Buying Advice First CUT: Sizing and Used Options
/ First CUT: Sizing and Used Options
Pretty solid thread on 3 point vs independent wood splitter. I hadn't considered long term expense of running up the hours on a tractor (hydraulic fluid, filters, etc.) I have a couple Honda gas engines already. They don't eat much. Unless I can get a SWEET deal on a used one I'll likely borrow or buy a trailered gasoline model. Thanks for the tips.
http://www.tractorbynet.com/forums/attachments/274069-3-pt-hitch-log-splitter.html
Good point Jeff, haven't really considered electric. Will have power at the woodshed so I'll want to keep and electric in mind. At first glance, the 110 models look somewhat anemic compared to gasoline. Not planning to run 220 out there (just a roof with 2x4s for sides). If I can split it with a 5 or 7 ton electric, I'll probably split it by hand. I could still be convinced... Would be nice to test drive one first.
/ First CUT: Sizing and Used Options #44
Good point Jeff, haven't really considered electric. Will have power at the woodshed so I'll want to keep and electric in mind. At first glance, the 110 models look somewhat anemic compared to gasoline. Not planning to run 220 out there (just a roof with 2x4s for sides). If I can split it with a 5 or 7 ton electric, I'll probably split it by hand. I could still be convinced... Would be nice to test drive one first. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=479954"/>
I have had a 4 ton electric splitter it for years, and it works fine for most of our uses, but I don't have any huge 24 inch rounds either. Paid less than $300 for it brand-new. Recently bought a 5.5 ton electric splitter as well.
Just read a dozen threads on plowing vs blowing snow. Seems a SSQA plow with hydraulic angle will be the best tool for me 95% of the time. Any recommendations on a brand or supplier?
/ First CUT: Sizing and Used Options #46
Check out the HLA plows... made by Horst Welding, in Ontario. They make a full line of sizes and weights, and when I needed a plow, Messick's in PA set me up with my HLA 1000, 78", with the hydraulic angling. HLA Snow | 1 SnowBlade
Works well, and seems like it is solidly made. I see the current models come with a crossover relief- I had added mine, because I am plowing a rough lane, with snags here and there. I like being able to lift snow piles up and over using the loader, when I run out of space to put snow.
/ First CUT: Sizing and Used Options #47
i bought a SSQA plate and created a mount for an 8.5 ft meyers. i didn't shorten the a frame on the plow so it hangs way out there, but i can still use it on a truck if need be
I have a dealer just north of here that sells HLA. Need to get a better idea of price. MSRP seems awfully high on those. I could buy an old truck with a plow and move snow from a heated cab for the retail price of those babies.
/ First CUT: Sizing and Used Options #49
AND, you're likely going to get that work done quicker with a decent truck. I'm going by what I've read others say; thankfully I don't have any snow issues.
/ First CUT: Sizing and Used Options #50
We get a pretty decent amount of snow. I do all my snow removal with a cheap back blade and the loader bucket. She, I'd love a SSQA blade and a three point blower, but for the price they want, I'll stick with what I've got. The rest blade is fast and easy, the loader can push the banks back if needed.
@motown you get a LOT more snow than I do. How much drive are you clearing with your back blade? I'm struggling to wrap my head around $2500 to move snow with a plow on the front...
/ First CUT: Sizing and Used Options #52
I clear my driveway which is about 200' and has parking spaces for about 7 cars. I also pack a 1/4 mile trail into the woods by turning the blade backwards and driving forwards. It's a walking trail, but my Jeep will ride on the surface once it's packed well.
Often I plow my neighbor's driveway also. Her's is much longer, about 1/4 mile. Last winter our biggest event was 14". I went out twice during the storm and once afterwards. They were predicting more snow, so I wanted to keep on top of it. If I'd known it'd stop at 14, I could have gone out once during and once after. To do my drive and hers with about 4-5" using only the back blade takes me about 40 minutes. I go fast, zip around and have a blast doing it. The last plowing after the storm ended I probably took about an hour and twenty minutes because I did push some banks back and tidied up a little.
