John Deere 301A Reverser issue
   / John Deere 301A Reverser issue #11
If pto operates correctly then damper clutch is not at fault. I'd suggest to check reverser linkage as the linkage has a history of groove pin failure.
   / John Deere 301A Reverser issue #12
Jim, thank you again for the response. The reverser linkage was the first thing I checked and was banking on that being the issue. When I took off the front and back covers of the valve housing I could see that the linkage was intact and moved the clutch control valve smoothly. Unfortunately, I didn't check forward and reverse pressure before I took it apart, so I think that might be the next step I need to do.
   / John Deere 301A Reverser issue #13
Yes a pressure check is needed.
   / John Deere 301A Reverser issue #15
Jim, what type of pressure gage would you recommend? Do you know what size fitting it would need? The bolt has the specs of:
Specification
Weight: 0.02 LBS 0.01 Kg
Thread Size 0.375 IN
TPI (Threads Per Inch) 24
Thread Length 0.360 IN
Length 0.530 IN
Diameter 0.127 IN
Hex Size 0.500 IN
Material 1020
Finish B
Note
   / John Deere 301A Reverser issue #16
300 psi gauge fitting would be 3/8'' 24 threads per inch
   / John Deere 301A Reverser issue #17
Jim I am having a heck of a time finding a fitting that small at the places where I live. Do you know where I can find the right adaptor or fitting?
   / John Deere 301A Reverser issue #18
A good competent hyd supply place such as Surplus Center or Bailey's hyd should have the fitting.
   / John Deere 301A Reverser issue #19
Well Jim I've struck out again. Called Surplus Center and they don't carry anything that small. After looking into it more I need something that is 3/16 NPT Male, which would be a 3/8-24 thread. Bailey's didn't have anything this small either. I wanted to double check I am trying to measure the pressure in the correct place. I am assuming it is #11 in the picture attached. Reverser Clutch Control Valve.JPG
   / John Deere 301A Reverser issue #20
I've never seen a NPT fitting that required an o-ring as shown in parts catalog because the threads on NPT are tapered. I think fitting needs to be orb(o-ring boss)
Kioti DK45 Tractor (A50860)
Kioti DK45 Tractor...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
PETTIBONE B66 EXTENDO (A51222)
PETTIBONE B66...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
