new grass
/ new grass #1
darrenjttu
Glen Rose, Tx
JD 4300
I planted some giant Bermuda seed on about an acre of one of my pastures about a month ago. The grass seed grew and is now about 3 inches high in some places. The problem is that the weeds are exploding with growth right now. I really need to mow them before they become too much for my big riding mower. If I had the setting on the highest level and only cut the weeds and not the Bermuda do you think it would hurt any thing? There still are little grass seedlings emerging so I wouldn't want to hurt those.
/ new grass #2
For an acre? I think I would get a hand sprayer with a broadleaf herbicide and kill off the weeds that way.
/ new grass
When I get the goats they will take care of the weeds. Right now I just want to mow it because it looks bad bit I don't want to hurt the new seedlings from the tires.
/ new grass #4
Can you walk thru with a weed whacker and take care of them individually?
I have a couple small areas of young grass.... And I try to avoid them but I've noticed walking or running it over with my BX didn't appear to kill it... But, I wouldn't run over the same spot more than once.
Also, sorry to hijack but do you have any details on how you seeded your acre? I have just shy of an acre I recently took back from a greedy farmer next door that I'd like to get seed on soon.
/ new grass
I plowed it then I put seed in a broadcast spreader and then draged a chain link fence over it. Each seed has a certain depth it should be planted.
/ new grass #6
The recommendation I've always followed on new seeded Bermuda is to keep it mowed to control the weeds. In the first year chemicals will weaken the grass.
/ new grass #8
make sure blades are sharp
/ new grass #9
I agree with this^^^^^
You can mow most Bermuda low enough to choke out weeds over time.
/ new grass #10
The higher that you cut the grass will allow your roots to go deeper. Healthier grass will eventually choke out weeds. A good fertilizer will also help with weeds, but I wouldn't recommend a weed and feed.
/ new grass #11
In the PNW we don't grow Bermuda grass, but much finer red fescue, rye, and blue grass blend. Broad leaf weeds such as dandelions, etc are a pain. Agree that one key is healthy deep roots that will help choke out the weeds. Fertilizer high in potassium and phosphorus promote root growth vs. nitrogen that promotes leaf growth. Another key is deep enough topsoil that grass with finer roots can engulf. Weeds do better in poor soil because they often have a tap root that can go down deeper than grass roots to where water and other minerals might exist. Aerating and reseeding can be effective too. If you do have way too much weed, then a weed and feed after a year, then reseeding after waiting some time for the soil to purify might be in order. Good luck.
/ new grass #12
You can use weed and feed if you must. Long term use will cause problems for trees.
/ new grass #13
You bring up a good point about higher cutting allowing the grass to root better. I allow my grass to get taller with my Fescue and go to seed before cutting in the fall. The rest of the year I let it get to about 6 inches plus then mow it to 4 inches, never lower than that. My next door neighbor is an agronomist and he has helped me a lot.
I suspect most people are looking for instant results but using good root stimulators over the winter can allow the grass roots to thicken. The next spring the weeds will be reduced dramatically. No herbicide needed in my case.
/ new grass #14
For years we planted rye in the fall just because we were told we had to. The past few years we let it seed out, and I really don't see much difference. It sure saved us a lot of work and money.
/ new grass #15
I agree... I don't like weed/feed fertilizers unless you need to do serious battle... I am... as I previously said... a proponent of reseeding and feeding with root loving chemicals. Cutting/Mulching grass just after it is goes to seed is a great solution. Especially if your soil will take it. Scuffing or aerating first will do wonders.
/ new grass #16
I use rye on a couple of properties where the customers request it but not on my own lawns. Most of the ranches I deal with are more interested in permanent pastures and less interested in using annual rye for winter feeding and cover. I find a lot of people at our latitude can benefit more by irrigating the permanent pasture over winter and using the fertilizers for root growth. The dry areas here in New Mexico are hard to get much feed from and I don't bother with these properties. We are at about the same latitude as Mabank TX so the lower elevations will have similar temperatures. I live in Ruidoso and most years I have green grass about 9 to 10 months out of the yearl
/ new grass #17
Hi jenkins... I suppose all depends on your latitude and rainfall. Here in the PNW we like blends of fescue, rye, and blue.
/ new grass #18
I have had the best luck with Fescue but don't use it on horse properties. We have all year flood irrigation in the Hondo valley NM.
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
832856 (A61166)
832856 (A61166)
