Is it time for a gasoline engine tractor?
/ Is it time for a gasoline engine tractor? #241
You are going to have to do a little better in reading my post...
You can pull FULL power out of your pto, but you should not pull full power out of the pto for continuous operation.
When you are mowing, you aren't pulling MAX power out of the pto... The hp you are pulling varies with the load, sometimes the grass is thicker/heavier and you may approach MAX, then you get to a easier spot and you aren't pulling MAX...
Just because you are running at pto speed, it doesn't mean you are pulling MAX hp out of the pto...
That's the part "some of you here", are missing...
SR
Your the one not reading my posts.
I didn't say pto speed/rpm, and I didn't say max ? Whatever that is.
I'm talking 'rated' pto hp. If your machine won't make rated hp continuously, it is.. Well.. Sad ;)
A machine should make its rated hp at load, till the fuel tank sucks in, then do it again when you refill, rinse and repeat.
I can certainly guarantee you I have pulled rated load for a couple fuel tanks a day, till I was tired, not the tractor! ;)
Now give it up, who's making the wussy tractor that wont do its rated load?
/ Is it time for a gasoline engine tractor? #242
Mmm ( in the highest gear that could be pulled without continually bogging the tractors engines for hours on end had to be running @ rated pto power )
I don't think I missed anything...
If the tractors were pushed any faster they would continually bog- ie no longer maintain engine PTO rpm... and these are governed engines.
There are NO limitations on rated power pto use for Either of my diesel tractors In the operator manuals that I have been able to find.
My guess is that applies to most of the TBNers diesel tractors and their manuals...
As Yet No One has posted a manuals quote- concerning limiting use @ rated PTO power-
and if someone does, Well that's what some of us would like to see.
Exactly.
Heck my antique gassers will pull a days hard work bit IT might take a couple tanks.
/ Is it time for a gasoline engine tractor? #243
I'm not a big ecoboost fan ;)
c'mon Soundguy, wouldn't you like a little Ford Ecoboost to add to your extensive Ford collection? One with a cab...
yes, I did mean a Hellcat car engine earlier, thought that was funny though. Who would ever think the Chrysler 707 hp Hellcat engine would be the wimp Hellcat engine?.....:D As far as an engine goes, you can't be built with tougher components. But do we really need or want a tractor engine
that goes faster than 3000 rpm? And I'm still a little fuzzy as to whether we are looking for power or torque here. I'm sure both but what should be prioritized?
I thought torque involved rotational twist and that's a pto for sure. or a tractor axle pulling against the wheel held back by the friction of the surface of the ground engaging implement.
The reason the big Tesla is such a moonrocket is it produces enormous amounts of torque instantly.
We may be getting more gas engines in tractors as alternatives, but sooner or later, after I'm gone, I think all tractors will be electric.
Maybe diesel powered electric, generators on wheels, but still electric propulsion. One at each wheel. Think of how well that could steer on a row crop tractor
making the end of row turn.
And how much would you pay for that 75hp gas Ecoboost tractor Soundguy? less than diesel?
regular unleaded 2.15 today, road diesel 2.20
farm tractors need fueling and what about hauling large quantities of gasoline around? Can you do that safely? Stiffer regs than diesel? Certainly way more flammable.
And how long will it last in a farm fuel tank?
/ Is it time for a gasoline engine tractor? #244
I think he is saying, If your using 100% of the power you stalled the engine
90% of the power your likely lugging the engine, 80% you can run continuous.
/ Is it time for a gasoline engine tractor? #245
I dont know what he's saying.. That's why I'm using a quantifiable term, like 'rated' ( pto hp )
Lugging would be adding throttle and not gaining rpm.
/ Is it time for a gasoline engine tractor? #247
Yes and using 90% power you would be at that point.
Would you?
If you have 10% more hp available.. And your load only needed 3% more.. You wouldn't be lugging!
/ Is it time for a gasoline engine tractor? #248
Sawyer Rob, even with a generator I can't see anyone realistically running at max horsepower for a half hour continuously?
/ Is it time for a gasoline engine tractor? #249
Max rated hp ;), yes!
/ Is it time for a gasoline engine tractor? #250
Would you?
You stalled the engine at 100% power.
