Hydraulic vs Manual Scrape blade
/ Hydraulic vs Manual Scrape blade #1
bbd 25
Member
North GA
KUBOTA 6800
I just bought a Kubota m6800 (rops). Needing attachments now 😁. Got my 7' bush hog. Want to buy land pride grading plane.
My question is whether or not a hydraulic scraper blade is worth the extra $$$$. Also 7' or 8'? Hydraulic or not? Be using it for drive ways, ditching and snow.
Thank you
/ Hydraulic vs Manual Scrape blade #2
I just bought a Kubota m6800 (rops). Needing attachments now ��. Got my 7' bush hog. Want to buy land pride grading plane.
Thank you
Go get on your tractor, drive it for 50' and stop. Get off and go to the back of the tractor. Now do that every 50'- 500' for as far as you have to go. Only you know if you like stopping and going all the time as well as getting on-off the tractor all the time. :rolleyes:
While you can get by with manual adjustments, (lots of people do) hydraulic is the way to go. Of course then you also need all the controls on the tractor to control all those hydraulics. :eek:
Here is the perfect blade for you. An RBT3596, either manual adjusters or hydraulic, just a good blade all around. Be sure to get it with skid shoes. If you decide that you want to go hydraulic, let me know, I can probably save you a few hundred and supply you with welded cylinders instead of the tie rod units that LP provides.
/ Hydraulic vs Manual Scrape blade #3
I used to use a blade for clearing snow. It was manual - having hydraulic would have made life way easier and faster!!! I learned quickly to plan my snow clearing such that I minimized the number of times I'd have to get off to swing the blade angle. Not sure how big your tractor is so can't comment on size. I don't use the blade as much now but I think I will add a cylinder to it one day.
E.
/ Hydraulic vs Manual Scrape blade #4
Hydraulic is the way to go. As the old saying goes, don't worry, its only money. Ken Sweet
/ Hydraulic vs Manual Scrape blade #5
HYD is the way to go. Size to be determined by how wide your tires are and will the blade cover the tracks when angled. I use an 8' with HYD tilt, angle and offset, My old blades were all manual and after finally buying a HYD blade all I can say is why didn't I do it sooner as it makes the job a easy and faster. Well worth the extra expense if you have a lot of blade work to do and especially if the ground you need to work isn't all level. Remember that weight is your friend when selecting a blade
/ Hydraulic vs Manual Scrape blade #6
I put a hydraulic cylinder on my LandPride back blade, it was nice. Of course I recently sold it & bought a blower.
I have a manual truck plow on the loader. I'm off to go pick up a hydraulic truck plow I got at an auction today. $150, but was listed as needing work. From the pictures it was just messed up mounting brackets, which will get replaced with SSQA anyway.
Hydraulics are worth it if you do a decent amount of work.
Thanks guys... At double the price I was expecting more people against it; but it seems it does make life that much easier. I'll look into buying one when I get the $ up. Thank you
/ Hydraulic vs Manual Scrape blade #8
None of these guys mentioned money. It's easier to say "hydraulic" when it's not your money. Buy what you can afford and justify. Rear blades have been used for decades without hydraulics. If this is an attachment that you are going to use 3 or 4 hours a year you might want to think hard about hydraulics. If you plan to use it at least a few days a month, then hydraulics are better justified.
If money is no object to you, knock yourself out. :)
/ Hydraulic vs Manual Scrape blade #9
Yep. How much use it sees and what type of use would be a big factor in determining it hyd is worth the money
/ Hydraulic vs Manual Scrape blade #10
That was well put. :thumbsup:
/ Hydraulic vs Manual Scrape blade #11
I've got a $75 Rhino blade with all the manual adjustments that I bought at a farm sale. Doesn't bother me a bit to drive by it parked in the machinery lot. Would freak me out if it was a $3000 hydraulic blade........ :eek: :)
/ Hydraulic vs Manual Scrape blade #12
If you can do a little welding and fabrication, you can add a cyl with hoses and ends on a conventional blade for way less than $200. Ken Sweet
/ Hydraulic vs Manual Scrape blade #14
Very good point Ken!!!!
/ Hydraulic vs Manual Scrape blade #15
I don't know about "way less than $200" for a blade that size, a quality cylinder is going to cost that. Then hoses, steel, pins, etc. Then the time.
Sure, you can save alot of money doing it yourself. But I think a "way less than $200" budget is way too low.
/ Hydraulic vs Manual Scrape blade #16
Not low at all, one 3 x 8 Hyd cyl $89, two 6 ft long 1/2 hyd hoses with 1/2 npt threads $44, 2 1/2" male pioneer ends $18, two black 1/2" npt street ells $3, pins come free with cylinder. two pieces of scrap steel cut as needed to weld to cyl cost $0, welding rods $4. Any farmer with a shop can do this install 3 hours or less. Total cost $158. Ken Sweet
/ Hydraulic vs Manual Scrape blade #17
Maybe. 3x8 cylinder just seems small. What does landpride use for that blade? And that's certainly not a prince or similar quality cylinder.
Seems odd that they would charge thousands more for $158 of additional parts
/ Hydraulic vs Manual Scrape blade #18
Yes, That would be a high quality cyl and actually a 3x8 is actually overkill. That is the same size we use to raise and lower haybines and wheel disc harrows that weigh 2000-3000 lbs. Because they are so widely used in ag applications, the 3x8 price will be lower than smaller cyls. Hey, the dealers are not in business for their health. lol. Ken Sweet
/ Hydraulic vs Manual Scrape blade #19
Just looked. Landpride uses a 3.5x14 on the 35 series and a 3.5x16 on the rbt40 series.
A 3x8 would be woefully inadequate and you'd be blowing lots of hoses
/ Hydraulic vs Manual Scrape blade #20
Something else that no one has brought up, that Land Pride unit can be purchased with manual adjusters, it does not have to be hydraulic. You only save about $500 above the all hydraulic unit. I would like for someone to show me a non hydraulic option rear blade that is the quality of any rear blade that either has or has the factory option of all 3 adjustments to be hydraulic. None that I know of. Because none of the manual only adjustable blades are heavy duty, medium duty at best.
We are comparing apples and oranges here. Yes the hydraulic blades are expensive, aren't all truly good-heavy duty implements costly? :rolleyes: You don't go and purchase a 1200lb box blade for $800.
Ken, you actually recommend using black pipe for hydraulic 90s? :eek: I know that they have been used for a long time, doesn't make it right or safe. :no: Also the problem with using a short stroke cylinder is that it makes the adjustments very touchy. There is a reason for using the 14" & 16" stroke cylinders.
Just my :2cents: ;)
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2020 INTERNATIONAL...
JOHN DEERE HX14 ROTARY MOWER, 3PT (A64278)
JOHN DEERE HX14...
2023 CHEVROLET 3500HD TRUCK (A63276)
2023 CHEVROLET...
