All electric house and a generator
/ All electric house and a generator #41
Apparently, I am told by people in the business that keeping moisture out of the rotor and stator is important. That is why testing under good loading is important. The power source is quite secondary (for testing) in my opinion.
As far as not running life support, well, I would rather not have any back-up, than think I do, and it fails. Because that really sucks! And it's why I lean in the direction of slow running commercial style back-up systems.
/ All electric house and a generator #42
Consider a solar system with battery backup. You will get a 30% tax break and the array will reduce your electric load everyday. If you electric company has net metering, you should look very hard at solar as backup power supply rather than all the drawbacks of a standby generator. HS
Right now my solar array is producing 4.4kwh, it's quite, no fuel, meter running backwards. HS
That's a big investment for system that only works during an outage. With enough battery backup your assertion may not hold water, by the way the array still produces in bad weather. HS
Just remember while your thinking this morning my solar has already produced over 5kwh, and is running at 3.4kw and spinning up. No fuss, no fuel, and all that's happened is the sun came up.... Incredible... HS
The OP lives in about the poorest location in the country for a solar installation.
http://www.nrel.gov/gis/images/map_pv_us_annual10km_dec2008.jpg
And that's the annual picture. Don't look at the winter pictures, its way worse. Its not a good option for his location at all.
/ All electric house and a generator #43
No. I am sure I pretty much have that (poorest) spot covered. Location, PLUS living in a valley on the North Side of a Forested Hill.
Yep around here you never see anything solar except a patio light or landscape lights. We are surrounded with trees so most of light comes when the sun is directly over head!
Thank you all for the wiring info, that helps make things a lot easier to figure out.
Looking tomorrow afternoon at 3 different propane systems and finding out the actual pricing.
/ All electric house and a generator #45
You wouldn't see Solar around here either, except for the fact that our government threw a few billions of tax payers dollars into the scheme!
/ All electric house and a generator #46
I don't want to hijac this thread, but has anyone installed co-generation capability, whereby the motor cooling system is piped into the house for heating purposes? This can nearly double the thermal efficiency of your fuel usage. And a step further can be taken when you use a heat exchanger to extract heat from the exhaust. There are now commercial units that do this with standby power. Even a tractor could be modified with cooling system disconnects (via large hydraulic fittings) in order to circulate hot water into a house area.
/ All electric house and a generator #47
It doesn't seem like a worthwhile expense.
/ All electric house and a generator #48
All the Mennonites around here with their own plants put the cooling water heat into the shop slabs via hydronic systems.
/ All electric house and a generator #49
Don't the Mennonites run the generators full time because they don't believe in on grid electricity? There's a big difference in a full time operation and a stand by generator that runs a few days a year. Another problem is a lot of the homeowner standby generators are air cooled.
/ All electric house and a generator #50
Around here, they don't have much of anything on electricity, unless you include 12V.
They run a diesel motor twice a day, it has a compressor, vacuum pump and charges 12 batts... The compressor fills two 500 gallon propane tanks, the vac pump runs their milking machines and the batts run a few other things.
All the houses/stores have propane lights in them...
SR
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A60352)
2023 HarbinGer V3...
SANY SY35U EXCAVATOR (A59823)
SANY SY35U...
M998 (A55852)
M998 (A55852)
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
