M7060 HDC12 New Owner, or recent shopper info needed
/ M7060 HDC12 New Owner, or recent shopper info needed #1
tflt
Member
N/Y
Kubota M7060HDC12, kubota L4300 DT, John Deere X500
Hi Team, I'm a Kubota fan, no doubt, I own an L series and love it. I recently decided to add an M7060HDC 12 to the fleet. The machine suits my needs perfectly, fit and finish are what we expect from Kubota. The issue is that I have demoed 3 NEW machines, as well as an 8560, and it appears they all have the same issue. When applying the brakes initially, and during operation the pedal will bottom out on the floor board. It feels just like when you were a kid, in your first new, old, chevy, you remember, the one that needed the master cylinder replaced. You can pump them right back up, but the initial activation of the pedal, sporadically, drops to the floor. One dealer said they needed to be bled, did so but the problem persisted, 2 other dealers are actively seeking answers. The machines have all been sitting idle all winter, that is apparent, the first one was dead as a doornail the first time I went to see it. The issue has been documented, and I am awaiting a definitive answer about what could be causing this issue, I am ready to pull the trigger but am leery of an impending problem. I was wondering if anyone could add some insight. I feed round bales on a feed row that requires operating on hills near my barn, the issue was unnerving when backing down a slope with a bale in the hugger and having the brake pedal drop to the floor. I was able to pump them back up, but it's just not right. What's going on?? For the record, I test drove a New Holland T4.75 today, (I know Blasphemy), and have to say it's a solid #2, the lower output hydraulic pump is apparent in loader operation, but not a deal breaker! I don't need a sunroof, but it is cool, as is the kid seat.
/ M7060 HDC12 New Owner, or recent shopper info needed #2
I do not have direct experience with that size Kubota. However, "that ain't right." Absolutely make them get to the bottom of it before you buy. My first guess is the guy was right and it does need to be bled (only more so than they have done so far.) Another thought is that many of the larger tractors nowadays use what is called an "equalizer" intended to manage pressures right versus left between the two braking systems. On MF at least the very first thing many dealers do is defeat the equalizer. Unlike the do-gooders trying to protect us from ourselves, many dealers understand that if we press on a wheel brake "we really mean it" and want some immediate action. What is wild is that you have seen this issue on all 3 demo tractors. All the more reason to insist on a Kubota explanation, not just the dealer making it work.
/ M7060 HDC12 New Owner, or recent shopper info needed #3
This is the first I've heard of this problem with Kubotas.
JD owners have complained about a very similar problem on here. I've read a couple lengthy threads about it. But I don't recall a solution. Most times they were being told that's "normal". I'm with you,,,,, that is NOT normal. And would be unacceptable to me for sure!!!! I'm in steep timber a LOT. I'd freak out if I had to pump the brakes every time I wanted to stop just short of going into a ravine!!!! :eek:
Hopefully there will be resolution. Please post the results either way.
As for NH, they were definitely in the running for me when I bought my M9540. The biggest turnoff to me was their 3rd function on the FEL is a diverter. They don't offer true 3rd function, or didn't then anyway. I use that feature a lot and didn't want to settle for a diverter setup from a manufacturer. I do like their tractors though.
JWR, the equalizer was apparently ruled out early on. The issue has presented itself at multiple dealers now. I was present while a Kubota rep, (not the dealer), was inspecting the first machine and clearly knew there was an issue. He was explaining what is in "spec" and what is not, this was clearly way out of spec. I walked away from that machine due to the poor response from that particular dealer. I was never a fan, but they are geographically closest, and offered a good price, but I have no confidence in them. I have a dealer a little farther away, and a little higher in price, who I have had several good experiences with and would like to use for the sale, but his machines show the very same issue! The owner observed it the first time it occurred in his machine during a demo, his response was immediate in bleeding the brakes but called to let me know that there is still an issue, he advised me that in going through multiple M series machines on his lot after seeing this occur it is happening across the board. He states he'll be working with Kubota to resolve this a quickly as possible, I hope so because I've really looked at the competition and honestly nothing is equal. I think the New Holland T4.75, (I demoed one) is runner up for the 7060, but not a very close runner up.
