wcampbell47
I re-read your wish list of things you want to do. I bought my first 21 hp Kubota thinking that would be all the tractor I needed. 4 wheel drive, front loader, pto and 3 point hitch. I did a lot of cleanup, mowing and gardening. I bought a 32 hp with same equipment to do more serious work - like moving truck loads of material and grading driveways. I wanted the tractor to be light because I work on a lot of yards. Both were B models. Recently I traded the B3200 for an L3901. A little more weight but a lot more tractor. I am still on a lot of lawns with no detrimental effect. I remove the FEL to do mowing. Makes the tractor more maneuverable and lighter. The L model is way better for grading roads and drives than either of the B models. The thing is I never thought I would need a bigger tractor. I have not regretted moving up in power - just regret I did not buy the L model to begin with. But then I did not know how big my tasks would become. I still have my 21 hp B7510 and use it to mow with a mid mount mower. I say this is my lawn mower on steroids. I moan and groan every time I think I need to remove the MMM or put it back on. Getting too old to do that often so I turn to the L39 with a 72" 3 point mower. The L39 handles my 60" brush cutter much better than the B3200. If it is in the cards to do some septic system work in the future I doubt that the B model will be up to the task or will struggle. My B3200 handled a 4 foot concrete culvert, but just barely. The L handles them much more easily. The B7510 is 48" wide, the B3200 was 54" wide and the L3901 is 58" wide. I have no regrets on being 4" inches wider. The L3901 is less than 400 lbs heavier than a B3350. Just thought I would give some real world experiences with different sized tractors. Don't get me wrong, I did some serious work with the B models - but the L model is very sweet. It is 4WD, HST and I have added the cruise control option for mowing. The operator's station is much more comfortable than the B's and I can stay on the tractor for 5 or 6 hours without getting to beat up. Strongly suggest you sit on different models and compare creature comfort as well as mechanical attributes.