IMO 90% would be lugging or dam close to it.
So 80% continuous in the manuals makes sense to me.
/ Is it time for a gasoline engine tractor? #251
If its at the point it will lug, IE, more throttle won't speed her up, but she's not loosing rpm... At that magic point, I think you could call that 100%. IE, adding any more load starts the stall and loss of rpm.
Reason I say that is 100 and not 90, is because at 90, you still have more hp available.. 10% to be exact. Remember hp is a calc of 'work done'. If you have hp left over (10%) you have not yet reached maximum work capability.
At 100% hp you are doing the max work you can.. As long as that max hp/work is no less than needed for the load applied, you aren't stalled.. You are working at max capability.
/ Is it time for a gasoline engine tractor? #253
The owner's manual for my Workmaster does not make any mention of load or duty cycle. The only reference to proper break in procedure for the engine is to not load the engine during the break in period. They define loading as running the engine where when you add throttle the tractor can't increase speed of operation. I've run the tractor thus far mostly at the rated RPM to run the PTO in bush hogging and finish mowing. I had always heard to vary throttle input on new engines and I have done that as much as possible but the owner's manual makes no mention of it. I need to read it some more. First time I've had to break in a new engine.
/ Is it time for a gasoline engine tractor? #254
I follow your logic, but I just want to use a real life example to make sure I'm on the same page. When I was in college, my dad replaced me with a bigger tractor. The Case 930 would pull a bigger plow than the 730. :) So I was using it to plow some alfalfa ground. In the low ground, it would lug down about 500 rpm, but keep fighting through it and recover the rpm after about 200 yards. I never had to downshift, but the black smoke was rolling out. So at what point was I at 90% and 100% ?
Dang, I miss that beast. According to Tractordata, it was 80 pto hp, but pulling that 5/16's it kept up with the neighbor's Deutz that I think was the DX110 at 102 hp.
/ Is it time for a gasoline engine tractor? #255
Many people mistake torque rise for power.
/ Is it time for a gasoline engine tractor? #258
PTO power is no maximum or rated power. Just look at the power, torque and fuel consumption curves. In example Kubota 1505 produces maximum power 33HP at 3300 rpm but my tractor has PTO power 28 HP set at 2500 rpm. Investigating the chart closer you would see that 2500 rpm is very close to maximum torque and the best specific fuel consumption. Simple mathematics will show that the engine produces 85% of rated power at PTO speed. Now if you are engaging in heavy ground work and going gets tough you might up the speed to 3300 rpm and use full power. Based on my brief experience the the engine will run noticeably hotter.
From above it is apparent, while running a generator, you will be using 85% of power at maximum load. So my guess is you could run it at that load continuously.
/ Is it time for a gasoline engine tractor? #259
I think that the Nebraska tests run tractors at rated PTO RPM's and identify the HP level at different time intervals. For a test to be considered accurate they run them for 2 hours? I know that in the 60's my dad said that when new a Allis-Chalmers would come into the dealership they would hook them up to the dyno and typically a 50 HP rated D-17 would initially pull 55 plus HP. After 15 minutes or so that rated output would be reduced somewhat to usually around 53 or so. Back then Allis-Chalmers and other manufacturers rated tractors at the PTO. They were always underrated from he factory. If you look at the Nebraska test for those tractors the tests will show higher output than stated HP.
/ Is it time for a gasoline engine tractor? #260
Our JD also had showed more on the Dyno then rated. It should for the fuel that it uses!
As for generators. That's why it important to start with something that runs at 1800 rpm. It's just purring along putting out only about half of what the engine is capable of. When my little JD 770 (Yanmar) ran my Onan 15 kw PTO genset, you pulled that throttle wide open to get 540/60 cycles. As the song says, "that's all there is and there ain't no more"!
As I mentioned several times before, I tried an experiment with a 2-1 PTO gearbox, thinking I could use this for light loads. The tractor would not even turn it with no load! It just surged in a most disturbing way, trying to catch it's breath. That genset did have a speed-up sprocket driven arrangement, that did not help. The Rotor spun quite quickly.
2025 Kivel 48in Forks and Frame Tractor Attachment (A61572)
2025 Kivel 48in...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
