Stick welding aluminum
   / Stick welding aluminum #11
Couple things I learned. Just before welding use a stainless steel wire brush on the weld zone. And a little preheat helps too.
It's interesting you have it labeled 0.0 arc force. This was the first time I was wondering if I could have benefited from adjustable arc force.
A couple more pics
117 amps
   / Stick welding aluminum #13
Personally I think a spool gun does a much better job.
   / Stick welding aluminum #14
I'm thinking the OP was just stating that for a small aluminum repair, aluminum stick is a cheap good fix. As far as aluminum mig welding goes, everybody that can mig weld steel, can mig weld aluminum, and it does come out a lot better, but to stick weld aluminum, you have to be good at stick welding, and then it's a challenge. Then you have the cost set up for aluminum mig welding.
I've welded a small aluminum project before with 1/8 stick on 1/4" thick angle bar, worked ok I thought, the welds was strong and lasted, I think I set my DC welder on DC straight, on the stop and starts, I cut the end of the rod for a better arc re-start.
   / Stick welding aluminum #15
Just before welding use a stainless steel wire brush on the weld zone. And a little preheat helps too..... Yep.
I keep my stainless wire brush in the consumable drawer under my Lincoln TIG machine. Always handy.Right with my TIG finger and doeskin gloves.
   / Stick welding aluminum #17
This was playing with the pulse when I first got my Lincoln V350-Pro welder.
   / Stick welding aluminum #18
I've done some repair work with stick before. Actually, the first time I did it I was surprised how well it worked and how strong it turned out. However, unless it is something remote in the field, my spoolgun is the go to and that's after a good brushing with my stainless steel wire brush that hangs on the wall dedicated for aluminum.
   / Stick welding aluminum #19
I have used them in the past.
The learning curve is straight up!
KEEP the rods in a container! If you lay the rods down they will become wet in minutes!
   / Stick welding aluminum #20
That's no joke. I did a repair and left the remaining rods in the plastic container they came in. Next morning I had some overpriced short pieces of aluminum wire.
2023 John Deere 6155M MFWD Tractor (A53342)
2023 John Deere...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2017 KOMATSU  D61 PXI-24 (A52472)
2017 KOMATSU D61...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
2002 International 4300 Cab and Chassis Truck, VIN # 1HTMMAAP02H548742 (A51572)
2002 International...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
