Building my bridge crane
/ Building my bridge crane #81
So that's where our tax money is going!
I worked for a very large marine construction company. All of our work is hard bid, lowest bid gets the work. What we do with our equipment / material is our business. ;)
/ Building my bridge crane #82
You bet it is. Contractor salvage. Low bid is low bid, the government the best price they were after.
Got the knee braces on.
3' long each, 3x3x1/4" tube on 45 degrees
All done except paint now
/ Building my bridge crane #86
Looks good, I plan on one in mine in the next year or so, still setting up the basic shop itself.
/ Building my bridge crane #87
That looks real good!
Here's what happened to mine. Tenants are using it to hold a roll of bubble wrap. It's 22 feet, on rails 100 feet long. Kind of a waste but it pays the rent.
449530d1449378387-building-my-bridge-crane-bridge-crane-jpg
Yea, could probably hang that bubble wrap from the conduit and be fine:D
Which I had electric hoists but man are they pricy. If I used it all the time maybe I could justify it. But once or twice a month....
Here are some shots after paint. I didn't paint the rails since they were reused, they were kinda greasy and didn't feel like cleaning it all off. Just need to stensil the capacity on it and call it done
/ Building my bridge crane #89
Looks professional. Nice job !
/ Building my bridge crane #90
Looks even better. Stencil the capacity on the fish plate with a black diamond border. With an electric hoist you're inclined to add a whole system to spool the wire as it travels which could be the most difficult part of the whole job.
/ Building my bridge crane #91
Not really. Run a piece of 3/16s aircraft cable parallel to the tracks (but as tight to the ceiling as possible) and get a bunch of cheap little pulleys, fasten your power cable to the pulleys every 2' or so. Do the same thing for the trolley but run it along the top if the Ibeam and fasten it every foot.
Aaron Z
/ Building my bridge crane #92
Aaron Z
That's pretty much how I have the power running to my crane. The power for the 1-ton hoist comes from one end of the shop. The power for the travel winch comes from the other end of the shop. I started out with small snatch blocks, but they didn't last long, I've been replacing them with snap clips.
/ Building my bridge crane #93
Makes sense, not much weight on them and its not like they are holding much weight or moving down the cable all day.
Aaron Z
/ Building my bridge crane #94
My span beam can set in one place for months at a time. I've checked the snap clips, they show no wear at all.
/ Building my bridge crane #95
Uh-huh. Its sure to be strong enuf for the cycles it will see. "Ultimate" though is a neat concept if you dont fixate on it breaking, but instead sustaining damage at each stress riser when it is loaded. That small portion of material has seen its ultimate and undergone plastic strain. The beam is now bent a tiny bit, facilitated by the stress riser at way under its ultimate strength. That micro damage is the basis of fatigue.
Last year i designed a leaf spring fatigue testbench. in order to get theoretically infinite life, it is designed to get stress levels of 1/10th the yield strength of standard construction steel. There are some micro initiation points in the welds but as you say, these micro cracks will be contained, and not propagate with this stress level. Using high strength steel is of no use: the fatigue life is the same. Thats why high reach demolition excavators are so costly to use: with heavy shears that twist the boom when cutting, it doesnt take long before it cracks.
/ Building my bridge crane #96
1,000 cycles being a fairly small number,,, to overload that hoist 1,000 times you have to overload it every 3 days for 10 years. No vacations. Hoist always dead-center in the middle. Shield Arc yours might take a little longer.
Thats a lot of projects. Better get 'crackin' ! :thumbsup:
/ Building my bridge crane #97
You are saying fatigue life of high strength steel is same as mild steel? You sure? (0:
/ Building my bridge crane #98
Way too general of a statement on fatigue life... One can study particular S-N curves and then factor in heat treatment and surface finishes to better understand fatigue life of various metals.
/ Building my bridge crane #99
Theoretically that is correct, and it works for simple load cases and/or constructions. When the margins get really thin, like the air suspension trailing arm, Ansys and LMS only provide an approximation, which is to be verifed with a test on this spring testbench. Then, the FEA models are adjusted to match the testbench outcome. Sometimes even having the clamping friction a few percent off can make big differences in lifespan of the FEA model...
Anyways, in this case when using pre-used (so probably pre-fatigued, with rust pitting etcetera) steel beams, its pointless to take heat treatment and surface treatments of welds such as shot peening, TIG re-melting the weld toe etcetera, into a FEA model. Its like firing a cannon on a mosquito...
In other words, the most important saying to remember for an FEA engineer is: There is allways a difference between practice and theory... except in theory. :D
/ Building my bridge crane #100
First of all take this info for what you paid for it. Which was nothing. In other words its for discussion only. :rolleyes:
Attached you will find FEA of OPs spliced beam... using tapered and square scab plates. Note hot spots at points of scab plate. With that being said, highest stress is at butt welds between two beams and not at scab plates.
Also I've included approx safety factor at 10,000 lbs with indicated loading... around 1.1. OP should inspect rail at butt weld joint for possible fractures. Proceed at your own risk. Not sure what you are gonna rate this crane at but be careful. Cranes are serious business.
Good day. :cool:
Did you model actual welds and the scab plates spaced apart from the main beam so your FEA program calculates the stresses individually, or did you just "glue" them to the beam, over the full contact surface, so the stress in the scab plate is the same as in the I beam flange ? Watching the stress concentrations in the square scab plate case, i assume the latter...
2015 CASE CX160C EXCAVATOR (A65053)
2015 CASE CX160C...
2022 EZ-GO ELITE...
2006 JOHN DEERE 700J LT CRAWLER DOZER (A65053)
2006 JOHN DEERE...
2006 Ford E-350 Passenger Van (A64194)
2006 Ford E-350...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
