Ooklaa; DELETED TO FOCUS ANSWER... But to amswer your question about the logs said:We get logs delivered in 8'-12' lengths ranging from 10"- 30+", and stacked up to 5-6 logs or 8'-10' high, and we use our B2320 with forks chained to our bucket to unstack them and stage them for cutting and splitting. I use a log jack or peavey to roll the logs onto the forks and while we do have to shorten or even halve a few of the biggest ones occasionally, it isn't really very often.
We DO have loaded rear tires and a really heavy ballast box as counter balance, but nonetheless we never feel like our loader or tractor are undersized for any of the work we do one our 8+ acre hilly wooded property.
As we always say, YMMV!
Ooklaa,
What can you do with the debris? Are you allowed to burn or will you have to pay for disposal of the debris?
I also found this for grapple attachments. Small size 48 inches they are used on mini skid steer. But their is no specs on weight, was gonna call the company to ask just havent had enough time.
How would you attach it to your loader?
It is a mini skid steer quick attach that is about 24 inches wide, Tractor QA is 44" wide.I assume its a quick attachment.------------------
You can say that again! I have been periodically burning debris from about an acre of clearing at my place for the past couple of years. I have the proper permits but I'm suppose to keep the pile less than 3ft by 3ft by 4ft. Hard to do... if the fire dept comes by, I will argue I thought the permit meant the flame needs to be less the 3x3x4Ooklaa,
Being able to burn surely lowers the cost of clean up.
You can say that again! I have been periodically burning debris from about an acre of clearing at my place for the past couple of years. I have the proper permits but I'm suppose to keep the pile less than 3ft by 3ft by 4ft. Hard to do... if the fire dept comes by, I will argue I thought the permit meant the flame needs to be less the 3x3x4![]()
That reminds me of my "Dead Tree On Fire", post: http://www.tractorbynet.com/forums/projects/313222-burn.html#post3787344--------------------------
Last time I burned the piles were about 50x 40x 12' high. It warmed up the whole area pretty good. Still small compared to some larger fields with huge burn piles.
Yep, measured with a rolling distance measuring wheel, like this one.Xfaxman,
From 150' away if radiant heat started the tree that is impressive. My burns are in the middle of plowed fields and are always the responsibility of the property owners. I don't need the liability risks. I keep my equipment away from fires too as it is easy to burn through air filters and get the ash in the engines.
The live tree next to it also had a dead branch smoldering. The Fire Chief said it happens a lot.
Those cedar trees get pretty hot pretty quick when set alight. I call them Gasoline Trees. They seem to burn with about the same volatility as gasoline. Even the green ones burn pretty well.
