Is it time for a gasoline engine tractor?
   / Is it time for a gasoline engine tractor? #101
   / Is it time for a gasoline engine tractor? #102
I doubt that. Gasoline engines have a lot of technology under the hood these days. EFI has a lot of stuff going on.
Todays gas compared to todays tier iv diesel and I don't care how they chose to get the diesel to meet tier iv, gas has less going on, hands down.
   / Is it time for a gasoline engine tractor? #104
In the grand scheme of things having to refuel every 5-1/2 hrs instead of every 7hrs is not that big of a deal. ...
In the grand scheme of things, that's about a 21.5% increase in your fuel budget, which is HUGE for a farmer.
   / Is it time for a gasoline engine tractor? #105
Kerosene (No. 1 Fuel oil) 134,000BTU/gallon
Burner fuel oil (No. 2 oil) 140,000BTU/gallon
http://www.human.cornell.edu/dea/outreach/upload/CompareHeatFuels.pdf
Or
Grade Heating Value
(Btu/US gal) Comments
Fuel Oil No. 1 132900 - 137000 Small Space Heaters
Fuel Oil No. 2 137000 - 141800 Residential Heating
Fuel Oil No. 4 143100 - 148100 Industrial Burners
Fuel Oil No. 5 (Light) 146800 - 150000 Preheating in General Required
Fuel Oil No.5 (Heavy) 149400 - 152000 Heating Required
Fuel Oil No. 6 151300 - 155900 Bunker C
Google
   / Is it time for a gasoline engine tractor? #106
Or
Grade Heating Value
Google
113% #2 diesel is 129500 btu and gasoline 114000btu.
With the price of diesel being 20-30% more expensive than gasoline the past 9-10 years. The 113% more btu in diesel still makes diesel cost more per btu of energy.
Gasoline gallon equivalent - Wikipedia, the free encyclopedia
Gasoline gallon equivalent tables[edit]
GGE calculated for gasoline in US gallons at 114000 BTU per gallon,
or 7594 kilocalories per litre[2]
Fuel: liquid, US gallons GGE GGE % BTU/gal kWh/gal HP-hr/gal kcal/litre
Gasoline (base)[3] 1.0000 100.00% 114,000 33.41 44.79 7594.0
Gasoline (conventional, summer)[3] 0.9960 100.40% 114,500 33.56 44.99 7624.5
Gasoline (conventional, winter)[3] 1.0130 98.72% 112,500 32.97 44.20 7496.5
Gasoline (reformulated gasoline, E10 - ethanol)[3] 1.0190 98.14% 111,836 32.78 43.94 7452.4
Gasoline (reformulated gasoline, ETBE)[3] 1.0190 98.14% 111,811 32.77 43.93 7452.4
Gasoline (reformulated gasoline, MTBE)[3] 1.0200 98.04% 111,745 32.75 43.90 7445.1
Gasoline (10% MTBE)[4] 1.0200 98.04% 112,000 32.83 44.00 7445.1
Gasoline (regular unleaded)[5] 1.0000 100.00% 114,100 33.44 44.83 7594.0
Diesel #2[5] 0.8800 113.64% 129,500 37.95 50.87 8629.8
Biodiesel (B100)[5] 0.9600 104.17% 118,300 34.80 46.65 8629.5
Bio Diesel (B20)[5] 0.9000 111.11% 127,250 37.12 49.76 8437.7
Liquid natural gas (LNG)[5] 1.5362 65.10% 75,000 21.75 29.16 4943.3
Liquefied Petroleum Gas (Propane / Autogas) (LPG)[5] 1.2470 80.19% 91,500 26.82 35.95 6089.84
Methanol fuel (M100)[5] 2.0100 49.75% 56,800 16.62 22.28 3778.1
Ethanol fuel (E100)[5] 1.5000 66.67% 76,100 22.27 29.85 5062.7
Ethanol (E85)[5] 1.3900 71.94% 81,800 24.04 32.23 5463.3
Jet fuel (naphtha)[6] 0.9700 103.09% 118,700 34.44 46.17 7828.9
Jet fuel (kerosene)[6] 0.9000 111.11% 128,100 37.12 49.76 8437.7
Nitromethane fuel ~2.3 41.23% 47,000
GGE calculated on non-liquid fuels
Fuel: non-liquid GGE GGE % BTU/unit kWh/unit
Gasoline (base)[3][7] 1.0000 100.00% 114,000 BTU/gal 33.41
Compressed natural gas (CNG)[8] 126.67 cu ft (3.587 m3) 20,268 BTU/lb
Hydrogen at 101.325 kPa 357.37 cu ft 319 BTU/cu ft[9]
Hydrogen by weight 0.997 kg (2.198 lb)[10] 119.9 MJ/kg (51,500 BTU/lb)[11]
Electricity 33.40 kilowatt-hours 3,413 BTU/(kW·h) [12][13] 33.40
   / Is it time for a gasoline engine tractor? #107
btw the conversation was about a hobby farmer's or estate owners under 50HP CUT and such, not Mr Big Time Operator with a couple of 400HP tractors and thousands of acres.
   / Is it time for a gasoline engine tractor? #108
"Farm" #2 diesel here, is and has been around 50 cents a gallon cheaper here than the cheapest gas...sometimes it's even more than 50 cents a gallon cheaper...
SR
   / Is it time for a gasoline engine tractor? #109
SR
Have you priced AG gasoline?
   / Is it time for a gasoline engine tractor? #110
SR
How many hobby farmers and rural estate owners can obtain the bulk high volume discount for farm fuel? Most pickup a couple of five gallon jugs from the gas station when in town.
Once again we are not talking about Big Time Operators, marine propulsion , irrigation pumps or electrical utility power generation. It's about under 50HP CUT.
202480 (A54757)
202480 (A54757)
2025 GPS Trailer (A56859)
2025 GPS Trailer...
10' CONTAINER (A52706)
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
