Excavating a hole in rock
   / Excavating a hole in rock #11
either buy a backhoe and rent a breaker or pay a back service that can gat a breaker. backbone's are assume in this kind of work when an excavator won't do. excavator should be first choose
   / Excavating a hole in rock #12
Back in the day when i was shooting dynamite, shot a hole out right at the house, no problems, a good dynamite person can easily do it.
Ronnie
   / Excavating a hole in rock #14
i worked with one guy that believed that when him and his dad used to build houses, they could dynamite a basement and have all the rock fall into the back of a dump truck.
   / Excavating a hole in rock #15
I don't have any experience with large rocks, just in concrete. I've found that I can speed up the demo of larger sections of concrete by drilling holes in it with my SDS Max first, then hitting it with the jack hammer close to those holes to create an opening that I can make bigger and bigger.
   / Excavating a hole in rock #16
If the hole can hold rain/melt water when finished, there is a danger the tank can float up out of the hole when you use part of the tank's water.
Bruce
   / Excavating a hole in rock #17
What kind of rock and how hard? Is it layered or solid or any other types of breaks?
Bruce
Absolutely correct. One of the reason why we want to put it close to the house is that we are planning on putting a covered wood porch over it. This will help keep the rain water out of the hole, but eventually it will fill with ground water. A daylight drain would be ideal, but we'd have to trench under the house. Instead, I'm planning on creating a open sump of some size and then putting a submersible pump in it.
It's dolomite. Typically with bedrock the upper layer will be fissured and weathered, but this stuff isn't. When I dug the ejector pump pit, I wasn't down a foot before I hit hard rock. The big problem with the breaker is that it wasn't able to displace the rock. I couldn't rattle with the breaker square to the rock. Instead I had to break off pieces.
This is the side of the house where the tank is currently (it was set after the photo was taken). The master plan is that the red door with the stoop (but no steps) will be into a screened porch area. The tank would be placed in the hole below the porch.
2014 MOROOKA MST 3000 VD TRACK DUMPER (A52705)
2014 MOROOKA MST...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A55788)
2017 Ford F-150...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
