303 oil from TSC
/ 303 oil from TSC #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
anyone got the scoop on the 303 oil ( accell maybee? ) TSC sells. it's about 25$ fro a 5g pail, with the regular traveler utf at 35$ for a 5g pail, and aw32/47 at about 42$ per 5g pail.
i read the 303 and it says it is a utf type oil, meeting most old tractor specs ( curiously lists none of them ).. and only meeting some new tractor specs, though as a general 'hydraulic oil' it will work fine.
I avoided it for utf uses, since I like to see a ford M2C134D spec.. however for a single sump loader application, I've decided to try it.. it is way ceheape rthan plain aw32, and if it has some utf properties.. sounds like it is actually a better oil than aw32.
without listing any specs.. I think it's safe to say it's not applicable for wet brakes or wet clutches.. and newer specs.. etc..
any comments?
soundguy
/ 303 oil from TSC #2
I'll use a quote:
What jobbers are specifically referring
to is product in the market labeled as
meeting John Deere JD-303, JDM-20A,
ョ and Quatrol . They say these specifications
are obsolete. Moreover, they note that even
if a farmer is comfortable using an obsolete
product because he has an old or leaking
tractor, the quality of these products is
highly suspect because it is not being
monitored.
The JD-303 specification was dropped
in the 1970s because it was based on sperm
oil, and sperm oil can no longer be legally
used as a lubricant. And the JDM-20A
specification has been 電efunct since the
early 1990s it was superceded by JDM-
20C.
The longer article from 2004 at http://www.pqiamerica.com/THFReprint.pdf
/ 303 oil from TSC #3
any comments?
soundguy
The 303 is what was factory recommended for the older John Deeres I ran on the farm. Wet brakes, clutches and all. It has a distinctive odor that helps the operator notice a leak quicker than regular hyd oil. Ken Sweet
/ 303 oil from TSC
i'm familiar with the old 303 as I have jd's and yanmar.. but as pointed out before.. the old 303 oil seems to no longer be able to be made.. so I was asking if anyone knew what this new 'version' of the 303 oil may be?
it does not list ANY specs.. not even a jd spec... while i'm sure it's fine as a hyd oil.. it leaves you to wonder what equipment you -could- put it in as a utf.. since it lists no specs at all on the jug??
soundguy
/ 303 oil from TSC #5
Call the maker on the jug. I called them when I had a question about the Travelers UTF and UTF renew. (Only Difference is a seal sweller). The guy that I talked to was really nice and pleasure to talk to. I asked if the agco oil is better then their stuff. He said , Sure, It smells better cause we make that too and add a fragrance. They also make the wally world oil. (No it's not recycled oil) and it's packaged in the USA.
/ 303 oil from TSC
warren if I recall correctly right?
soundguy
/ 303 oil from TSC #7
soundguy
Yeah, warren, who is also coastal.
I called and they said it's was ok to use in my tractor but it's caused brake chatter in my JD 4455. I went back to JD Hy-guard and it went away.
I was hoping it would work at $25 for 5 gal. I'll have to look somewhere else to save some $$$$. It was worth the try.:thumbsup:
/ 303 oil from TSC
oh wow.. I didn't know they did coastal too!
I got some coastal oils from a carquest a few months ago.. on sale.. 1g jugs of utf, and 80w90 and 85/140 gear oils for 9$ each. I loaded up.. got like 3g of each PLUS what I needed for the tractor I was working on..
soundguy
/ 303 oil from TSC #9
soundguy
Thats the way to stock up. I'm always looking for sell.:laughing:
/ 303 oil from TSC
yep.. I got the gear oil.. the utf i could already get cheaper.. but 9$ per gallon gear oil was quite a savings. got oh.. 6gallons for my rowcrop ford I was working on, plus a few more for the next project. that next project just came along and I got enough oil to do it without buying any for the work itself.. though am stocking back up to keep some on the shelf as needed.. etc.
soundguy
/ 303 oil from TSC #11
soundguy
I got gearoil for the rear end of my truck when i changed it a few months back. I got the supertec at WM and i think it was hovering around $10/gal. Beats the price of the quarts at $4 though!!
/ 303 oil from TSC
fer sure.
I'm glad i had a bunch of 9$ gear oil as I serviced my 850 today and used every drop I had!!
soundguy
/ 303 oil from TSC #13
fer sure.
soundguy
I think I read somewhere that you did some bushhoging on the side. If so, I have a ? I need to bid on a job that has about 100 ac of smooth land that needs to be bushhoged once a year. I plan on using a 100hp tractor and a 15ft hog. I want to be competitve in the bidding, so any pointers on a good bid? :thumbsup:
/ 303 oil from TSC
I try not to do any for hire work so that I can stay non comercial. I have however 'helped out' adjacent neighbors to my land and drove over and mowed their pastures for them
if you are looking for a time estimate.. my ~95 hp NH 7610s and a 15' JD 1517 batwing .. I mow in 5th gear on flat clean land and can do 10 ac in about 2 hours of straight mowing.. obstacles add time.. ruts, holes and non cleaned areas add time. SUPER overgrown makes me drop to 4th and so that adds time. I like to clip them at 2' .. if it gets to 3' it's 4th gear..
for price ideas.. take your time guess, then look at local tractor 'for hire' prices. most people hire out by the hour.. look at thier prices and price yours according to what you are trying to do.. ie.. help a person out with a decent price.. or side jhob.. or whatever. that will keep you in line with what is normal in your region for tractor work.
keep in mind for hire work can get sticky with insurance and all.. that's why I will help out.. but rarely like to do cash jobs...don't need the hassles. barter works fine though. I've cleaned pastures up in exchange for good old implements.. and such ;)
/ 303 oil from TSC #15
keep in mind for hire work can get sticky with insurance and all.. that's why I will help out.. but rarely like to do cash jobs...don't need the hassles. bater works fine though. I've cleaned pastures up in exchange for good old implements.. and such ;)
I have seen price ranges of $100 to $150 for a 15ft hog and 100-125 hp tractor. Some say they charge $10 for everyfoot of bushhog a hour. Thanks for the reply.:thumbsup:
/ 303 oil from TSC
sorry it wasn't a straight price like I think you were looking for.. but I just really try to avoid any 'for hire' work. Again.. I don't mind doing a favor for a favor in kind.. or barter deals.. or creative bartering.. and such.. but I like to draw the line on comercial ventures.. especially if roading my tractor to my other farm... my homeowners INS wont pay if I'm doing for hire work.. and I don't want business insurance.. or a cdl.. or any of that jazz.. etc..
soundguy
/ 303 oil from TSC #17
No problem. I was just thinking that IF I burned 5-6 gals of fuel a hour and depreciation/wear on equipment that I might make $50 a hour. :D
2012 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A66736)
2012 Freightliner...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A66734)
2025 BrushFox...
12ton Hydraulic Bottle Jack (A64557)
12ton Hydraulic...
CATERPILLAR 324EL LONG REACH EXCAVATOR (A65053)
CATERPILLAR 324EL...
2016 Mobility Ventures MV-1 Passenger Van (A66736)
2016 Mobility...
2016 CATERPILLAR 289D SKID STEER (A65056)
2016 CATERPILLAR...
