SSQA fork build
/ SSQA fork build #61
Does your welder run off single or 3 phase?
Yes. :laughing:
It's old enough they didn't cripple the single phase performance and it's still rated to 425A on 240v/1ph :hot: but the duty cycle is down around 10% where it'd be more like 30 or 40% on 3ph. I think they call it auto-line or some such. When I got it I pulled the pigtail the original owner had (3ph) and ran SOOJ to a 50A plug and never looked back.
I run .035 solid with c25, but I do have a bottle of 98/2 that someday I want to play around with for pulsed spray. I haven't done spray since I had the thermal arc Fabricator 250 before this machine, but I have run pulsed on a similar power supply before (Access 300).
/ SSQA fork build #62
What's the benefits of 3 phase welders?
There's 30% more electrical potential with 3ph vs 1ph. So you get more power with less overall current consumption. Similar to how a 1hp motor draws half the amperage on twice the voltage when you hook it up to 240v - only with 3ph, your voltage is still 240, but you have extra power capacity available.
If you don't have 3ph power already, it's not cost effective to bring it in for nearly all circumstances.
Older transformer based 3ph welders might not work at all on single phase, and that's why they're virtually worthless after they're removed from industrial service. You need to be sure a welder you get can be run on single phase if you're going to try to buy one.
/ SSQA fork build #63
I have 3ph service. It's 208y. I was just curious as to what the benefits were but I see that you get less current - per leg - which gives you a better duty cycle and if course smaller ga wire if you need to add receptacles or cords.
Maybe I should hunt for a used 3ph welder since I won't be using it anywhere else. I have a small mig /fcaw for that.
/ SSQA fork build #64
I wish I could get 3ph! There's a TON of used machines out there that most people have trouble giving away because they don't know how to power them. Welders, grinders, mills, lathes - lots of stuff with motors too big to run off a phase converter for less than the price of a decent car - so it goes for scrap price. It's tragic.
/ SSQA fork build
I'm really curios too what the finished set of forks weigh, looks like the specs show about 855 lbs at 19.6" from the pins. May just be a good reason to upgrade the tractor to match the forks. :) Very nice work.
I do like the way you think, country!
/ SSQA fork build
/ SSQA fork build #67
Do you think it would have been better to use a flat bar at the top like a real forklift instead of the round bar?
/ SSQA fork build
I looked at a forklift with adjustable forks, and they had a substructure that was guided by 'V' strips that I guess were some sort of bearing material, maybe bronze. The upper flat bar is there but the fork doesn't rest on it until a load is applied. I did see a huge forklift on a construction site that was using the round bar and an Acme screw system for adjustment. I'm just trying to keep it as simple as possible. I figure if the hydraulic adjust is a total flop, disconnect the cylinder and do it by hand and chalk it up as a loss. In the mean time, I'm having a blast building this thing.
/ SSQA fork build #69
You can also use electric 12v actuators instead of hydraulic. They are cheaper but still strong and you could have 2 of them with a 2 way switch for easy use.
/ SSQA fork build
I knew that the welds were going to warp the side plates so up on the press they go and I got them back to decent flatness. Ready to start assembly.
I also weighed up all the parts and the total is 450 lbs. About the same as my grapple.
/ SSQA fork build #72
You just need to trade in for a bigger tractor that's more suited for the forks. :laughing:
/ SSQA fork build #73
If you decide they are to much for your tractor, I'll come take them off your hands. :) if they work half as good as they look you should really like them.
/ SSQA fork build #74
It would be really sweet to have hydraulic adjustable width, side shift, and side to side tilt.
/ SSQA fork build #75
Oh boy, here we go. :) Bigger and Better. By the time we are finished , he will have to get a bigger tractor. :)
/ SSQA fork build #76
Not a bad idea. I always wanted to build something using those.
I already have for a power SSQA. http://www.tractorbynet.com/forums/customization/321704-linear-actuator-power-ssqa.html
V1 uses those cheap $60 ones rated to about 200lbs. V2 used a $150 one rated to 500lbs or so. If I ever do a V3 for another tractor I would use the cheap ones again.
I've also used those cheap ones for some chicken coop doors.
I wouldn't use the cheap ones for the forks. To slow & wimpy. The 500lbs ones might work though. You could even side shift as you ran the 2 switches in the right direction.
/ SSQA fork build #77
Assuming he already has third function hydraulics for a grapple wouldn't hydraulic cylinders be cheaper?
/ SSQA fork build
Very nice post! You got the gears in my head turning now.
/ SSQA fork build
You've got me thinking about the hydraulic motor option.
https://www.surpluscenter.com/Hydra...E-255040F3DD22AAAA-HYDRAULIC-MOTOR-9-8287.axd $80 and a couple acme threaded rods.
I remember seeing in a catalog somewhere a RH/LH acme rod that would be the perfect set up. Heck, now that I'm thinking about it, it would be pretty easy to make your own. A length of RH and a length of LH and couple the two together and the synchronizing issue is solved. Hook the motor to a 90 degree speed reducer and drive it from the center. Well, I now know what my fall back plan is!
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63688)
FRESHLY...
MOULINE 260 BAGEL SLICER (A64281)
MOULINE 260 BAGEL...
EXMARK TURF TRACER S-SERIES WALK BEHIND LAWN MOWER (A64280)
EXMARK TURF TRACER...
Caterpillar 236/246/248 Skid Loader Parts and Service Manuals (A63117)
Caterpillar...
Caterpillar 966C Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 966C...
