Trailer Brake Help
/ Trailer Brake Help #1
RDrancher
North Texas
New Holland
My flatbed is in the shop so I need to tow my GN with my old F350. All lights work but the trailer brakes will not activate either with the slider or pedal. GN connected to the flatbed truck and brakes work.
F350's Prodigy controller show no connection to the GN.
Brakes work fine when the F350 is connected to my other trailers.
Controller checks out fine, both for the slider and brake switch.
Using a 6-7 way adapter, but....
Voltage checks out fine at the 7 way trailer brake output terminal on the adapter when the brakes are applied.
Switched trailer brake and 12 volt constant connections on the trailer's plug to check brakes.
Plugging in with the 12 volt connection instantly activates the trailer brake magnets.
This would indicated that the trailer brake wire is working.
Switched the wires back to normal position and no brakes / controller shows not connected.
So...what am I missing?
/ Trailer Brake Help #2
My flatbed is in the shop so I need to tow my GN with my old F350. All lights work but the trailer brakes will not activate either with the slider or pedal. GN connected to the flatbed truck and brakes work. F350's Prodigy controller show no connection to the GN. Brakes work fine when the F350 is connected to my other trailers. Controller checks out fine, both for the slider and brake switch. Using a 6-7 way adapter, but.... Voltage checks out fine at the 7 way trailer brake output terminal on the adapter when the brakes are applied. Switched trailer brake and 12 volt constant connections on the trailer's plug to check brakes. Plugging in with the 12 volt connection instantly activates the trailer brake magnets. This would indicated that the trailer brake wire is working. Switched the wires back to normal position and no brakes / controller shows not connected. So...what am I missing?
On many 6 pin to 7 pin adapters they have two wires internally that can be switched. Check that.
If it were me though I would junk all the 6 pin stuff and replace the plug on the truck with a 7 pin. That's what everybody is using nowadays.
Chris
Chris, I took apart the adapter just to check and it's wired correctly. I actually have a 6 to 6 adapter that I use for rental dump trailers since you never know which way they're wired.
What I can't figure out is why I show voltage at the truck's brake output when the controller is activated AND why I can energize the trailer brakes with constant 12 volts from the plug. That means the truck is fine and the trailer's plug and brake wire are fine. I'm stumped.
/ Trailer Brake Help #4
Couldn't this be corrosion in the connector or similar mechanical connection in the connectors?
/ Trailer Brake Help #5
I think you're onto something. The connection the tester is making to both the truck and trailer side could be better than the connector pins are making. Also, when you get 12 volts with a tester (no load) it may not be the same as you get when applied to a load if there is resistance in the connector. Can you test a wire on the trailer downstream of the connector?
/ Trailer Brake Help #6
In this case you can use a test light because the load is probably drawing more current than your multimeter does because of its low internal resistance.
Probably a ground problem or bad connector issue. You can even use a trailer bulb if you don't have a test light. Solder or wrap the center and the outside to 12v+ and ground. May light up may do nothing but probably barely lit.
How doesn't that trailer get ground? If through the hitch check corrosion on the GN mount and then the ground on the trailer itself.
/ Trailer Brake Help #7
Chris, I took apart the adapter just to check and it's wired correctly. I actually have a 6 to 6 adapter that I use for rental dump trailers since you never know which way they're wired. What I can't figure out is why I show voltage at the truck's brake output when the controller is activated AND why I can energize the trailer brakes with constant 12 volts from the plug. That means the truck is fine and the trailer's plug and brake wire are fine. I'm stumped.
Just because there is voltage that does not mean there is amperage.
I would look closely at the trucks ground a brake wire. Check with a test light, volt meter, and amp meter.
Chris
/ Trailer Brake Help #8
Do the trailer brakes activate when you pull the break away pin? Not sure if that will help but it would be another bit of information.
/ Trailer Brake Help #9
We chased this down on my neighbors trailer by using a volt meter at the magnets and working towards the truck to find where the issue was..Often grounds are the problem, that's a fairly easy check. We found that the connectors at the magnets were lightly corroded and a ground was iffy.
His was like yours power everywhere but at the brakes...We ended up replacing the 7 pin connector and the breakaway battery for good measure.
Thanks for the advice guys. I'll start down the line on the trailer after work tomorrow and see what I come up with.
/ Trailer Brake Help #11
Put a ground jumper wire from the truck frame to the trailer frame and try it. Booster cables would work.
/ Trailer Brake Help #12
Are the grounds the same on the Dodge and the Ford ? Has a wire got pinched ? Good to see you around .
/ Trailer Brake Help #13
I found two fuses blown on my '09 with similar issues.
If you need a manual for your truck try this:
Ford F-35 Owners Manuals - JustGiveMeTheDamnManual.com
After running new wires from the trailer plug to the trailer and bypassing the breakaway, the controller went from reading "no connection" to "short." Very confusing, but the frustrating ordeal has finally come to an end. While I was changing out the water pump yesterday, my FIL stuck his finger into the truck's plug socket and noticed that one of the posts moved a tad. Yep, the trailer brake post. While putting enough straight pressure on it, the post would actually slide back flush. I'm really glad that's over...it was making my head hurt.
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A65563)
2004 International...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
2023 Wolverine DM-13-72W Mulcher, Skidsteer Mount (A62679)
2023 Wolverine...
MISC PALLET OF FITTINGS (A65643)
MISC PALLET OF...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
