Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #401
So, I have 3 remotes on my tractor (that I'm in the middle of purchasing). I plan on using one of the rears (at least temporary). I think the NH has the Ag/open-type quick connects. Some of the grapples have 'Flat Face'. What is the difference and what should I be using? Do you guys make your own lines (seems like expensive crimping tools)? And it looks like there are 1/2" & 3/4" that are pretty standard. Guess I need to look up somewhere what the NH TN75A has on it.
Some, a minority, use flat faces connectors. Most of us use the Pioneer style Ag connectors. Ag connectors are less expensive. I haven't used flat faced but I recall they are supposed to be easier to connect under pressure.
I would not try to make your own lines unless you want to invest in some expensive equipment. High pressure hydraulics is not for amateurs. Either have a local hydraulic shop make them or buy pre made lengths with end fittings from surplus supply or similar interweb dealer.
A grapple can be run with 1/4 line, a 3/8" line is more than adequate and anything bigger is excess.
/ Grappling fun - A Picture Thread.... #402
The second one looks cool. Independent controls is awesome. Do you have multiple buttons on your joystick?
All two lid grapples are independent. The cylinders are plumbed in parallel so the lid with the least resistance to movement will move first. When it contacts something the other lid will move until it contacts something, then same hydraulic pressure is applied to both cylinders.
For the picture both lids were up, I opened the pressure release valve for the aux hydraulic connectors and pushed on the lid to start it moving, gravity took over and it closed.
It's been a little while since I've posted pics in this thread, but if you look back through some of them, you'll see some very distinct situations where the wider grapple can be advantageous. Specifically, when carrying firewood or carrying multiple stumps at a time. I do honestly feel that there are more advantages to a wider grapple than there are to a 48" grapple when dealing with larger CUT's or small ag sized tractors. I personally would most definitely NOT purchase a 48" grapple on a tractor as large as a TN75. The advantage of the 48" are more apparent on smaller tractors with less capability. Keep in mind, you can also buy less than 48" grapples, but you don't see the guys with the 48" grapples selling them for narrower versions. You will find that for the most part, people will recommend what they have. I do love my 64" OBG2 and would not sell it or trade it in if I upgraded to a larger tractor.
We know Island Tractor is a very die hard 48" grapple user and that works very well for all his needs. Just keep in mind that not many of us have had the luxury of using many different grapples, so take our opinion's with a grain of salt.
I've given up tirelessly defending why I believe the wider grapple is better for general use, although I still feel that way.
I'll try to post some more pics as it's been a while!
/ Grappling fun - A Picture Thread.... #404
I do honestly feel that there are more advantages to a wider grapple than there are to a 48" grapple when dealing with larger CUT's or small ag sized tractors. I personally would most definitely NOT purchase a 48" grapple on a tractor as large as a TN75. I do love my 64" OBG2 and would not sell it or trade it in if I upgraded to a larger tractor.
Have to agree- once into ag tractor territory a little wider grapple is probably a good idea.
my grapple is around 67 inches wide-, the only major drawback was in the past when I used it digging out stumps.
The day the dozer arrived was the LAST day of using a tractors FEL and wide grapple to remove a stump
had I continued using the FEL/ wide grapple for some of these larger pine trees (not sure the FEL would have survived):eek:
obligatory grapple/stump shot or two :)
Newest use for grapple - unloading 1200# square hay bales from trailer and then stacking them in the barn
Here are a few more pics to hopefully get this picture thread back on track :D
This is perhaps the best "alternative use" of a grapple I have put into practice so far.
I needed to drill some post holes for some 9X9 white oak timbers I was using as posts for a retaining wall. The retaining wall was being built on the opposite side of a fence, which I could not gain access to with the tractor. What I did was, pinch the mounting bracket to my hydraulic auger with the mini ex bucket/thumb, and then using my tractors hydraulic outlets, parked my tractor close enough to the fence to where I could hold the auger with the mini ex, and run the hydraulics using the tractor. My father was on the tractor running the remotes, and I was on the mini ex lowering the auger to drill the holes. It worked better than I could have imagined, and saved a WHOLE LOT OF WORK!
/ Grappling fun - A Picture Thread.... #407
So, are the connectors typically 3/8" Pioneer-Ag or 1/2"?
/ Grappling fun - A Picture Thread.... #408
Flat face aren't easier to connect under pressure, if anything they're worse.
What they do offer is an easier to clean interface.
/ Grappling fun - A Picture Thread.... #409
1/2" quick connects are more common as tractor rear remotes and FEL hydraulics are usually 1/2". Of course you can use various adapters to go up or down a size from the hose.
My dealer set me up with 1/2 hose from rear remote to grapple on my first tractor but I'd use 3/8 hose with 1/2" connectors if I did it again. 1/2 hose is too stiff and harder to make turns with as needed in back and under the operator station. If you look closely at grapples and 4n1 cylinders, the last short section of hose from the manufacturer is often 1/4 inch so that means anything bigger from rear remote or diverter is not making any difference in flow. The trade off with larger hose size is therefore stiffness and abrasion resistance verses flexibility.
/ Grappling fun - A Picture Thread.... #411
Very clever. :thumbsup:
Too bad you didn't have my Versahandler. ;)
/ Grappling fun - A Picture Thread.... #413
I'm so jealous! Those things look like such fun, and I can't have one because all I have is a little Kubota BX 25!����
OH YES YOU CAN!!!
Everything Attachments Compact Wicked Root Grapple 50"
Here's a review. The JD 1025R is very similar to the BX.
"Have had about 2 weeks now. The grapple is great. Picks up chunks of concrete and tree brush, works great. The grapple is well built works great on my JD 1025R. It is a real back saver on the farm."
I'm so jealous! Those things look like such fun, and I can't have one because all I have is a little Kubota BX 25!dde22dde23
Sure you can!
/ Grappling fun - A Picture Thread.... #415
I wouldn't hesitate to put a small lightweight grapple on a BX25. The issue would be getting a grapple with pin mount because you won't be able to afford the weight of a SSQA adapter. Also, converting your standard bucket to a bucket grapple is way better than no grapple and the cost and weight penalty are each a fraction of what a true grapple costs.
/ Grappling fun - A Picture Thread.... #417
We do offer our 50" grapple with the BX pin mount. Not great for switching, but at least there's only 3 pins. Travis
I think switching a pin mount implement on a subcompact would be duck soup so long as you had a reasonably flat area to do it. A crowbar to make small adjustments and perhaps an extra pin that has been beveled to a point like a steelworker's wrench to help line up the holes would make it a ten
minute job. I use such a tapered pin to mount my backhoe bucket. Just start the pin when the holes are roughly in line and hammer it in to force the bucket or grapple mount into alignment. Then just push that pin out with the real pin. Easy.
/ Grappling fun - A Picture Thread.... #418
I have to disagree. A 6ft 1/2" ID hose connected to 2ft of 1/4" will have a higher flow rate than 8ft of 1/4" hose (assuming the same head pressure). At least that's what the laminar flow physics says.
/ Grappling fun - A Picture Thread.... #420
2013 Chevrolet Cruze Sedan (A66738)
2013 Chevrolet...
Unused 2021 UM Ripper Bedder 432 Toolbar Subsoiler Tractor Attachment (A66734)
Unused 2021 UM...
2007 JLG 450AJ SERIES II SKYPOWER TELESCOPIC BOOM (A65056)
2007 JLG 450AJ...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2025 48in Forks and Frame w/ Bale Spear Attachment (A66734)
2025 48in Forks...
2014 JOHN DEERE 700K LGP CRAWLER DOZER (A65056)
2014 JOHN DEERE...
