Tricks to getting good tie in
/ Tricks to getting good tie in #1
aarolar
Augusta Ga
Kubota MX4800
What are the tricks to getting good tie in down in inside corners with stick mainly 7018? I struggle with this it ends up being a big blob or having slag inclusions most of the time.
/ Tricks to getting good tie in #2
I like to use a die grinder with a 1/16-inch thick disk to feather my starts and stops of a weld. Makes for easy tie ins.
Yea I'm good with that I'm only talking about an inside corner with stick.
/ Tricks to getting good tie in #4
Sometimes you have to use a roto burr in a die grinder.
That's exactly what I ended up doing I was wondering if I was doing something wrong.
/ Tricks to getting good tie in #7
You can try to use a smaller rod. Or weld in from the other direction and tie in that way.
/ Tricks to getting good tie in #8
That's the only tool my die grinder has ever seen. That exact one.
/ Tricks to getting good tie in #10
Works excellent for getting slag out of deep grooves on the first pass too.
I use a 1/4" ball tip. Easier to control and almost always it can do all you need.
/ Tricks to getting good tie in #11
When you get to the corner, point your rod forward just a little about 1/4" from where you want to tie in and do a small circle, then pull straight out. Pointing forward at the end makes the bead lay down and the circle re- consumes or re melts the bead and flattens the tie in.
2014 FREIGHTLINER CASCADIA 113 S/A DAY CAB TRUCK TRACTOR (A59912)
2014 FREIGHTLINER...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
2012 JLG G9-43A TELESCOPIC FORKLIFT (A64279)
2012 JLG G9-43A...
2016 Kia Sorento SUV (A61574)
2016 Kia Sorento...
2014 BOBCAT E42 EXCAVATOR (A64279)
2014 BOBCAT E42...
2017 Ford F-350 Flatbed Dump Truck (A61573)
2017 Ford F-350...
