SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,605
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Surely you can design a welded connection to be more failure prone than a bolted. But that isnt the object is it. With welding only possible at edges - and cracks naturally initiating at edges - its a big mistake to ignore the need to blend stiffness gracefully.I agree with the first half of your statement. The weld is correct in this situation. I have used similar welded splices in the past
Bolted and welded connection are useful in different situations. Neither connection is better than the other for all situations.
Bolted connections are a common way to repair cracks in bridge beams.
I have seen many cracked welds in bridges, the only bolted connections that I have seen cracked also had large amounts of section loss from rust.
