Regular Auto Oil in ATV
/ Regular Auto Oil in ATV #1
DrRod
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
Greetings,
While pursuing my ill-fated oil change [see drain plug thread] I actually looked something up in the manual. It seems to say that using any 10W-40 oil is fine. But I recall the dealer and others saying you need to use ATV oil that contains various additives due to the wet clutch. Does anyone use plain old auto engine oil or should I stick with ATV oil? Incidentally, they are a 1999 Honda 450 ES and a 2001 Honda Recon.
/ Regular Auto Oil in ATV #2
They have always said this for motorcycles.
What does it hold? Change it once a year? Throw a good sync oil in.
Not like a truck or bike where you have to do it a few times a year, at least my 4 wheelers. Even on those I go good. Which is a debated topic.
I'd go to 4 wheeler for too.
/ Regular Auto Oil in ATV #4
I would go with any atv type. I go with Mobil one or Amsoil usually cause I can buy it at fleet farm 7 days a week. Though I have run dealer oil. I
I don't get caught up in brands, though I do suspect some are better.
4 wheeler is 3 quarts or less probably. So less then $10. Though I realize easy to spend other people's money and you may need that 10 for something.
I have had times in my life I wanted 10 bucks more.
/ Regular Auto Oil in ATV #5
As long as the oil doesn't have Molybdenum in it, it's fine. (In the right viscosity, of course) You can't use Moly with a wet clutch. Most automotive oils have it.
/ Regular Auto Oil in ATV #6
Why make the effort to find out?
/ Regular Auto Oil in ATV #7
I agree. I use Honda oil. It's only $1 or $2 a quart more expensive than average auto oil. I have to go get an oil filter from them anyway. Peace of mind is worth a lot.
Well, the spec in the manual got me thinking in that direction. Plus you can buy regular oil almost anywhere while ATV oil requires a trip to the dealer and they can be hard to get to given their hours [and they all seem to close on Sunday and Monday].
/ Regular Auto Oil in ATV #9
Run Honda oil in my Rancher ATV. Reason being that the Honda oil is API spec'ed SG. I believe this is the last spec before friction fighters were introduced to passenger vehicles. In this case it is the lack of additives for the wet clutch instead of extra additives.
/ Regular Auto Oil in ATV #10
I agree with others. I run Honda oil in my Honda Foreman 450. You have to use motorcycle oil due to wet clutch.
Hondas are built like tanks. No reason to ruin a fine machine by using the wrong or cheap oil. Good luck! (0:
/ Regular Auto Oil in ATV #11
Greetings,
A lot of people will tell you "oil is oil! Dont believe them! Always use quality oil and filters. The oil should always meet/exceed the minimum requirements of your machine.
Good fortune!
Scott
/ Regular Auto Oil in ATV #12
Ya dealer hours can problem. Fleet Farm has 4 wheeler filters and Amsoil.
I would get some type of bike or 4 wheeler oil, but that is me.
/ Regular Auto Oil in ATV #13
I have an old Suzuki, and the clutch is flaky. I suspect it's because the wrong oil has been used.
Someone mentioned not having Moly in the oil. Is there a way to "clean" the clutches after the wrong oil has been used (probably for years)?
/ Regular Auto Oil in ATV #14
I am by no means an expert with this, but I do know that using oil with Moly is problematic for wet centrifugal clutches.
Maybe try a "flush". Change the oil to the correct oil and add and engine flush product. They make several -- Sea Foam, Royal Purple, mechanic in a bottle. There are several... (don't overfill oil capacity)
Run it for a little while (maybe a half hour) in normal use. Then drain the oil. (and filter if applicable)
Add the correct oil and new filter. Sure can't hurt anything.
/ Regular Auto Oil in ATV #15
That is the clutch, I think, that feels funky. It seems to grip/slip to varying degrees without changing anything. Not trying to derail the original topic, but thanks.
/ Regular Auto Oil in ATV #16
Talked to a mechanic at the dealer and he said -- yes -- there is a difference and you should always use ATV oil. He didn't seem particularly worried about the auto oil currently in the machine. No need to do a flush or even change the filter. just drain and replace with the right stuff and all should be fine. So I've done that, took it out for a ride, and so far so good. Another crisis averted.
/ Regular Auto Oil in ATV #18
Use ATV oil. I own a Honda Shadow Aero and Honda Rincon and always use Honda powersports oil. Im not picking on the origional poster here but why screw around with the lifeblood of an engine? Just use the right oil for the job, it can save you some major headaches and pains later on.
/ Regular Auto Oil in ATV #19
I started with the required specs for the oil and the only JASO MA2 with an API of SM or higher (SN in this case) 10W40 I could find was Motul's 7100 4T 10W40 oil, so that's what I'm running in my 2015 Kawasaki Mule Pro FXT LE.
For the transmission and differential, going again with the specs and verifying from Kawasaki tech support that "LS" or limited slip gear oil isn't required for either the trans or the differential, I found that Motul's Gear 300 75W90 exceeded all the specs, so I went with it.
/ Regular Auto Oil in ATV #20
Rotella T6 5W40 is JASO spec oil, makes it wet clutch friendly.
JASO is all you need to look for on the bottle.
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2016 FORD F-150 (A67714)
2016 FORD F-150...
2005 COMPTANK ACID TRANSPORT TRAILER (A67714)
2005 COMPTANK ACID...
300 GAL WATER TANK (A68842)
300 GAL WATER TANK...
2018 KENWORTH T370 LUBE TRUCK (A65057)
2018 KENWORTH T370...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
