I thought I would post up a review of the Honda Pioneer 500. I have the 2015 model and I don't believe much has changed with the 2016 models that are available now. To buy the pioneer, I traded in my trusty 2006 Honda Rancher 2x4 foot shift fourwheeler. It was a great machine but I thought I could really benefit from the "utility" of a side by side.
The P500 has fit my needs perfectly. I was looking for something that I could use as a tool on the ranch and would still be fun to ride. I found myself wanting something with a bed that I could carry tools, patch/build fence, feed cattle, spray pastures and fence lines amongst other chores. We have a Kubota 1100 RTV on the ranch and while it is a workhorse, it is just plain boring to drive and I don't like the transmission (not to mention it is a boat anchor going through Florida mud!).
The Pioneer 500 comes with the running gear out of a Honda Foreman so the engine and transmission are tried and true. There is a five speed semi-automatic transmission that is controlled by paddle shifters mounted to the steering column. The shifts are smooth, crisp and fast. The ECU is programmed to ****** the throttle automatically as you shift so there is no need to release the skinny peddle while shifting.
The top speed of the P500 is about 42 mph compared to ~55 in the Foreman so the P500 is geared low for more torque. I recently launched a pair of jet skis and was able to pull them out on a soft Florida lake shore without spinning. The suspension is much smoother than my solid axle four wheeler but it is in no way a trophy truck.
I have added the Honda OEM hardtop roof, a big sky gun rack, Strong Made front bumper, 20" Super Bright LEDs light bar, custom aluminum bed with Kolpin tool box (made for Yamaha Rhino) and an 8" LED light bar facing rearward. The next thing to do is to add some taller tires such as the Interco Interforce tires in 27.5 (typical R1 design).
In its stock form, the P500 comes with an atv style rack but I really wanted a bed. I went to a local welder with some plans. I decided on 1" square aluminum sides with 1/8" aluminum sheet as the floor. Overall, the bed weighs about 30 lbs so it doesn't impact the carrying capacity of the machine (officially 450 lbs but it can handle more than that easily).
If anyone would like more specifics I would be happy to share.
