Sand blaster question
/ Sand blaster question #1
crowbar032
Gold Member
Moores Hill, Indiana
MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader, NH LS170 Skid Steer
So I bought an old Coby running gear that I'm currently sanding down so I can paint it. Eventually I'll put a hay bed on it. I have one of those harbor freight 40# gravity sand blasters and it's working surprisingly well. Except for I'm using quite a bit of sand. So far I've used 4 bags of sand and I have the rims left to do. Has anyone found a way to "capture" and re-use the sand or should I just continue to let it fall on the ground. I thought about putting down some plastic then scooping it back up to use again. On the other hand at $7 a bag maybe it's not that big of deal.
/ Sand blaster question #2
Sand blasting cabinets allow you to recover blasting media but you'd need a really big cabinet if you are doing wheels and equipment. I think most folks would just consider sand a consumable.
I thought about a cabinet but like you said, some things just won't fit in it. And then I'd just have one more tool in my garage taking up space.
I kinda figured sand blasting bigger pieces it would be a consumable, but I never expected to go through that much sand.
/ Sand blaster question #4
Since you stated that little gravity blaster works pretty well, what size compressor are you using? Also, what type of sand? Thanks.
I'm using this sand. I had to go with fine as the medium was clogging the nozzle.
Black Diamond Fine Blasting Abrasives - For Life Out Here
The blaster looks something like this.
110 lb. Pressurized Abrasive Blaster
And I'm using an older craftsman compressor something similar below. It does struggle sometimes and I have to wait for it to catch up. I set the blaster at 60 lbs and the compressor runs constantly. I think it would work better with a bigger compressor, but I'm not planning on doing much of this so it's not worth an upgrade. And the sand must be absolutely no question about it powder dry.
Craftsman.com
/ Sand blaster question #6
I have the HF blasting cabinet. It works well for everything I need to blast. The largest thing I've had in mine is steel automotive wheels.
I have also used the HF gravity blaster for larger items (I blasted a single axle trailer frame and refinished it a few years ago) and I did put down a tarp first and reused the media a couple times. The tarp made for an easier cleanup when I finished.
I also use the black diamond media.
/ Sand blaster question #7
I have reused actual sand before by sweeping it up off the concrete where I was doing the job. Just be aware that the media breaks down and becomes less effective because it looses the sharp edges. It also requires sifting to remove whatever you are cleaning from the object such as paint. Basically, I decided it is not worth the trouble.
Hopefully you have some type of respirator. I'm thinking about using some hose and a shop vac to set up a positive pressure hood next time I do some blasting.
/ Sand blaster question #8
Except for I'm using quite a bit of sand. So far I've used 4 bags of sand and I have the rims left to do. Has anyone found a way to "capture" and re-use the sand or am I should I just continue to let it fall on the ground. I thought about putting down some plastic then scooping it back up to use again. On the other hand at $7 a bag maybe it's not that big of deal.
This is what I do when I have a big job. ... About 20 foot square plastic on concrete, edges elevated on 2x4s. Done in the sunshine to prevent dampness. Sweep up, sift thru window screen and re use.
/ Sand blaster question #9
I have some heavy metal screen like door screen only heavier, I sweep and run it through a few times. As other said it breaks down faster than you may think a couple few times thru and it's shot.
I also have a HF cab blaster it is the big version and takes up some space & it all is run off a 7.5HP IR compressor that was a 80gal, $999.00 unit from TSC a few years ago works great can run my HF blast cab 100% and still shuts off & restarts after a few min of blasting.
Be sure to wear good respirator if using cheap sand, the stuff above is OK it is slag so not as much SI in it so not as great of chance at respiratory issues. Glass beads are great at surface prep and cheap sand with high amounts of silicon in it while great surface actually leaves a non stick coating that keeps paint from biting well. It needs cleaned with a phosphate cleaner to remove it and help etch the metal for paint to stick.
M
/ Sand blaster question #10
As spiker said above, Use a good respirator, You may not see the sand but you will see the remnants of it all around your garage on flat surfaces.
There is a mod available for these that might be of interest to some to increase performance.
https://www.youtube.com/watch?v=CgZW2GBvZQs
/ Sand blaster question #11
We blast with a commercial blaster (350# pot) and a 200 cpm compressor. We have played around a little with trying to reclaim the sand, but it's not worth it for us. We use the 35/65 blasting sand with a respirator.
I realize not everyone needs a commercial blaster and the small ones do have their place, but the metering system is nothing more than ball valves and difficult to fine tune. We started out with a light commercial Brut blaster which had the same system. You couldn't keep sand hauled to it fast enough.
We moved up to a commercial blaster which will blast twice as much with half the sand. If you have a lot to blast, you might want to check with your local equipment rental store. You can sometimes rent a big blaster and compressor fairly cheap. It could turn a several day job into a few hour job.
I said "sand" however I was not using true sand (even though the guy at one national home improvement store told me play sand was perfectly fine to use). It was very low silica coal slag I got from Tractor Supply. My family comes from Eastern Kentucky coal mining towns so I'm aware of silicosis aka black lung. I did wear a respirator and I was also doing this outside in fresh air and not in an enclosed area. Nothing is zero risk, but I tried to take precautions and I'm not doing this professionally.
When I finish up my wagon frame, I'm going to put a tarp down and try to "recycle" some of the media and see how it works. As others have stated, it may not be worth the hassle. I just didn't know if it was standard practice. Thanks for the responses.
/ Sand blaster question #13
Just to add one more thing to all of the above. Controlling the amount of sand passing through the hose is very tricky and fluctuates. You will find that a light mist of sand works just as well as a heavy stream.
/ Sand blaster question #14
Two things will help:
1] Do it in the sun so humidity from your compressed air supply flashes off,
2] Have a couple fans blowing at your back so most of the fines are taken away downstream and not captured for reuse.
/ Sand blaster question #15
The sand that hits the project is only about 20% of what comes out of nozzle. Sift the used and reuse it.
/ Sand blaster question #16
If you have a pressure washer, you can add a sand blast kit to it for dustless stripping.
It works quite well, and the sand has to enter the sand blaster from the top part of the nozzel.
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
CARORI 4' FINISH MOWER, 3PT (A64278)
CARORI 4' FINISH...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
HOMEADE 101" X 25' TRI-AXLE FIVE SAFETY HOUSE (A63276)
HOMEADE 101" X 25'...
