30hp Chinese Bulldozer Parts
   / 30hp Chinese Bulldozer Parts #71
Amazon.com: NEW 12V 11T CW STARTER FITS RHINO 3320 3324 4134 HERCULES 2282 2284 TRACTOR QD1247A: Automotive
   / 30hp Chinese Bulldozer Parts #72
   / 30hp Chinese Bulldozer Parts #73
I have a two cylinder 30 hp diesel. I checked the armature with an ohm meter and one burned copper plate shorts to all the others. The number on the starter is QD1247A. It is a 1.5 kw 12v starter.
Your two cylinder 30 HP diesel engine has a brand name (not the same as the dozer), and it has a model and serial number as well. These are usually found on a nameplate on the engine itself. This would be very helpful info.
Many of the Jinma tractors use the same engines and components as the Yuchai/Guilin dozers do, so you can check all of the Jinma dealers as well.
Another place you can try is Keno Tractor.
   / 30hp Chinese Bulldozer Parts #77
the starter that you showed me.
Your posts are not going to help any future readers searching for a starter, like you found this old (2009) thread.
Need some details please.
   / 30hp Chinese Bulldozer Parts #78
Um, I didn't show you any. Like what was stated in the above post, someone else with a Rino two cylinder diesel dozer would really appreciate in knowing what the model number is of the starter that you purchased. Was it the gear reduction type or the standard OEM type?
   / 30hp Chinese Bulldozer Parts #79
it is a gear reduction starter 12v 11t cw starter that fits a rino 3320. It is supposed to be a lot stronger than the OEM starter.
   / 30hp Chinese Bulldozer Parts #80
here is the name again.Rareelectrical NEW 12V 11T CW STARTER RHINO 3320 3324 4134 HERCULES 2282 2284 TRACTOR QD1247A. I hope this helps. John
Informational Lot - Shipping (A56438)
Informational Lot...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2024 Timpte 40ft Hopper (A56438)
2024 Timpte 40ft...
2006 Chevrolet Express 3500 Cargo Van (A59230)
2006 Chevrolet...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
