BX23 Won't Start
/ BX23 Won't Start #1
dboz
Danville,Ia
Kunitz bs 23
Bs 23 will not start. Have power and it will start if you jump the starter. Think it is the lever switch. How do I check that for sure?
/ BX23 Won't Start #2
This is for a BX25, I expect a 23 will be similar, but may not be the same.
From the wiring diagram there are the following things in the starter circuit.
Slow blow 50 amp fuse (or fusible link) in main cable from starter main terminal to fuse block and main switch, (OFF/ON/GLOW/START switch), PTO switch, HST Neutral switch, solenoid. Give the PTO and HST switches a workout!
/ BX23 Won't Start #3
Check to see there is no dirt/debris on the selector lever... it should be easy to move.
Hydro forward/reverse in the middle position too~
/ BX23 Won't Start #4
I agree with 100td. (the fuse). we had one and there was a fuse in the harness at the starter it would blow every 6 months. check that fuse with test light for power
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
2018 BOBCAT E45 EXCAVATOR (A59823)
2018 BOBCAT E45...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2024 JOHN DEERE 325G SKID STEER (A62129)
2024 JOHN DEERE...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
