Round tubing
/ Round tubing #31
I don't have a lot of experience working with round tube. I did however purchase the HF tube notcher and set it up in about 10 minutes and make my first nearly acceptable cut a couple minutes later. As with all HF tools there is a need to shim and adjust. Once I figured that out I was able to make precise notches quickly and easily. I was making 90 degree cuts but it looks just as easy to make cuts from 30 to 90 degrees without more than moving a bolt along a calibrated arm. And, once you've set the device up, you can cut an identical notch in about a minute. Just reclamp a new piece, measure, tighten and turn on the drill. Actual cut takes about five seconds.
I've used both torch and plasma but I don't see how those would be as quick or repeatable as the notcher. For the price of the HF notcher (?$45) and a set of bimetal hole saws, it seems a simple way for a novice to prepare tubes for welding. If I was undertaking a serious project I'd probably invest in one of the US made notchers but for general duty notching of thin wall tubing up to about 2 inches I was impressed with the HF (after shimming). All I needed after the cut was to file the burrs and weld. Pretty efficient.
/ Round tubing #32
A $45.00 notching machine, didn't know they was that cheap, is there a Youtube video on one?
/ Round tubing #33
I built a firewood rack out of tubing using a bandsaw to make saddle cuts. I think the same thing could be accomplished with a cutoff saw.
This is a video that basically shows how to do it.
How to make a Saddle Cut with a bandsaw - Instructable - YouTube
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
207280 (A52708)
207280 (A52708)
(INOP) MASSEY FERGUSON 263 TRACTOR (A59823)
(INOP) MASSEY...
2004 CATERPILLAR 416D BACKHOE (A59823)
2004 CATERPILLAR...
2011 Ford F750 Bucket Truck (A60352)
2011 Ford F750...
