PTO safety
/ PTO safety #11
Sloppy/complacency is one thing. Ignorance is another... and yes, I was ignorant. The very first time I mounted my slasher onto my brand spankin' new tractor (see left).
LORD! I cursed a blue streak trying to align the shaft onto the PTO. Finally it slid on, or I thought it did... I didn't know about the locking position. Fortunately, when it did come away from the PTO, the shaft just nose-dived into the ground and left a rut. I dug the dirt out and figured out what I'd done wrong.
Later I discovered that there is not a standard in shaft locking configurations. Some have 'buttons' that need to be depressed, others have a collar that needs to be pulled back. There are probably more variations that I've yet to encounter.
I did the same exact thing first day I had my tractor with the finish mower. Mine just wedged in the pto cover and broke of one of the chains that keep the guard from spinning. Oops lesson learned, luckily no more mishaps since. Ive grew up mowing with my dads tractor but it was a dedicated mower and we never removed it so was never taught the proper way to hook up the pto shaft.
/ PTO safety #12
I don't like it, I have a problem with the nut backing out, then you have the nut and bolt as flying projectiles and then the shaft comes off.
I believe you should get a Nylock nut and tighten it good and tight I think it should be tight enough to squeeze the shaft with the yoke and thus remove any chance for wobble and wear .
/ PTO safety #13
We always used pto pins on shafts that had the hole, they have a rounded spring bail that holds them in place.
/ PTO safety #14
I have one where the collar twists to unlock, once released, springs twisted back and locks.
I always give them a final tug to make sure they don't pull off.
:thumbsup:
/ PTO safety #15
Go naked around PTOs. Best advice. Just don't get an erection and get it caught.
Yeah, I hate those pull back collar kinds of PTOs. Had my sales person change mine out to a push button one. But even the push button one is harder to work than the push button one I have on my shredder/chipper. I glues a button onto the fairly recessed one he supplied for my cutter.
Ralph
/ PTO safety #16
Ralph
G'day hmmm don't think I could stand close enough to worry about that AND it may upset the neighbours:laughing::laughing:
Jon
/ PTO safety #17
I have a very stout Fimco mower from the early seventies that I had purchased with a tractor. The pto shaft button/rod was removed and they had been using a bolt with nut and lock washer.
I used it like that for twenty some years. Finally I yanked that u joint assembly off and put on a new one. Apparently the ol boy I bought it from must have ruined the unit and wallored it out so he just put in a bolt. I never had a problem with it but was kicking myself when I fixed it right.. Now I am that ol boy;-)
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
2017 Nissan Pathfinder SUV (A59231)
2017 Nissan...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
2019 Ram 1500 Crew Cab Pickup Truck (A59230)
2019 Ram 1500 Crew...
2013 Infiniti JX35 v SUV (A59231)
2013 Infiniti JX35...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
