Stick welding aluminum
/ Stick welding aluminum #1
mikefromnh
Gold Member
Figured it was a good thing for a newbie to try.
Here's the broken wheelchair ramp. Probably about 20 broken or cracked welds. And the hobart 4043 stick rods that I got on amazon for $15 delivered.
It took 2 and half rods to fix the ramp. So about four bucks. Saved over $150 vs having to replace it :) as this ramp was beginning to be not safe.
/ Stick welding aluminum #3
You found out... I did too, even though I own a TIG and MIG with a spool gun, I needed to stitch something outside so I got some too, in my case some ESAB and tried the SMAW route. It was ugly for one, and two it wasn't structurally strong at all. Mine looked like bird droppings and cracked too. I wound up stuffing the trailer in the shop door and doing it right with the MIG and spool gun. lesson learned.
SMAW with alum rod might be okay for filling in a hole but thats about it.
Yeah it's not ideal. But better than nothing.
105 amps
Before I wire brushed the flux off. The mess to the left is the original weld
/ Stick welding aluminum #6
I have done some pretty decent welds on aluminum with a stick welder. You just have to follow the rod a lot faster and not be distracted. Ed
Up to 110 with better results
/ Stick welding aluminum #8
...and you most likely used a ferrous metal wire brush (which makes it even worse). Always wire brush an aluminum pre prep joint with a stainless steel wire brush no matter what process you use....
Yep, guilty as charged :(
Not really set up with the right stuff for aluminum. But the ramp is back in service... Jumped on it a few time and no broken welds. Much more solid then it was.
/ Stick welding aluminum #10
Your a better man than me. They say to make sure your stainless wire brush has never brushed anything but aluminum too.
/ Stick welding aluminum #11
Couple things I learned. Just before welding use a stainless steel wire brush on the weld zone. And a little preheat helps too.
It's interesting you have it labeled 0.0 arc force. This was the first time I was wondering if I could have benefited from adjustable arc force.
A couple more pics
117 amps
/ Stick welding aluminum #13
Personally I think a spool gun does a much better job.
/ Stick welding aluminum #14
I'm thinking the OP was just stating that for a small aluminum repair, aluminum stick is a cheap good fix. As far as aluminum mig welding goes, everybody that can mig weld steel, can mig weld aluminum, and it does come out a lot better, but to stick weld aluminum, you have to be good at stick welding, and then it's a challenge. Then you have the cost set up for aluminum mig welding.
I've welded a small aluminum project before with 1/8 stick on 1/4" thick angle bar, worked ok I thought, the welds was strong and lasted, I think I set my DC welder on DC straight, on the stop and starts, I cut the end of the rod for a better arc re-start.
/ Stick welding aluminum #15
Just before welding use a stainless steel wire brush on the weld zone. And a little preheat helps too..... Yep.
I keep my stainless wire brush in the consumable drawer under my Lincoln TIG machine. Always handy.Right with my TIG finger and doeskin gloves.
/ Stick welding aluminum #17
This was playing with the pulse when I first got my Lincoln V350-Pro welder.
/ Stick welding aluminum #18
I've done some repair work with stick before. Actually, the first time I did it I was surprised how well it worked and how strong it turned out. However, unless it is something remote in the field, my spoolgun is the go to and that's after a good brushing with my stainless steel wire brush that hangs on the wall dedicated for aluminum.
/ Stick welding aluminum #19
I have used them in the past.
The learning curve is straight up!
KEEP the rods in a container! If you lay the rods down they will become wet in minutes!
/ Stick welding aluminum #20
That's no joke. I did a repair and left the remaining rods in the plastic container they came in. Next morning I had some overpriced short pieces of aluminum wire.
235/85R16 Tire (A68134)
235/85R16 Tire...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2023 Unused Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
2023 Unused Del...
2017 Chevrolet Silverado 2500HD 4x4 Crew Cab Reading Service Truck (A68183)
2017 Chevrolet...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2016 Chevrolet Tahoe SUV (A66738)
2016 Chevrolet...
