30hp Chinese Bulldozer Parts
   / 30hp Chinese Bulldozer Parts #61
Not sure about having 2 hydraulic pumps. To the left of the transmission theres a hydraulic cylinder that connects to a lever for forward and reverse operation. 2 lines come off that and go to the hydraulic selector switch. The other 2 lines come from the right side switches which control the 6-way blade and pto lift. I hooked up the lines the way I thought they were and the switch is working to engage forward and it starts to go forward. I put it in reverse the switch moves the lever to reverse but the dozer dont move. I must have 2 lines crossed. The lines off the forward and reverse switch are top bottom left and right. Thanks
   / 30hp Chinese Bulldozer Parts #62
Okay, sorry 'bout that. Had you mistaken for another party.
I know the setup you have now. Check your adjustment (throw) for the reverse portion of the quadrant. It should be equal to the forward throw.
   / 30hp Chinese Bulldozer Parts #64
Ok still no reverse. The throw is the same forward and reverse. I think I have 2 lines crossed. Is there any diagrams out there that shows where the lines go. Thanks
   / 30hp Chinese Bulldozer Parts #65
Sorry, I don't have that information, but if you are getting equal throw in reverse then you may have internal problems.
   / 30hp Chinese Bulldozer Parts #66
Thanks bob. The only thing that I wasnt sure of when bolting the transmission to the gear box was the 3 spacers. I put them between the 2 mating plates. Do you know if thats correct. Maybe they dont go between and its pushing the shaft forward too much. But they are only about 3/8" thick. Thanks
   / 30hp Chinese Bulldozer Parts #67
Apologize for the late reply. Not sure what "spacers" and "mating plates" you are referring to. A picture would help if possible.
   / 30hp Chinese Bulldozer Parts #69
I need a new starter QD1247A for a rino dozer
How do you know you need a new starter?
What engine do you have? Sounds like a weird number to me.
Try Circle G Tractor and Affordable Tractor.
   / 30hp Chinese Bulldozer Parts #70
I have a two cylinder 30 hp diesel. I checked the armature with an ohm meter and one burned copper plate shorts to all the others. The number on the starter is QD1247A. It is a 1.5 kw 12v starter.
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51243)
2024 AGT...
John Deere Bale Spear (A50515)
John Deere Bale...
1270 (A50490)
1270 (A50490)
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
