Everlast PowerArc 160
/ Everlast PowerArc 160
Huh I felt it was pretty mediocre been awhile since I walked a cup.
/ Everlast PowerArc 160 #43
People really don't understand how nice these units are for the price and what you can do with it. Weld quality is professional quality. You won't do that nice with a tombstone I don't think...TIG anyway.
/ Everlast PowerArc 160 #44
Mark, are there more of these available? I do have a MM180 MIG machine, and an ancient A/C only buzz-box that I bought in 1980. I don't use it for much anymore, and probably don't need more than the Miller, but a new Everlast A/C & D/C stick plus, would be pretty cool.
/ Everlast PowerArc 160 #45
I've only used mine a little bit. So far I'm VERY happy with the smoothness of my welds using E6011 rods. The 1 amp step adjustments are a big change from my tombstone.
/ Everlast PowerArc 160 #46
The 1 amp steps are even more important if you want to do some scratch start TIG with it.
/ Everlast PowerArc 160 #47
Hey Mark, just want to doublecheck something I noticed on my new-to-me PA160 (thank you): It is marked for 240 only, no 120 input option listed...is this feature only on the newer versions of the PA140/160/200 (my suspicion) or is my unit capable of it, but is just not marked that way?
Trying to figure out if I need to make a new dryer cord or if I can run it on a 20A 120 outlet.
/ Everlast PowerArc 160 #48
The original PA160 is 220-240 volts only. There is no provision for 110-120 volt operation.
/ Everlast PowerArc 160 #49
Thanks, that was what I suspected from the label.
Would have been nice to realize that earlier, running from my 120-only generator would have been a nice benefit...maybe I'll pick up a newer PA140 yet.
/ Everlast PowerArc 160 #50
James is correct. The 160 is 240 V only. There are adapters that you can buy ready made to convert a 14-50 receptacle into a welder plug. But with these as they are, without a plug if you only (and I mean only) have a 14 50 or some other type plug, you can make one up to match from HD, or Lowe's, and drop the neutral, just use the green for the ground. White and black should go to the hot. Don't confuse a welder white wire with the dryer's white wire as that is the neutral. The white should go to the red terminal, and the black to the black. I don't typically give out wiring information publicly like this because it is confusing and so many people can misread it and there are those that have "exceptions". But, I want to give the best info I have.
I probably should mention something here, as it has been an issue in the past and people claim we have falsely advertised the older 160, 200 and 300 units as being scratch start TIG capable. First, these units, as have been shown , are TIG capable, but don't expect these units to go down to 5 amps or something. They aren't for low end TIG welding. We've had customers buy them and then say we didn't tell them it wouldn't do low amp TIG welding, which apparently is what they bought them for. If you need to weld 30 amps or less with TIG, move on. Second, these units have built in arc force control which does boost the amps off the base amperage while welding so the amps will vary some what according to the arc length. And third, no these will not weld aluminum, IF you are buying it to weld aluminum. These are DC. Yes, technically you can weld aluminum with DC, but if you are buying it to weld aluminum in DC and have no experience with TIG, don't buy it. But as you can see from various members posts, they can and will TIG weld in DC and do a passable job. If you need super controlled TIG parameters you might want to pass on these units. We do have TIG specific welders that can do that, though.
/ Everlast PowerArc 160 #51
Yes these are available. But they are not AC. They are DC only. But when you have a DC stick unit, you'll say AC what??
/ Everlast PowerArc 160 #52
Hi Mark, nice talking with you a few days ago. Sorry again about your FIL. Eagerly waiting on the 200st, if I didn't need to run 120v I would have went with the 160. And like you said why would anybody want to run AC when you have DC available for stick welding. We used to run AC rod on DC all the time. The only thing I ever used AC for was Aluminum TIG and thawing Pipes! CJ
/ Everlast PowerArc 160 #53
Huh I felt it was pretty mediocre been awhile since I walked a cup. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=467316"/>
I'm searching for a 'Bow Down' animated emoji to post.
/ Everlast PowerArc 160 #54
Hobart 6011, dcrp 1/4 no bevel open butt. 2nd one is overhead, no prep, square open butt and full pen with keyhole.
Want to touch base here again I actually used the 160 pretty extensively this AM to weld out my tooth bar and it did and exceptional job. Want to apologize to SA for my 7018 skills I'm mostly a mig/tig guy don't get a lot of stick time in the shop.
Power Arc 160
TSC Hobart 1/8 7018
Light preheat with oxy/propane
125 amps
/ Everlast PowerArc 160 #57
They look very good to me.:thumbsup: With these inverter welders, I find ESAB's Acclaim 7018 runs the best.
They look very good to me. With these inverter welders, I find ESAB's Acclaim 7018 runs the best.
I'll have to keep my eyes out for those I mostly buy the TSC stuff because it's easy and come in a manageable quantity for home use.
/ Everlast PowerArc 160 #59
I have my local Airgas bring them in for me. The welding supply I normally deal with, is not an ESAB dealer.:(
/ Everlast PowerArc 160 #60
Looks good to me.. The little PA160 is small, lightweight, easy to carry, and makes some nice 7018 beads! I know I have one...:thumbsup:
1996 GREAT DANE TRAILER 48X96 SPREAD AXLE FLATBED (A60736)
1996 GREAT DANE...
New/Unused Landhonor 8ft X 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2023 TAKEUCHI TL8R2 SKID STEER (A62129)
2023 TAKEUCHI...
2013 Peterbilt 365 IMT 40/275K6 9.5 Ton Knuckleboom Crane Truck (A60352)
2013 Peterbilt 365...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
