An easily visible hydraulic fluid level indicator. Shows the level of the fluid in the "tank" ?
It is a fluid level indicator but not for the hydraulic reservoir.
I have no idea. I'm still trying to figure out how the operator reaches the rear remote levers.![]()
Why not just use some control cable with a ball end in a clear tube?
Rig the other end to the rod, the sleeve to the cylinder and voila! You have a remote length gauge. Bike shops should have all the cable you need.
If I'm using my BB, and I want to put downward pressure on the right side, how am I going to do that?
With this device in place the most downward pressure I can exert is "float". Without the device I can forcefuuly extend the tilt cylinder and use the weight of the BB to increase downward pressure.
