Gas Usage
/ Gas Usage #1
jfh28
Poconos, PA
Power Trac 2425
Is it just my imagination or do our machines use more gas in the hot weather.......ran out of gas again today while out working in the heat.......thats the second time this week......I've never run out before.......maybe I'm having to much fun on it and don't realize how long I'm out there "working"........haha.....just curious if anyone else has noticed this.......man do I wish these machines came with a fuel gauge........Jack
/ Gas Usage #2
They do not have a fuel gauge? I did not know that. The PT1850 has one. I wonder if they are concerned about electrical sources at the gas tank (mine is diesel). I am not sure how much sending units cost like the ones in cars. You could probably add a mechanical float style one. Perhaps one of the ones that are a dome so you can read it from the side.
Ken
/ Gas Usage
unlike the low boys with the plastic tank my gas tank is part of the steel frame so you can't see what is inside.....plus the fill tube is long enough that you need to shine a flash light down it to get an idea of whats in there....the only reference points you have are where the end of the fill tube penetrates the tank which I use as the "full" point and the gas filter near the bottom at the pull point which I use as the "empty" point.......everything in between is a guess......oddly enough pt put a sticker on the outside of gas tank area that has a line on it and says "do not overfill"........I've never figured out how I'm suppose to see when the gas level is at that point......lol.......the battery compartment extends out over the fill tube which also makes filling a bit of a challenge in tilting the gas can at just the right angle so gas will flow.......those push type nozzles on cans are a real pain as I can never get the angle to actually push the nozzle enough so gas flows out........I'm thankful that it's all steel but this was not one of pt's most well thought out designs...........Jack
/ Gas Usage #4
from the pictures on the web site, you should be able to put in a float style fuel gauge into the fill tube, replacing the solid fill tube cap. For example, my ATV has the style where a float runs up and down a twisted piece of metal. The float rising rotates the metal causing the half dome gauge built into the gas cap to rotate. A commercially available one might not be accurate for real amounts but it would tell you some idea of how much you have.
Just did a quick search and found this one that is 10" long:
http://www.partsreloaded.com/Snowmo...JlhnjSptFMLNyaFwhS32dxV2tEq2d3PyuQaAoRp8P8HAQ
Here is one that is 13.5" long:
Amazon.com: Kelch 54-1815 13.5" Gauge Gas Cap: Automotive
It would not be that hard to make an adapter to be able to use one of these but there might even be one that fits directly.
You could also add a sight tube to the tank but I would be less than thrilled with that unless you put serious protection around it. Another option is to keep the fill tube/cap as is and have another flange welded on for a dedicated float gauge.
Ken
/ Gas Usage #5
I wonder this too the other day, when on one of the most humid days of the year, it felt like my car didn't have the same amount of "go".
Possibilities:
1) Is summer blend of gas the same as winter blend? I thought summer was better?
Humidity:
2) On one hand, one would think that on very humid days that the additional expansion of water vapor into steam in the combustion chamber would increase power.
3) On the other hand, does this change of phase rob energy to do so?
Heat:
4)On one hand, less energy is used (robbed) to raise the air/gas mixture from ambient to combustion temperature (since ambient is higher),
5) On the other hand, hot air is a lot less dense, so less air/gas is entering the cylinder and motor has less power?
I'm guessing #5 is the most realistic / noticeable?
/ Gas Usage #6
Hard to say if the difference is noticeable to me. I use a little over a gallon per hour year round. I have the plastic tank, so one time, when it was empty, I poured in a gallon, drew a line, poured in another, drew a second line, etc... so I have 4 one gallon marks on the see-through tank. I can see it through the steel mesh on the engine cover. That won't work for yours.
/ Gas Usage #8
We've got 4 usable gallons on most gas powered Power Tracs. Would it be noticeable to an eyeballer?
/ Gas Usage #11
The volumetric coefficient of expansion for gasoline is very close to 0.001/degree C so that would be very close to 0.0005/degree F. So 125 °F change for one gallon = 1 gallon +1 gallon x 0.0005/°F x 125°F = 1.06 gallons. So just from a "gasoline density" point of view, the cold gasoline would have ~6% more energy than the hot gasoline. I am pretty sure I am remembering the numbers correctly. I will check later and if i am wrong, I will post again.
Ken
/ Gas Usage #12
Ken
I like eggs...
:laughing:
/ Gas Usage
thanks ken thats an interesting idea.......just measured the fill tube......it's 8" long at about a 45 deg angle........so at best I would only have a couple of inches of the fuel gauge in fuel when full so would need to find something a bit longer to be of use......Jack
Gas Tank Cap - Arctic Cat Snowmobile (167241) (w/Gauge) [21146] - $15.5 : Parts Reloaded, Your Source For Hard To Find Motorsports Parts
Ken
/ Gas Usage
I've never measured how much fuel my tank holds but based on whats left in a full 5 gal gas jug after filling I'm guessing my tank holds a little less then 3 gal as I get pretty close to two fill-ups per 5 gal jug....my tank is a welded pt custom steel tank so I'm thinking it was designed based on room available and not on vol of fuel to fill......Jack
/ Gas Usage #16
Ken
Wow! I like bacon with eggs. :D
Ok, so how much time in a tank of gas, say 4.5 gallons? Does 3.5 minute per gallon sound right?
/ Gas Usage #19
About a henweigh.
Nobody has asked,,, what's a henweigh?? :laughing:
I run a LOT of gas through 2 gas engine machines, including one with a 24HP Onan,,,
I see very little difference in fuel consumption due to temperature.
/ Gas Usage #20
Wow! I like bacon with eggs. :D Ok, so how much time in a tank of gas, say 4.5 gallons? Does 3.5 minute per gallon sound right?
I got about 1.5 GPH on my 25 HP Kohler.
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
2018 Chevy Traverse 3rd Row Seating (A63118)
2018 Chevy...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
