Lincoln Arc 225
/ Lincoln Arc 225 #1
12Bravo
Gold Member
Eastern TN
Kioti CK2610 TLB, Gill 5' Scraper Blade (Tilt/Angle)
Did a search and not a lot of information on this welder. Lincoln Arc 225
What are your thoughts on this machine. I'm not made of money, so get this for only $xxxx.00 amount isn't going to work.
I am looking for a basic Arc welder for around what this machine cost, $300+/-. Never TIG welded so not sure I would be interested in that, but if there is an inverter welder that is worthy of mention around same price, I will listen.
What I am going to be using this for. Farm implement repair fabrications, such as ballast box, bucket hooks and other tie off hooks/pins. Angle iron, square, and round tubing for "Stuff".
No expert nor am I going to be building trailers and stuff. Just simple stuff for around the house.
/ Lincoln Arc 225 #2
The Lincoln 225 is a good welder for what you are wanting to do. I owned one years ago and it worked great for the type of things your doing.
/ Lincoln Arc 225
How would it compare to the Everlast 140ST?
/ Lincoln Arc 225 #4
Doesn't the Lincoln Arc 225 take 15-amp jumps? If so, that would drive me crazy!:confused2:
I'd contact Mark with Everlast and see what kind of a deal he can make you on a PowerArc 200ST.
/ Lincoln Arc 225
Just PM him? Looking at the information on that welder, looks good except the extra $100. But if it's worth it, I think I could swing a bit more, depends on the "Deal" he can make.
I'm tired of thinking "Wish I had a welder for this or that", it's getting annoying now that I could actually use a welder!
/ Lincoln Arc 225 #6
I've had three Everlast welders to date. For the money they have a very impressive arc:cool2:. Here is what the PowerArc 200ST can do with an LN-25 wire feeder with self shielded wire, and 6010.
/ Lincoln Arc 225 #7
This is my original buzz box I used for 35 years. Notice the 10 - 20 amp jumps between tapped settings. It never drove ME crazy because I didn't know any better!
Plus 1 ^^ on recommendation to consider Everlast.
Terry
/ Lincoln Arc 225 #9
I'm still WORKING on my hobbyist badge.....
/ Lincoln Arc 225 #10
Bought the old tombstone Lincoln fresh out of high school. Shop at Dinnerbell Foods had a special price of 99 dollars. Asked the foreman if I could get one. Sure if I had the money. Still have it in the shop today. Even had a helmet.
/ Lincoln Arc 225 #11
That is what I would do too. I have the Everlast PA160, I sold my Lincoln AC 225 to a member here. I have not regretted doing that.
/ Lincoln Arc 225 #12
I use a 225 tombstone and am thinking about one of the Everlast welders. I don't know which one I'd like the best. What I do know is that my Lincoln's paid for. :)
/ Lincoln Arc 225 #13
The AC225 is/was a very popular machine but with machines like Everlast's at around the same price, you'd be a fool not to consider one. The Everlast will weld so much nicer and be a lot easier to use as well which is the number one consideration when choosing a machine. Then you add higher duty cycle, more choice of rods because of DC current, ability to add a TIG torch for not much money, small enough to easily move around, uses less power, etc.
/ Lincoln Arc 225 #14
If the op was in our area and wanted a nice used Lincoln AC welder for a very affordable price I would consider this
https://spokane.craigslist.org/tls/5386655031.html
If going for a new welder-
agree with checking out a new Everlast, with a 5 year warranty, dc welding, easy to add tig , and portability what's not to like.
/ Lincoln Arc 225 #17
Anyone except my Miller Dynasty 300. ;)
/ Lincoln Arc 225
Well, got an E-mail from Mark.
I think I will go with the PowerArc 200ST if I can get the funding in order, waiting for a reply e-mail from him and I might be a new owner of a Everlast Power Arc 200ST!
/ Lincoln Arc 225
Just ordered the PowerArc 200ST, should be here in 5-6 Business days!
Now I need to get some steel and some rods to play with and practice. I already have a hood and other tools from my little cheap welder.
What rods should I start with? Just for practice on angle iron.
2019 TAKEUCHI TL12V2 SKID STEER (A64279)
2019 TAKEUCHI...
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
2025 Swict 60in. Bucket Skid Steer Attachment (A61572)
2025 Swict 60in...
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2019 ASV RT-25...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
