Grinding my weld
/ Grinding my weld #1
jel1988
Gold Member
Elliot Lake, ON
2012 Mahindra Max 22, John Deere D120
I'd like to know why my flux core welds grind so easy compared to my mig welds. I like to use mig, the welds are so neet and clean with no spatter. The flux core weld is so easy to grind when it comes to clean up. I'm doing auto body sheet metal, could someone explain this to me?
/ Grinding my weld #3
Crimini Carl! What are you doing up so early, or late? Either way... you shouldn't be. I have an excuse... I'm in Taiwan.
/ Grinding my weld #5
Dang, Carl - there's PILLS fer that :D
I know - I'm ON 'em :( ...Steve
/ Grinding my weld #6
/ Grinding my weld #7
Never said mine were BLUE - you 'fessing UP to somethin Terry??!? ;)
/ Grinding my weld #8
Uncertain what you're getting at, Steve. These are MY blue "pills". I use them regularly and they always bring a smile to my face :)
Terry
/ Grinding my weld #9
I'm pretty sure this is a record. In 7 posts you guys totally derailed this thread.
In Shield Arc's first post he was spot on. So I guess I gotta adjust to 6 posts before derail.
To the OP. I think what you are seeing is the difference in the hardness of the stick weld rod used and the wire weld wire used. No big deal. But a very good time to educate yourself about the differences. If these guys can get off their personal physical limitations and get back to welding. :)
/ Grinding my weld #10
You're right. To the OP. Sorry. I got carried away.
Terry
/ Grinding my weld #11
Terry
No worries on my part. We all do it. Even Shield Arc who is the most organized and diligent poster I know. :D
/ Grinding my weld #12
I guess I started it... if I post to say I'm sorry am I further derailing the thread? Always wondered. I did post to 'subscribe' though. Interesting question by the OP.
And some relevance to me. I am trying to find best low/no spark grinding media that is affordable. Working in the offshore rig build at Singapore shipyard. Carry on...
/ Grinding my weld #13
Do you notice a difference in the sparks between the two? Sparks can indicate hardness of the metal by color and density.
/ Grinding my weld #14
Try some different MIG wire.
I recall someone mentioned a wire called "easy grind".
2019 Polaris Ranger Crew XP1000 4x4 Utility Cart (A61572)
2019 Polaris...
2016 Chevrolet Silverado 1500 Pickup Truck (A61573)
2016 Chevrolet...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
Kubota Snow plow with subframe
Kubota Snow plow...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
