I'm new to the forum and have a tractor issue that has stumped me.
Last week I was using my tractor and noticed that it would go forward but would loose forward motion under load while climbing hills, pushing dirt etc. It had full power in reverse. I got an oil gauge and checked the reverser pressure. With tractor in park, I had 150 lbs in neutral, 150 lbs in reverse, 25 lbs in forward. So I figured I had a bad seal in the forward clutch pack of the reverser. I broke the tractor in two, pulled the forward clutch pack, put in new seals, and rings, put it back together and now...
I have 150lb in neutral, 150lbs in forward... when I shift the reverser to reverse the engine loads down and stops. Mind you the tractor is in PARK. If I put the tractor in a forward gear instead of park and move the reverser lever I get the following: shift to forward I go forward, shift to neutral I for FORWARD, shift to REVERSE I go FORWARD.
So I thought maybe I did something wrong with the clutch pack and it was frozen up, so I broke the tractor apart again. Leaving the forward clutch pack in place I can still turn it by hand with the tractor in PARK, put the tractor in gear and I can still turn it with a little more resistance, so I am assuming the clutch pack is not frozen up like I was afraid of. If I engage the PTO and turn the clutch pack the PTO will turn.
I have the Tech Manual and it shows a Reverser Brake Assembly that I am assuming is in the housing between the forward clutch pack and the transmission, could it be that part?? Any help would be appreciated, I am lost. The reverser is over my head, I'm used to tractors that you just shift forward and reverse. Thanks
