Which Gooseneck Trailer?
/ Which Gooseneck Trailer? #61
I feel the same way, but I was asked what the GVWR was and I got it right off the sticker, I am satisfied that it will haul more than I will be putting on it, for that matter I probably could have got by with a 14k trailer but I am kinda like a big kid and wanted a little better toy and they made me a deal that I couldn't pass up, actually cheaper than most 14k trailers around here.
I totally understand. I also don't like to haul near capacity. I'd rather have too much trailer as too little. A big load for me is two tractors totaling 16K.
/ Which Gooseneck Trailer? #62
I agree. Hauling right near the stated capacity 8s asking for trouble. A little more room for error isn't a bad thing. I know when I was looking at a 14k trailer I never thought I would need more, now I'm considering tandem duals with 12k axles to be able to move bigger loads. I do have a truck big enough to handle it now so that makes a big difference too. My 1 ton diesel wasn't pleasant towing at capacity on the trailer. The international just toys with everything I can put behind it now.
Nice trailer. Do you know the empty weight on it? What is the GVWR - 20k?
I,m sorry it took me so long to get this trailer weighed, but I have been so busy with any and everything else, but I put it on the scales today and it weighed in at 7,380 pounds almost exactly what my truck weighs. One other thing I felt like I needed to clarify is that the axles were not Dexter axles, they were LCI or Lippert axles, I have read a lot about problems with these axles but they were pretty much all on travel trailers and were not 10k axles, I have since talked to some people who said that there are nothing wrong with these axles and that the company had gotten their issues fixed and that all the parts are Dexter compatible, anyhow I haven't had any problems and thought I would give an update. Charlie.
/ Which Gooseneck Trailer? #65
Nice looking trailer Lineman! Those Gator trailers seem to be well built. I think I'll look into them for when I replace my gn trailer. I would be looking for almost the same trailer. We run 17.5s on stock trailers and have been super pleased with them.
I have been very pleased with the 17.5 tires and the 10k super single axles and yes they are heavy built trailers, I got the workhorse series which is their basic trailer but it still has the 14" I beam pierced frame and appears to be very well built, it doesn't have the Dexter axles like their top of the line trailer, it has Lippert axles but I haven't had any problems so far, for $ 7695.00 for a 25 plus 5 made just like I wanted it, I can't complain.
/ Which Gooseneck Trailer? #67
Thanks for sharing! I always forget to check for replies on this site :laughing:
/ Which Gooseneck Trailer? #68
Lippert still has major issues with the axles. Over on the Grand Design RV group folks are having to have the seals replaced right and left. I am just waiting for my Grand Design RV to start throwing grease on the brakes. My Dexter and Rockwell axles on my Big Tex and PJ trailers have never gave me any trouble.
Well, so far no troubles as of yet, but I don't use it every day, I hope it works out for me, you can find bad reviews on anything and I certainly saw all the bad stuff on the RV axles but I have yet to find anyone that has had any problems with the 10k oil bath axles, hope it won't be me.
/ Which Gooseneck Trailer? #70
sweet trailer! I'm in the market. Assuming u have 4.10 grears like me, does this weight mean you have a carrying capacity of 6,620#s?
I do have the 4:10 gears in my truck, as far as the trailer goes they call it a 24k trailer, I assume they are considering pin weight as a factor in them rating it that high, this is what I consider it, the trailer has 2-10k super single axles with 17.5 tires, therefore I consider my carrying capacity to be somewhere around 13,000lbs. Will I put a little more than that on it when hauling hay out of the field, probably so.
/ Which Gooseneck Trailer? #73
Yup, they are expecting you to put 4~5 K on the pin when they rate your trailer. You will be limited by your trucks axle rating.
/ Which Gooseneck Trailer? #74
Our trucks are rated to tow a max of 14k lbs. your trailer is using up more than half that capacity empty?
Am I understanding right? If you trailer 13k you'll exceed your trucks capacity by around 6k, right?
Absolutely, I'm going to exceed the limit on my truck from my hayfield to the barn which is a little less than a 1/4 of a mile. There is a man who buys hay from me who comes about 70 miles and he has me stack 26 round rolls on his trailer and his truck is a Chevrolet 2500 HD a few years older than mine except his is a diesel and he makes the trip 4 or 5 times a year.
/ Which Gooseneck Trailer? #76
Right on... Yeah, I would t worry about that use case.
Plan on pulling your 5093e? Guessing that with loader and cutter is over 10k, plus trailer around 18k?
/ Which Gooseneck Trailer? #77
I'll gurantee it's over 18k if it has loaded tires. My 5083e is as well so... Thats alot of weight behind a 3/4t. The only thing that helps is the flatland of FL.
I would put it on the trailer and haul it if I need to, like to carry it to the shop to get it worked on or whatever, it does have loaded tires and a FEL so you are probably about right, I imagine it weighs in excess of 11k. Most of my hauling besides the work here on the farm will be me hauling my smaller tractor over to my hunting/fishing camp to mow and or push and clear, it's about 100 miles over there.
I imagine I am probably a little overloaded, but it pulled it and stopped it without a problem, I also decided to test the theory of not having a torque tube and completely loading one side, I did and it never flexed or budged that I could tell.
Sorry on the last post I uploaded the same picture twice.
Adams Under Truck Conveyor (A63688)
Adams Under Truck...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2021 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A61572)
2021 Caterpillar...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
