The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!!
/ The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #81
Good advice from Eric.
The NX6010 and JD4066 tractors are both large compact tractors with similar weights and the loader lift capacities are over 2,500 pounds.
I don't think you can really go wrong with either grapple.
Click this for the full comparison chart.
Does the Single Lid Wicked Root Grapples for Compact Tractors in each size really weigh exactly the same as the Dual Lid Wicked Root Grapples for Compact Tractors in each size category?
for example both 72's weigh the same.
That's what I've been told. Those lids on the singles are pretty beefy.
Travis
Single Lid 54" Compact
66" Single Lid Compact
/ The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #84
I cannot wait, also customer service at ea is top notch
/ The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #86
He stole my picture!
:D
The grapple also works for getting birds out of the yard.
:D
Awesome pics! Tractors, kids and wildlife. What more could we ask for?
Travis
/ The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #91
Travis;
Is the opening 42 1/2" on both dual and single lid versions?
/ The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #94
/ The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #97
Called Travis this afternoon and ordered the 73" single lid Wicked Grapple for Utility tractors.
EA is really great to deal with and Ted needs to give Travis a big raise for being a true EA Product Champion!
Looking forward to delivery of my grapple. It will augment my 84" HD dual lid grapple installed on out New Holland TL100A. The new EA Grapple will be used exclusively on our LS XR4046HC tractor for brush and limbs from tree trimming.
I look forward to weighing in on the "single lid vs. dual lid" disputed on several TBN threads. :)
I was originally going with the 55" but, decided on the 73" for additional $145 so it will cover my tires if I need to actually grapple some roots.
This will obviously eliminate me from weighing in on the "narrower is better" disputes but, so what? ;-)
Thanks Rick!
Man, too bad you'll not be able to settle the "single vs. dual" dispute AND the "narrower is better" dispute.
But..........if it were settled, what could we all argue about? :laughing:
It was a pleasure helping you. If you're used to the 84" on the smaller tractor, you should know what you're getting into with the 73".
We look forward to seeing pics.
Drop some on the Wicked Grapple photo thread if you get a chance. That goes for everyone else too!
Travis
/ The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #99
Thanks Travis. My 84" grapple is very HD and weights almost 1000# so it virtually full time on my NH TL100A with Bush Hog on back for added counterbalance.
Anxious to receive my new grapple.
/ The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #100
My 73" Single Lid Wicked Grapple arrived yesterday. I put pallet forks on my LS XR4046HC and unloaded from the back of the SE Freight Lines truck. Had SE loaded the grapple pallet 180 degrees turned, I could have just dropped the pallet forks and hooked onto the grapple SSQA and picked up grapple and pallet. No problem, trick was at my place for less than 10 minutes. I like SE FL as I get same driver for every delivery. He knows where to go so, little time is wasted.
Installed my QD's and had an operating grapple in about 15 minutes. Ready to get busy this morning.
2019 John Deere 460E Articulated Dump Truck (A60352)
2019 John Deere...
2013 Lincoln MKZ Sedan (A61569)
2013 Lincoln MKZ...
2013 MACK CHU (PINNACLE) (A60736)
2013 MACK CHU...
Cat CB24B (A60462)
Cat CB24B (A60462)
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2025 Swict 78in. Bucket Skid Steer Attachment (A61567)
2025 Swict 78in...
