Is it time for a gasoline engine tractor?
   / Is it time for a gasoline engine tractor? #121
Knowing what I don't know now, if I had the choice of buying gas or diesel tractor, I'd pick the one that's significantly the quietest, fuel consumption would come in sec. Same if I was buying a new pickup, when ever I walk by a diesel pickup, I can hear it 200ft away, for me, motor noise is good if I was driving a 1962 Ford Thunderbird, but on anything else I want quiet, might have to wait for Dylithium Crystal power.
   / Is it time for a gasoline engine tractor? #122
My brother and I have a total of 5 gas tractors, no diesels. They work just fine, don't seem to burn a lot of fuel so it's not a factor. I like the quiet and lack of diesel smell. The two 75 year old MMs aren't real quiet, but still quieter than diesels. One of them runs a 6' rear mower on my 5 acres of unused pasture.
A new diesel tractor would have some advantages, like a live pto and hydro drive, but it's not worth the price to change for me. Would like to have a new gas tractor just as much.
   / Is it time for a gasoline engine tractor? #123
IF only you was as smart as you would like the folks here, to think you are...
In MANY places, including here, ag diesel is available right at the pump, just take a can and fill it with what ever amount you want... I buy mine from the same station I buy all of my fuel...
I'll help you out with a "hint", it's RED!
SR
Yes, that's not an issue here either. Several stations handle off road diesel. I've got a 50 gallon tank with a pump I utilize on the back of my truck to fill with off road diesel.
   / Is it time for a gasoline engine tractor? #124
I can assure you my very new mtd mower does indeed have a throttle, and can be run at more than one engine speed!
What is the hp limit on your "small engines dont have to comply" statement?
Gas tractors from 9-30 hp have done lots of work in the last 70 years...
As for life expectancy.. I'd say gassers started out goid then dropped in the 70's and are now coming back.
Running, working gasser antiques testify to that.
Is your MTD a push mower or a rider? I was thinking push mowers, I have not seen a push mower in a while that didn't just have an on and off switch. Not saying I am an expert but just showing my point that small gas engines to meet regulations are specially setup to work at rated and not much else. The carburetors are adjusted for rated and not meant to be variable like the old days. Lots of smaller motors now are going EFI just to meet the standards.
I think you misunderstood what I said, current tier 4 regulations break "Nonroad Spark-Ignition Engines 19 Kilowatts and Below" down into different levels based on engine size, year, EPA phase, and if it is hand held or not. They also break out things like marine generators. What I was meaning is that a small lawnmower motor doesn't have to meet the same standards that a larger motor you would find in a tractor does.
I would disagree with your life expectancy, I would say gassers have been on a steady climb since day one but in the 60s diesels overtook gas and stayed ahead but have been losing ground to the gas motors.
I don't disagree that gas tractors can do the work, I am merely talking about the differences between gas and diesel engines and why diesel gained favor a long time ago.
In 1990 my father bought an 8200 Heston windrower and got it with a gas engine. It was one of 6 built (or that is what we were told) that year and I think it was the next year that they dropped the gas option. Just not enough demand.
   / Is it time for a gasoline engine tractor? #125
Lets not forget the Oliver 770 was a 1958 to 1967 vintage low compression carburated gasser burning leaded fuel and produced 12.25 HP per hour per gallon of gasoline , 4.3 gallons per hour at full power to make 50.0HP.
The diesel made 14.5 HP per gallon per hour and used 3.4 gallons of high sulphur per hour to make 48.8HP.
Those are Nebraska tests b.t.w.
Taking a wild guess the fuel tank held maybe 25 gallons ?
In the grand scheme of things having to refuel every 5-1/2 hrs instead of every 7hrs is not that big of a deal. In particular when gasoline has been cheaper than diesel the past 9-10 years.
Getting back to engines of 2016 instead of the 1950's. Today's direct injection high compression gas operating on cheaper gasoline would put the 1950's Waukesha diesel to shame. For those of you who like to compare modern diesels to old gassers. Turn about is fairplay.
The tanks on those were 20 gallon.
I didn't know you were a Waukesha fan. For those that don't know on the Oliver Waukesha engines, the diesel engines and the gas engines were basically the same motor. So your example of 4.3 to 3.4 further proves that in very similar motors the diesel fuel usage is less in this case.
