Tricks to getting good tie in
/ Tricks to getting good tie in #1
aarolar
Augusta Ga
Kubota MX4800
What are the tricks to getting good tie in down in inside corners with stick mainly 7018? I struggle with this it ends up being a big blob or having slag inclusions most of the time.
/ Tricks to getting good tie in #2
I like to use a die grinder with a 1/16-inch thick disk to feather my starts and stops of a weld. Makes for easy tie ins.
Yea I'm good with that I'm only talking about an inside corner with stick.
/ Tricks to getting good tie in #4
Sometimes you have to use a roto burr in a die grinder.
That's exactly what I ended up doing I was wondering if I was doing something wrong.
/ Tricks to getting good tie in #7
You can try to use a smaller rod. Or weld in from the other direction and tie in that way.
/ Tricks to getting good tie in #8
That's the only tool my die grinder has ever seen. That exact one.
/ Tricks to getting good tie in #10
Works excellent for getting slag out of deep grooves on the first pass too.
I use a 1/4" ball tip. Easier to control and almost always it can do all you need.
/ Tricks to getting good tie in #11
When you get to the corner, point your rod forward just a little about 1/4" from where you want to tie in and do a small circle, then pull straight out. Pointing forward at the end makes the bead lay down and the circle re- consumes or re melts the bead and flattens the tie in.
