figured that if the "Menu" button was supposed to bring up some sort of display then that would tell me that this monitor was in fact bad (not something that I had hooked up wrong; I'm 99.9% certain that I had things hooked up right- the .1% is in case my mind is failing me :D).
No word from the dealer today, so figure that this is going to drag on for another week. At this point it doesn't matter all that much because we're going to be having a ton of rain for the next week+.
/ My NX5510H #38
2) Woods BB720X
3) Bush Hog BH26
- 10ga decks
Random thoughts on the BB720X (since I have one and have pegged out what it can and cannot do).
1) I broke a driveshaft because I hit a windfall in tall grass and instead of rolling over, the cutter jackknifed my three point lifting it up to the point where my driveshaft flexed and then broke in half. I have learned to back up into the material I'm cutting and so I have the rear set so that it is higher than the front when I have the three point down. Even so, I must be "cool" about "stump jumping" to avoid jack-knifing the three point and shelling a driveshaft. FWIW, my local Fleet Pride reused the undamaged driveshaft ends and replaced the driveshaft for about $300 about half of the cost than what Woods wants for a new driveshaft.
2) Get the chains and reinforced edges for whatever cutter you get.
3) If your machine is a HST with our live PTO, you can run any of the cutters. I rarely stall but I'm also "easing into" heavier material.
4) Ratings are for green hardwoods. Softer material like aspen or poplar will get chewed easier.
5) The single tail wheel is fine although I will likely need a set of wheel bearings on the tail wheel at some point as my cutter has a lot of wheeling around time on it.
6) Get a Quick Hitch. I've had good success with the SpeeCo brand which is cheapest on the internet at Blair's Fleet Farm (as I recall). The Pats Hitch is too light to take the abuse of carrying around 1200+ pound attachments without peening out.
7) Dull blades work well to process material and shred them forcing their roots to send up new sprouts rather than growing out of whatever was cut. Dull blades still do a good job at cutting field grass.
8) Get a set of blades thrown into any deal (or something).
9) Seems to me I paid something like $3500 for my new BB720X in 2014.
10) Woods orange isn't orange, it is sort of burnt-yellow color. They come in different colors and Kioti/Kubota orange is an option.
11) Hang a bungie strap to support the weight of the driveshaft from the top link to support the weight of the driveshaft while attaching the driveshaft. Doing so make life way, way easier.
12) Consider a hydraulic top link. It massively increases to flexibility of your attachments including the angle of attack you can process material with a rotary cutter.
13) Consider getting your wheels filled with Rim Guard for ballast and traction.
/ My NX5510H
Eric, thanks for the reply/input!
Yes, I probably had a good (conservative estimate) 400 hours with my old 5' cutter. I go easy into places that I am not certain what lies below the brush. My property is full of logging land mines! (even finding old, HUGE logging cables) Haven't been easy on the cutter, but also haven't thrashed it. Broke the tail wheel a year ago: w/tax that ran to $180 - I suspect it was an issue of accumulated stress rather than all from one big hit (but one tends to only notice when there's a complete failure!).
I agree on the chains, been thinking about those. Do you recall how much more those ran? Someone about 175 miles away from me (dealer) is selling a new Woods BB720X for $3,300 but it doesn't have chains. I'll get a better idea when I stop by a nearby Woods dealer on what the chains would run.
Most of the smaller stuff I have is of the soft variety, such as alder. In general I try to preserve most saplings as they will one day be my firewood (or someone else's).
I think that I'd only sharpened my old cutter's blades once (three or four years ago), and after reading more I haven't bothered. Original set of blades and they were still decent. I scratch my head over those that are regularly replacing and or sharpening blade.
I've followed your thread so I've picked up a lot of good info (such as the bungee cord for the drive shaft).:thumbsup:
I'm posed to fire off an order for an hydraulic top link once I have the tractor here and can verify the top link's measurements (I can probably go by what others went with but I want to make sure). Also will be measuring for the hoses for the remotes for the grapple. I am excited about the grapple, but the hydraulic top link is something that I have really missed (I should have sought out adding it to my B7800- if my wife does in fact start using it [she says that she'll mow in the tighter areas] then I may add one).
Tractor will be coming from the dealer's with ballast in the rears. This will be a lot of weight on my property and I'm a bit concerned but will watch things: ground is soft.
I'll have to see how I feel about hitching things up whether I want to shell out for a quick hitch. Had one on the B7800 and it was of limited utility because it didn't work with all implements. For now I'll be using the other end of the tractor (bucket, grapple, pallet forks), the rear isn't likely going to see much action until the end of next Spring when it starts to dry out.
I'm not necessarily hung up on colors, but I suppose if I'm ordering new then I figure it might make sense to (try to) color match: I do think that orange/yellow is a good color for implements such as this- anything that's dangerous ought to be more visible!
Dealer update
: Tractor will be delivered tomorrow (w/o the extra remote because it's not in yet- I have to wonder if they just dropped the ball on ordering it since the tractor oder was originally in weeks ago). Weather is going to be utter crap, which is disappointing: hoping it's not an omen; when I'd gotten my B7800 delivered it was an unusually warm and sunny November day (2010). Supposedly going to spend an hour with me going over things.
/ My NX5510H #40
I'd have to second Eric on the quick attach. Granted I've only had it two weeks, I've changed out attachments 7 times. Each time it's been under half a minute to include PTO hookup on two of those. I talked my dealer into throwing it in at no cost since I did buy several attachments. It's the SpeeCo brand also.
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2022 EZ-GO ELITE...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