/ M7060 HDC12 New Owner, or recent shopper info needed #5
Like Richard, I've never heard of it on a Kubota, our 8540 works great and has to as like Richard, we operate on some steep slopes. For me there is no wiggle room, either it works perfectly or I don't use it.
The T4 I drove had the factory 3rd function, (which I need), installed. The machine was nice, the hydraulics too slow, and the visibility from the cab not great for loader work. the controls were ok, but seemed less refined than kubotas. They were "clunky" and not very smooth to operate. So, after reading through pages of owner experiences, (various leaks, difficult to service), I would call it a distant runner up, for me. (only my opinion)
I'm rooting for Kubota to come through!
I agree, and use a 7040 quite often with no issue, this is a 60 series issue.
/ M7060 HDC12 New Owner, or recent shopper info needed #8
I didn't realize brakes was one of the changes on the 60 Series.
I'm not sure they changed, I'm just pointing out I have quite a few hours on a 7040 with no issues.
Interesting point though RRR, can anyone advise if there was a brake revision for the 60 series?
I know the front axle engages when the brakes are applied while traveling in 2 wheel drive, giving you 4 wheel braking.
/ M7060 HDC12 New Owner, or recent shopper info needed #10
You said "I know the front axle engages when the brakes are applied while traveling in 2 wheel drive, giving you 4 wheel braking." I wonder if that is a related factor ? I never knew of a tractor with that feature (e.g. triggering front wheel drive line when brakes are applied.) Just my ignorance no doubt but that one is new on me. A quick test of course would be to run it around some in 4wd and then try the brakes where the automatic shift is not required. Regardless, Kubota has to find and fix this one big time. Sounds like a recall coming considering the number of them and the observations of the rep.
/ M7060 HDC12 New Owner, or recent shopper info needed #11
This is all news to me. I know my dealer has sold several, I'll try to remember to ask him tomorrow if he's seen the same.
PS, this sounds like a good tool to negotiate a better price on a 8560 or M5-088. :)
/ M7060 HDC12 New Owner, or recent shopper info needed #12
I like how you think Derek..... :)
/ M7060 HDC12 New Owner, or recent shopper info needed #13
I own a M7060 HDC12 and have never had this feeling with the pedals. As far as JD, tractors as old as the last 1960s have had that in brakes. I will say despite that feeling, the brakes have never failed to stop the tractor.
That's encouraging! What year was yours manufactured? I am wondering if it could be from sitting for a long time on the lots. I know the one I want was delivered in sept 15 to the dealer, and the first one I looked at, at another dealer could have been there since 2014, the salesman was ambiguous about delivery date. I really like the 7060, I'm just concerned about the brakes.
That's a great idea, I wish I thought of trying the brakes in 4WD, I figured it was a solenoid run by the brake pedal, linked to the electronic shift on the fly, but maybe not.
/ M7060 HDC12 New Owner, or recent shopper info needed #16
Late 2014 purchased in January 2015.
/ M7060 HDC12 New Owner, or recent shopper info needed #17
Meant to add that I'm working with the rep on some other equipment so I will ask him if they have had any issues. They are a good sized dealer and move a lot of equipment.
Thanks! so would you say your brake pedals are consistent. When you apply them do they seem to always "feel" the same? This issue will allow the pedal to drop to the floor, and than if you pump it, the pedal will come back up to where it should be. It won't drop to the floor every time either, but often. Thanks for your insight, I think the 7060 perfect for me I'm worried about what I'm seeing with the brakes though.
/ M7060 HDC12 New Owner, or recent shopper info needed #19
Mine are consistent and firm. Very little movement in the pedals at all. Unless they have changed something since this one I suspect air in the lines.
Where are you located?
I'm in Central NY, Cortland Co. I know the suspect machines have been out on the lot for at least one full winter, if not more, and hope it's something like air in the lines. The problem is that multiple dealers figured air in the lines, bled them and state the issue persists. Don't get me wrong I'm not bashing! I'm rooting for Kubota!
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
UNUSED WOLVERINE PALLET FORK FRAME (A64281)
UNUSED WOLVERINE...
