Lincoln Arc 225
/ Lincoln Arc 225 #1
12Bravo
Gold Member
Eastern TN
Kioti CK2610 TLB, Gill 5' Scraper Blade (Tilt/Angle)
Did a search and not a lot of information on this welder. Lincoln Arc 225
What are your thoughts on this machine. I'm not made of money, so get this for only $xxxx.00 amount isn't going to work.
I am looking for a basic Arc welder for around what this machine cost, $300+/-. Never TIG welded so not sure I would be interested in that, but if there is an inverter welder that is worthy of mention around same price, I will listen.
What I am going to be using this for. Farm implement repair fabrications, such as ballast box, bucket hooks and other tie off hooks/pins. Angle iron, square, and round tubing for "Stuff".
No expert nor am I going to be building trailers and stuff. Just simple stuff for around the house.
/ Lincoln Arc 225 #2
The Lincoln 225 is a good welder for what you are wanting to do. I owned one years ago and it worked great for the type of things your doing.
/ Lincoln Arc 225
How would it compare to the Everlast 140ST?
/ Lincoln Arc 225 #4
Doesn't the Lincoln Arc 225 take 15-amp jumps? If so, that would drive me crazy!:confused2:
I'd contact Mark with Everlast and see what kind of a deal he can make you on a PowerArc 200ST.
/ Lincoln Arc 225
Just PM him? Looking at the information on that welder, looks good except the extra $100. But if it's worth it, I think I could swing a bit more, depends on the "Deal" he can make.
I'm tired of thinking "Wish I had a welder for this or that", it's getting annoying now that I could actually use a welder!
/ Lincoln Arc 225 #6
I've had three Everlast welders to date. For the money they have a very impressive arc:cool2:. Here is what the PowerArc 200ST can do with an LN-25 wire feeder with self shielded wire, and 6010.
/ Lincoln Arc 225 #7
This is my original buzz box I used for 35 years. Notice the 10 - 20 amp jumps between tapped settings. It never drove ME crazy because I didn't know any better!
Plus 1 ^^ on recommendation to consider Everlast.
Terry
/ Lincoln Arc 225 #9
I'm still WORKING on my hobbyist badge.....
/ Lincoln Arc 225 #10
Bought the old tombstone Lincoln fresh out of high school. Shop at Dinnerbell Foods had a special price of 99 dollars. Asked the foreman if I could get one. Sure if I had the money. Still have it in the shop today. Even had a helmet.
/ Lincoln Arc 225 #11
That is what I would do too. I have the Everlast PA160, I sold my Lincoln AC 225 to a member here. I have not regretted doing that.
/ Lincoln Arc 225 #12
I use a 225 tombstone and am thinking about one of the Everlast welders. I don't know which one I'd like the best. What I do know is that my Lincoln's paid for. :)
/ Lincoln Arc 225 #13
The AC225 is/was a very popular machine but with machines like Everlast's at around the same price, you'd be a fool not to consider one. The Everlast will weld so much nicer and be a lot easier to use as well which is the number one consideration when choosing a machine. Then you add higher duty cycle, more choice of rods because of DC current, ability to add a TIG torch for not much money, small enough to easily move around, uses less power, etc.
/ Lincoln Arc 225 #14
If the op was in our area and wanted a nice used Lincoln AC welder for a very affordable price I would consider this
https://spokane.craigslist.org/tls/5386655031.html
If going for a new welder-
agree with checking out a new Everlast, with a 5 year warranty, dc welding, easy to add tig , and portability what's not to like.
/ Lincoln Arc 225 #17
Anyone except my Miller Dynasty 300. ;)
/ Lincoln Arc 225
Well, got an E-mail from Mark.
I think I will go with the PowerArc 200ST if I can get the funding in order, waiting for a reply e-mail from him and I might be a new owner of a Everlast Power Arc 200ST!
/ Lincoln Arc 225
Just ordered the PowerArc 200ST, should be here in 5-6 Business days!
Now I need to get some steel and some rods to play with and practice. I already have a hood and other tools from my little cheap welder.
What rods should I start with? Just for practice on angle iron.
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
Brake Drums (A62613)
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
1990 FRUEHAUF 53' DRY VAN TRAILER (A65054)
1990 FRUEHAUF 53'...
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