I never used the loader during that storm. If I hadn't been able to go out during the storm, I probably would have had to put the blade on my Kubota which has AG tires and more weight. I don't think the New Holland with industrials could have done it. Not without a loader and chains on all four tires (I run them on the front only) anyway.
I inherited my back blade. Three of them actually. They are cheap, lightweight models. See better ones all the time on Craigslist for under $400. They've got other uses too, like light grading work, and packing my walking trail.
I'd strongly advise picking one up. Try it for a winter. If you don't like it, put it back on Craigslist and try the next most expensive option.
/ First CUT: Sizing and Used Options #53
I converted an old Curtis truck plow to my SSQA;it has worked well.Choice you have with the FEL mounted plows;float the blade or float the FEL.I chose to float the blade and it works quite well for my uses.
@motown - you're making a lot of sense with that advice. I like the idea of a multitasker and watching a few folks move snow with a rear blade online helped me understand the speed one can run it.
I saw a 6 way rear blade at Everything Attachments that looks really interesting. Being able to offset the blade and move your windrows off the side of the drive looks promising (if it doesn't turn the tractor sideways). Price is still a fraction of a blower or front mounted blade, plus the other benefits of having a grader blade.
6 Way Deluxe Scrape Blade for Compact Tractors
They also have a front mounted snow system with hydraulic angle just around $2000. Far less expensive than anything else I've seen.
Compact Front Scrape Snow Blade with Optional Hydraulic Angle
This choice may just come down to what I can snag cheap on Craigslist and like you said, try it a season and if I don't like it, put it back.
For anyone who's moved from a rear blade to a front blade or blower, what made you switch?
/ First CUT: Sizing and Used Options #55
I converted a 9' Western truck plow w/power angle to SSQA for the front of my tractor. Around $500 or so invested. Works great
I found a used 63" 2 stage rear blower in good condition for $825
Great ride vince. I'll bet you look forward to snow with that rig.
/ First CUT: Sizing and Used Options #58
I can't say that I've really had to deal with snow (only once did I do a little bit of removal to free up a car that was stuck in the driveway), but was wondering whether you couldn't turn around the backblade and run in reverse. I know that going in reverse with my box blade creates a much better surface: the tractor rides smooth and keep the boxblade more level.
If this is a possibility AND you have a cab, then maybe plow in reverse using a back-up camera system?
http://www.tractorbynet.com/forums/customization/316927-backup-camera-50-a.html
/ First CUT: Sizing and Used Options #59
You can do it, yes. I usually plow my whole drive going forward then turn the blade around and push the banks back in reverse.
There are a few problems with doing the whole thing in reverse. Namely that the three point is designed to be operated the other way. It's much easier to bend and break stuff if you're going backwards than forwards. Also, moving snow is different than soil. Snow is much lighter, and instead of leveling it, you want to get it gone. By going forwards, you can safely travel much faster and throw the snow quite a ways, which is what you want. Also, there's the visibility issue. Much easier and more fun to wind out the tractor, put down your blade and zip to the end of the drive than to try to do it going backwards.
/ First CUT: Sizing and Used Options #60
That rear blade is exactly what I'm talking about. I'm not sure what tractor you'll be putting it on, but if you're primary use is snow, you can use a fairly wide blade. I'd have to check, but I think mine is a 7'. Might be 6, though. Remember, it will be angled dramatically, so your swath becomes much narrower than the width of your blade.
Personally, if I wanted a front blade like the one you show, I'd buy a blank SSQA plate and weld up a used truck plow to it. Just like Vince's. Should be under $1000.
Everything attachments is a great company by all reports. I've never done business with them, but that's only because my implement budget really only affords used stuff. Honestly, though, for a cheap back blade, look on Craigslist. If you can't find what you want, find a place that sells king Kutter stuff and get either a 6 or 7 foot blade. Just my .02
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
Unused 2022 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
2014 FORD F-150 (A67714)
2014 FORD F-150...
2022 PETERBILT 389 (A67714)
2022 PETERBILT 389...
2017 Ford Fusion Hybrid Sedan (A66738)
2017 Ford Fusion...
2025 Swict 60in Bucket Skid Steer Attachment (A66734)
2025 Swict 60in...
