Trailer got stolen, so decided to build one
/ Trailer got stolen, so decided to build one #43
Ummm, it's used. Yeah people expect to pay less - a lot less. If you are asking close to new price, why would they bother? They can pick from stock on hand or get built to order for not much more...with a warranty... If they are looking at used items, it is to SAVE MONEY. Not sure where you are at on your price, but if you won't knock at least 20% off new, then you will not even get a response, other than a low-baller. I hear a lot of people say 50% for used stuff is a good target. IME, that is not far off.
So good luck, but reality does not care if you take a loss or not. Just what people are willing to pay.
/ Trailer got stolen, so decided to build one #44
I just now did a search on CL in my area. Lots of hits on a "For Sale" search for "my money back" from people who bought something, used it for a while and "just want to get my money back" on the price.
Try your area.
Bruce
/ Trailer got stolen, so decided to build one #45
If you have the capability then it wil be better to make it yourself.
/ Trailer got stolen, so decided to build one #46
If it sells it sells if not no big deal!! I can extend it to 18' -that's enough to get the tractor and bucket on the trailer and move the axels.
Just a story about the trailer. Yesterday I got a call about it the guy wanted to know if I had the title to it.....why because a trailer that's looks like mine was stolen from his house not far from me I told him come over and check out the paperwork!.
/ Trailer got stolen, so decided to build one #47
It looks great, How much did you spend on materials, may I ask?
/ Trailer got stolen, so decided to build one #48
I'm all for diy projects, but not those built by others that could kill me. Trailers need to be built using engineered plans and welded by certified welders (or somebody that good). Winging something that can carry 6000 pounds at 60 mph is incredibly reckless.
Seeing comments about using 5" channel instead of 3" without any mention of the web thickness shows me how much is missing from this discussion.
Please keep this trailer on your property.
BWSwede
/ Trailer got stolen, so decided to build one #49
BWSwede
You don't need to be certified to weld a trailer together! That's just a piece of paper. As long as you have penertration on both pieces of metal to be welded.
I'm up to around $4100 for materials and consumables.
Life has gotten in the way of finishing. I was hoping to finish the trailer before we broke ground on a house we've been planning on building, but that didn't happened. I've been meeting with contractor and subs during my time off for the past month. My 6 y/o started kinder and my 5 y/o started pre-k this week. This is the first time both kids have attended school. I thought I had a lot of time between dropping off the kids and picking them up, but 3pm rolls around pretty quickly. I can only manage a couple of hours of trailer time a day if I have any time at all. All I have left is to prep for paint and prime and paint, then do the wiring for lights and brakes.
/ Trailer got stolen, so decided to build one #51
Ditto, just do it right and check it occasionally and you will be fine.
/ Trailer got stolen, so decided to build one #52
Yup pick the right rod and set the machine right to get the right heat
/ Trailer got stolen, so decided to build one #53
Most people I know that build those sort of things over-engineer them by adding more braces, more steel and more weld than a manufacturer. Home built trailers are usually built like tanks.
/ Trailer got stolen, so decided to build one #54
People often worry that they might be endangered by something built by people at the same level of competence as theirs... Its just that the incompetent cant judge someone elses competence.
The worlds biggest disasters were caused by people who concidered themself as competent: those brave enough to ask for others opinion usually spare themself from catastrophic failure.
/ Trailer got stolen, so decided to build one #55
In the past 3 years I have seen the result of two home built trailers that failed parked on the shoulder of a mountain highway I frequent. Both were goosenecks and both folded and drug their bellies. The first was hauling hay, I don't know what the second was hauling as it had been unloaded.
Most construction failures come from faulty construction or user error, not from professionally engineered designs.
Why put innocent people at risk to possibly save a few hundred bucks.
"Usually like tanks" or "usually save themselves from failure" is not good enough for me.
BWSwede
/ Trailer got stolen, so decided to build one #56
If you had spent some time in professional engineering, you wouldnt be so certain that the latter excludes the first !
/ Trailer got stolen, so decided to build one #57
BWSwede
Actually, I'd say very little is missing by ignoring web thickness. I can't imagine why you would want any standard channel other than the lightest section.
If a C3x4.1 isn't enough, go to a C4x5.4 rather than a C3x5 or C3x6.
If a C4x5.4 isn't enough, go to a C5x6.7 rather than a C4x7.25.
If a C5x6.7 isn't enough, go to a C6x8.2 rather than a C5x9.
Assuming you have no depth restrictions - which you are unlikely to see on a trailer - I'll always bump up to the next depth instead of going thicker. The lightest section is still going to be more than adequate for thickness, and usually lighter, and therefore cheaper. Less weight means more remaining carrying capacity and more remaining cash.
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A61567)
2002 Bobcat 863...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2007 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A62129)
2007 CATERPILLAR...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61166)
IMPORTANT PLEASE...
