How to Grapple without a Grapple - Pictures please
   / How to Grapple without a Grapple - Pictures please
I have used pallet forks with no clamp for moving trees. It works pretty well as long as you are in a big open space. If you brush another tree it tends to drag the load off where a grapple can keep on going. The pallet forks no doubt are light years ahead of the bucket for moving brush and logs.
This is sort of my dilemma now. Do I just go get some strap on pallet forks and continue to pile on my burnables manually, or do I get a QA set up and have more capacity with forks (I don't move pallets around hardly at all), or do I invest in the grapple (my dream but not sure I can justify the expense)?
   / How to Grapple without a Grapple - Pictures please #13
I like it Xfax! That's a lot of evergreens... did you light that pile off? Can't imagine the flame if you did. :eek:
Yep, eastern red cedar, unfortunately I didn't get pictures of that one. :(
   / How to Grapple without a Grapple - Pictures please #14
Sorry, no pictures at this time. I've considered building a "push-off" for my pallet forks because the loader on my B9200 doesn't lift high enough for easily dumping a load of limbs into a truck with sideboards. Probably would need to use a scissor type linkage with a cylinder(s) to actuate. Anyone know of such a device that I could look at?
   / How to Grapple without a Grapple - Pictures please #15
An image search didn't turn up much. Do some research on scissor lift and build one sideways. :D
   / How to Grapple without a Grapple - Pictures please #16
That's a good example. I designed several vertical scissor lifts in my days on the job and they're really not that difficult.
I'm thinking a forked push-off attachment that would bolt into the bucket might be an approach.
   / How to Grapple without a Grapple - Pictures please #17
An image search didn't turn up much. Do some research on scissor lift and build one sideways. :D <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=456718"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=456719"/>
I was thinking more along these lines, sideways of course. image-1458145367.jpg
   / How to Grapple without a Grapple - Pictures please #18
I have had all three. I currently have SSQA forks and a grapple. SSQA forks are far superior to clamp on forks in every aspect. If you have a QA loader I highly recommend avoiding clamp on forks like the plague. A grapple is far superior to forks for moving logs and brush, but $$$. If you have the ability to fabricate you could build a claw for pallet forks. This would way better than pallet forks alone. The downside is you still need third function hydraulics.
   / How to Grapple without a Grapple - Pictures please #19
I thought of another thing that might be easier. Use the idea of the high dump bucket or roll-out bucket, but with forks, not a bucket. There would be fewer moving parts. High Dump
Another style, same principle.
   / How to Grapple without a Grapple - Pictures please #20
Xfax, are those cedar trees cut off with a chainsaw ? ;)
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2022 Polaris Ranger 4x4 Utility Cart (A55851)
2022 Polaris...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A55851)
1996 JLG Commander...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
1974 Ford F600 Grain Truck (A55315)
1974 Ford F600...
