How to Grapple without a Grapple - Pictures please
/ How to Grapple without a Grapple - Pictures please
I have used pallet forks with no clamp for moving trees. It works pretty well as long as you are in a big open space. If you brush another tree it tends to drag the load off where a grapple can keep on going. The pallet forks no doubt are light years ahead of the bucket for moving brush and logs.
This is sort of my dilemma now. Do I just go get some strap on pallet forks and continue to pile on my burnables manually, or do I get a QA set up and have more capacity with forks (I don't move pallets around hardly at all), or do I invest in the grapple (my dream but not sure I can justify the expense)?
/ How to Grapple without a Grapple - Pictures please #13
I like it Xfax! That's a lot of evergreens... did you light that pile off? Can't imagine the flame if you did. :eek:
Yep, eastern red cedar, unfortunately I didn't get pictures of that one. :(
/ How to Grapple without a Grapple - Pictures please #14
Sorry, no pictures at this time. I've considered building a "push-off" for my pallet forks because the loader on my B9200 doesn't lift high enough for easily dumping a load of limbs into a truck with sideboards. Probably would need to use a scissor type linkage with a cylinder(s) to actuate. Anyone know of such a device that I could look at?
/ How to Grapple without a Grapple - Pictures please #15
An image search didn't turn up much. Do some research on scissor lift and build one sideways. :D
/ How to Grapple without a Grapple - Pictures please #16
That's a good example. I designed several vertical scissor lifts in my days on the job and they're really not that difficult.
I'm thinking a forked push-off attachment that would bolt into the bucket might be an approach.
/ How to Grapple without a Grapple - Pictures please #17
An image search didn't turn up much. Do some research on scissor lift and build one sideways. :D <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=456718"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=456719"/>
I was thinking more along these lines, sideways of course. image-1458145367.jpg
/ How to Grapple without a Grapple - Pictures please #18
I have had all three. I currently have SSQA forks and a grapple. SSQA forks are far superior to clamp on forks in every aspect. If you have a QA loader I highly recommend avoiding clamp on forks like the plague. A grapple is far superior to forks for moving logs and brush, but $$$. If you have the ability to fabricate you could build a claw for pallet forks. This would way better than pallet forks alone. The downside is you still need third function hydraulics.
/ How to Grapple without a Grapple - Pictures please #19
I thought of another thing that might be easier. Use the idea of the high dump bucket or roll-out bucket, but with forks, not a bucket. There would be fewer moving parts. High Dump
Another style, same principle.
/ How to Grapple without a Grapple - Pictures please #20
Xfax, are those cedar trees cut off with a chainsaw ? ;)
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2017 John Deere 6120E (A53317)
2017 John Deere...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2011 CIRCLE M  35 GOOSENECK (A60736)
2011 CIRCLE M 35...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
