New electrical panel question
/ New electrical panel question #1
erda
Alberta
Kubota B2601
So, completely renovating and adding on to a 1940s farm house.
My question is, what size of service should I go for? 100amp or 200 amp? I've had two different electricians tell me two different things...
Thanks.
/ New electrical panel question #2
Go with the 200 amp. Extra circuits for future needs are cheap compared to upgrading the panel. The cost difference of a 100 amp service panel and a 200 amp panel are negligible.
/ New electrical panel question #3
Thanks.
The answer depends on what your heating, cooking etc. with.. It is pretty easy to figure it up and not be subjective about it. Probably even web sites to help. Bottom line and I won't get into specifics, you should find a website to do that, if your using a lot of electric high amp draw applicances (HW Heater, Oven, Furnace etc.) you need 200 amp. If you house is mostly gas and you use mostly gas (HW Heater, Oven, Furnace) you could get away with 100. I would probably never do 100, go at least 150 just in case you decide to change any of those things. In fact, I would say 200 just to give you options later..
I have changed two homes from 100 to 200 Amp.
/ New electrical panel question #6
The cost may be negligable or not.. probably only has a 100 amp line going to the house, which means all new run or weather head everything up to 200 amp. That is not cheap upward of 1k - 3k depending on how long his service and a lot of other factors. Yes, the panel costs and labor to switch panel would be negligable difference.
Erda, Is your service under ground or above ground attaching up above the roof? If it isn't underground I agree with going 200 amp hands down. Still have to change out the weather head but it wouldn't be as expensive as all new underground runs.
/ New electrical panel question #8
I tend to agree with all the posts trending to 200 amp. Since your on a tractor forum you may weld, have a shop etc. However, I don't know your financial situation and you may be trying to get it done at as low a cost as possible. If you can afford the 200 amp estimate, by all means do that for all the reasons mentioned.
/ New electrical panel question #9
Maybe a different meter socket and bigger wire into the house too I think. When I sold my first house the home inspector actually measured the wire gauge and determined it was undersized for my 200a service. Some inspectors do, some don't.
/ New electrical panel question #10
You probably don't need 200. But if I could get it now at about the same price I would. Cost of panel isn't much.
My house clamps at 9 amps when nothing big is running. I have air handler, electric dryer/water heater and well, and 100 amp panel.
Chances are you will never need a 200. If you have any thought of putting a big shop, then it wouldn't hurt.
/ New electrical panel question #11
/ New electrical panel question #12
^^^ Learn something everyday... thanks for the link!
/ New electrical panel question #13
Thanks.
200. It's a lot cheaper to do it now than do it later. The labor is a wash for either so you're only looking at the a little up charge for the parts which is insignificant when compared to adding capacity later on. Even if you don't need all the capacity now, you likely will later on. One thing is for sure, you won't be using any less later on.
/ New electrical panel question #14
I was thinking just the opposite... we do use significantly less now... than 5 years ago or 25 years ago.
The utilities are complaining because usage is down overall... maybe it is all the LED and more efficient appliances?
/ New electrical panel question #15
It sort of goes without saying you have to upgrade everything including wire to the house when upgrading to 200 amp. and that is why the price is most likely quite different between the two quotes. No licensed electrician would put a 200 amp box on a 100 Amp wire to the house. Not even a good unlicensed handyman would do that. Only a complete hack that doesn't know about electricity would do that. OP do not allow a hack to put a 200 amp box in your house without also sizing the feed to the house for 200 amp.
/ New electrical panel question #16
While we may use less power for lighting and such we tend to need more circuits than we did years ago i.e. more circuit breakers in the panel. The number of breakers in the panel is tied to the overall amp rating of that panel. A 100 amp panel will have space for fewer breakers than a 200 amp panel will. The buss bars etc. will be smaller too. Like tractors, more tractor is usually better than less tractor.
/ New electrical panel question #17
200 amp and maybe more if you plan to run power to a barn and use a welder or other power tools. Question though is what size wire is feeding your existing panel. Will it handle 200 amp?
I did my own upgrade on my house form 100 to 200 (Allowed in Colorado with permit) I left the existing panel in place and mounted the new one beside it and fed through a 100 amp breaker in the new one. I also recommend the Square D withthe transfer switch built in (they did not have that when I did my install) as you can get breakers almost anywhere.
/ New electrical panel question #18
Complete hack or a total cheapskate looking to save a few pennies with salvaged equipment, wire and other parts (describes my first house). Back to the OP though I think the difference in opinion was in whether to opt for 200a vs. staying with 100a. Utilities around here will now inspect the service entrance for code before they plug the meter back in. Perhaps there are some "sparkies" out there that would attempt a panel change with live wires...not for me...
/ New electrical panel question #19
This is actually not a bad option for the OP if they don't have the money to upgrade the feed coming into the house. It would be safe and allow them to upgrade the line later to the new panel with 200amp feed.
/ New electrical panel question #20
Also, if you need a new panel, you will probbaly also need new service entrance cable (due to age and possible cracked insulation)
On the transfer switch, Square D makes an interlock kit that they sell separately, (but it switches over your whole panel, not just part of it).
Aaron Z