I will disagree with your refueling comment. When you are working the machine for weeks on end then yes, refueling time is a big deal. That is time you could have the wheels turning trying to make money.
Sure the direct injection high compression engine would put the old Waukesha engine to shame (though it wouldn't do it with the style and hum of the Waukesha) a modern turbo high fuel pressure diesel would put an old engine to shame as well. I was comparing similar era engines, old vs old.
Something else that has not been brought up. When storing gasoline above ground or non protected you can lose a lot of fuel from evaporation. For example the University of North Dakota did a study showing in a non protected 300 gallon tank you could loose 10 gallons a month of gasoline but the diesel rate was small enough it wasn't a concern. Gasoline that was subject to evaporation had an effect on fuel quality where diesel didn't show any difference.
   / Is it time for a gasoline engine tractor? #126
I just got 250 gallons of diesel delivered for my new tank at $1.399 a gallon. Well, it was two months ago when the price was at the bottom. Red died. No paperwork...
About two years worth for me, and I figured diesel was good for two years. Actually I'll probably get it topped off next summer.
Would I do this with gasoline? Not even with ethanol free.
Clearly older lower compression tractor engines seem to run on almost anything you put in. My experience with engines under 20hp is very different though. Only exception seems to be my "real" Hondas, not Chondas, which always start. Granted I dose them with SeaFoam, etc.
I'm at 250 hours with my diesel X750 JD GT and I flat out love the thing. I do find fuel usage goes up substantially when run at higher rpm, so i try to slow it down a bit, and keep my blades sharp so I can.
What about torque and HP concerns? Haven't diesels always put out more torque? Isnt that what we really want with our tractors? Though I was surprised to find the spec on my 23hp Vanguard that I repowered my Gravely with was almost the same torque as my diesel JD. But I'm guessing that torque comes in at higher rpm. But then one mows at higher rpm...
Torque doesn't do work. Force over distance with relation to time is a measure of work. When you say torque, are you referring to torque rise when lugged down during an overload condition ? With a hydrostatic or powershift machine the point is mute.
   / Is it time for a gasoline engine tractor? #127
Whilst gas motors for tractors again are a possibility, if they were practical they would be in semi's and Ford/Dodge/GM would be plastering the TV with ads about their big block, high torque, gas 3/4 ton trucks. There is no law saying you can't rip out the diesel in your Kubota and bolt in a 454 Chevy to get rid of the emmisions krap, have at it.... But I bet the diesel was and is the best choice.... Probably the ' next big thing ' will be battery powered tractors for lower hp machines.. have to plug it in for an hour or so a couple times a day.. :(
because the Semi truck is a HD applications with a duty cycle near full rpm and full power. The CUT, forklift, manlift, car and light truck are light duty application at part throttle and part load. I am being to think that some people don't know the difference ? Or they are so devoted to diesel since the 1950's they don't want to face what the EPA has done to a good engine and will again in 2019 with tier V?
   / Is it time for a gasoline engine tractor? #129
This argument has played out over the last 100 years, gas lost a long time ago; more expensive, hard to store, dangerous to use, has less energy, costs more to refine, and gas engines don't produce the toque need to do jobs a tractor performs, gas engines require more maintenance, and are shorter lived. It's a no brainier it's diesel. Oh, by the way a clean diesel produces way less CO2 then gas, just added that for a modern twist. HS
Your story would stand in 1970 with low compression gassers using carbs, point ignition and leaded fuel. Now it's now 2016 with Tier IV . Gassers in 2016 unlike 1970 are high compression, direct injected and use unleaded fuel. Diesels now in 2016 unlike in 1970 are loaded with EGR, delayed injection, glow plugs, turbo, variable waste gate, particulate filter, urea injection, two batteries, gelled fuel an complex/expensive filtration.
   / Is it time for a gasoline engine tractor? #130
SR
No red pumps here at the truck and car gas stations.
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2014 Dodge Charger Passenger Car, VIN # 2C3CDXAT8EH223963 (A57453)
2014 Dodge Charger...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
Quick Attach 84" Skid Steer Broom, S/N 103581, Asset# 73 (A59076)
Quick Attach 84"...
2020 Komatsu D155AX-8 Crawler Dozer, S/N 100205, PIN# KMT0D126PJC100205, Turbo Diesel Engine, 13' (A59076)
2020 Komatsu...
